mklotz70 Posted May 30, 2018 Report Share Posted May 30, 2018 I wish mine would do 65 MPH obviously, you need to find a bigger hill :) edit...... hhmmm....you're in Kansas....they don't have hills in Kansas.....do they?? lol 2 Quote Link to comment
d.p Posted May 30, 2018 Author Report Share Posted May 30, 2018 I wish mine would do 65 MPH Lol I can do 70 no problem, hesitant to go above that though. Quote Link to comment
mklotz70 Posted May 30, 2018 Report Share Posted May 30, 2018 My wife's 521 will easily do 50+ in 3rd on the on ramp. I used to run it back and forth to Salem....1hr....at 70-80 without any issues. It came to use with a dogleg behind the L16/weber and I put a 3.89 rear end in it. I still towed complete 521's behind it with a tow bar....up some serious hills. 1 Quote Link to comment
d.p Posted May 30, 2018 Author Report Share Posted May 30, 2018 My wife's 521 will easily do 50+ in 3rd on the on ramp. I used to run it back and forth to Salem....1hr....at 70-80 without any issues. It came to use with a dogleg behind the L16/weber and I put a 3.89 rear end in it. I still towed complete 521's behind it with a tow bar....up some serious hills. 5 sp dogleg? That is the easiest swap right? Heard its not a very robust tranny but how robust do they need to be in a 521? 1 Quote Link to comment
banzai510(hainz) Posted May 30, 2018 Report Share Posted May 30, 2018 I think they are OK 5 speeds. esp if you find them for 100$ 1 Quote Link to comment
d.p Posted May 30, 2018 Author Report Share Posted May 30, 2018 I think they are OK 5 speeds. esp if you find them for 100$ Anything has got to better than the stock 4spd. 1 Quote Link to comment
banzai510(hainz) Posted May 30, 2018 Report Share Posted May 30, 2018 the 4 speeds are fine for around town. I like them as if im really lazy you can up shift w/o the clutch. give it gas and let off just right and one can put it in the next gear.. This is good when the slave cylinder/MC blows out and one can start in 1st gear and up shift to get home 280zx 5speeds are good but ezest install I believe is the 77-79 200sx model 1 Quote Link to comment
mklotz70 Posted May 31, 2018 Report Share Posted May 31, 2018 5 sp dogleg? That is the easiest swap right? Heard its not a very robust tranny but how robust do they need to be in a 521? This one came with the truck, so I've never done the install. We don't drive hard enough to worry about how robust it is. lol I'm not sure how the 1st gear ratios compare between the 4spd and dogleg, but if they're the same, I'd put a 3.89 diff in. 1 Quote Link to comment
pwrcat4000 Posted June 6, 2018 Report Share Posted June 6, 2018 After getting it set right my truck would probably do 90Mph now.http://community.ratsun.net/topic/73920-pinging-under-power-and-drive-train-qs/?hl=pwrcat4000&do=findComment&comment=1567638 1 Quote Link to comment
d.p Posted June 7, 2018 Author Report Share Posted June 7, 2018 Damn rubber boots from the 555 tie rods already cracking. 1 Quote Link to comment
Jstocks Posted January 10, 2020 Report Share Posted January 10, 2020 I don't know of you guys like a good old throw back, but I need some upper control arm bushings but can't seem to find a solid solution. Rock auto has a some.but they don't look like the ones in bluehands vids. A little help for a guy? 1 Quote Link to comment
wayno Posted January 10, 2020 Report Share Posted January 10, 2020 Are you talking about the inner or outer bushings? 30 minutes ago, Jstocks said: I don't know of you guys like a good old throw back, but I need some upper control arm bushings but can't seem to find a solid solution. Rock auto has a some.but they don't look like the ones in bluehands vids. A little help for a guy? 1 Quote Link to comment
Crashtd420 Posted January 10, 2020 Report Share Posted January 10, 2020 If it's the one I'm thinking it wont look like what rock auto sells.. Mike manufactured what he sold... it was sort of an upgrade..... Wish I bought some..... Stock ones look like this.... 1 Quote Link to comment
mainer311 Posted January 10, 2020 Report Share Posted January 10, 2020 I've used those Moog ones from RockAuto. They start to crack in less than a year (at least on the surface). The threaded inner bushings look extremely similar to datsun roadster bushings, but I don't know if they're the same. 1 Quote Link to comment
wayno Posted January 10, 2020 Report Share Posted January 10, 2020 The 320 and Roadster share these front suspension spindle/bushing parts, the 521 has much larger bushings/caps and the caps will not interchange. 3 hours ago, mainer311 said: The threaded inner bushings look extremely similar to datsun roadster bushings, but I don't know if they're the same. 2 Quote Link to comment
mklotz70 Posted January 11, 2020 Report Share Posted January 11, 2020 19 hours ago, Jstocks said: I don't know of you guys like a good old throw back, but I need some upper control arm bushings but can't seem to find a solid solution. Rock auto has a some.but they don't look like the ones in bluehands vids. A little help for a guy? Yep....I machined those from a Energy Suspension bushing. There's a tiny chance I have a set of the 2 piece ones left, but I'm not sure. PM me if you want me to check. The rubber ones only last about 6 months in my experience and the front one gets completely crushed right after installation. All the trucks I've seen......the top of the dogbone gets pushed forward for some reason...really hard....so the delrin washers(on the ones I was making) on each side of the bushing aren't just there to look pretty. :) lol 3 Quote Link to comment
Jstocks Posted January 11, 2020 Report Share Posted January 11, 2020 5 hours ago, mklotz70 said: Yep....I machined those from a Energy Suspension bushing. There's a tiny chance I have a set of the 2 piece ones left, but I'm not sure. PM me if you want me to check. The rubber ones only last about 6 months in my experience and the front one gets completely crushed right after installation. All the trucks I've seen......the top of the dogbone gets pushed forward for some reason...really hard....so the delrin washers(on the ones I was making) on each side of the bushing aren't just there to look pretty. 🙂 lol I think I'll just run the rock auto 2 piece ones just to try and get this thing to be a rolling solid chassis again. I'm bringing this old truck back and it's in a terrible rusty state. You worked with my brother in law Barto on some really nice D21 uppers. I plan to do the disc brake conversation over this summer once I get this thing mobile again. Lots to do and soooo little time. 😛 Thanks for the replies fellas, really appreciate it. 2 Quote Link to comment
mklotz70 Posted January 11, 2020 Report Share Posted January 11, 2020 4 hours ago, Jstocks said: I think I'll just run the rock auto 2 piece ones just to try and get this thing to be a rolling solid chassis again. I'm bringing this old truck back and it's in a terrible rusty state. You worked with my brother in law Barto on some really nice D21 uppers. I plan to do the disc brake conversation over this summer once I get this thing mobile again. Lots to do and soooo little time. 😛 Thanks for the replies fellas, really appreciate it. I sent you a pm about the urethane ones. They're nice and cheap. We know they don't last very long, so buy a few sets. Put some grease on the bolt or inside the bushings when you install them. The steel sleeve in the bushings rust to the bolt and then you have to cut the bolt out. If you can avoid that, then it's real easy to change out the bushings later. Ah.....yes.....Barto provided me with some great crash testing info. LOL I think we worked it out so that he got a set of the pretty blue ones before I ran out. Disc conversion? Which one? 1 Quote Link to comment
d.p Posted January 11, 2020 Author Report Share Posted January 11, 2020 Mike I’ll take those uppers if you still got them. Will email you now. 1 Quote Link to comment
mklotz70 Posted January 11, 2020 Report Share Posted January 11, 2020 1 hour ago, d.p said: Mike I’ll take those uppers if you still got them. Will email you now. Sorry....all gone now. I'm might try to make some more.....just no clue when. 1 Quote Link to comment
bilzbobaggins Posted January 11, 2020 Report Share Posted January 11, 2020 39 minutes ago, mklotz70 said: Sorry....all gone now. I'm might try to make some more.....just no clue when. right after you get more brake kits done most likely........🥺.....For those of us who are stupid and did not get while the getting was good. 2 Quote Link to comment
d.p Posted January 11, 2020 Author Report Share Posted January 11, 2020 6 minutes ago, bilzbobaggins said: right after you get more brake kits done most likely........🥺.....For those of us who are stupid and did not get while the getting was good. Nothing against Mike as he does great work but Beebani’s is just as capable. 1 Quote Link to comment
bilzbobaggins Posted January 11, 2020 Report Share Posted January 11, 2020 (edited) 28 minutes ago, d.p said: Nothing against Mike as he does great work but Beebani’s is just as capable. I know. Unless you want stock wheels as I do. Its my own goddamn fault. Kinda like the NOS 521 carrier bearing and rubber that was already a steal on ebay. I should have just clicked buy now, but tired to beat him down. Edited January 11, 2020 by bilzbobaggins 1 Quote Link to comment
Charlie69 Posted January 13, 2020 Report Share Posted January 13, 2020 On 6/7/2018 at 9:09 AM, d.p said: Damn rubber boots from the 555 tie rods already cracking. Mosy likely 30 to 40 years old when you bought them new. Quote Link to comment
DanielC Posted January 13, 2020 Report Share Posted January 13, 2020 Back to the upper bushings. 1 Quote Link to comment
