mrbigtanker
I know a wagon chick that bought a 521. Lol
While I was at it & armed with the spraycan...
Share this post
Link to post
I would put the L20b in the one you drive the most, since I am a truck guy I say the truck needs the most power, but you may drive the wagon more.
  • Like 4
Share this post
Link to post
Yeah, the wagon is my 1st love so she will get the goods  :console:
Share this post
Link to post
The tailgate hinge pins are 5/16 in diameter. You can take a 5/16 punch, and drive the pins out. This will be difficult on the left hinge, if the hinge itself got bent.
Most punches are not long enough to completely drive the hinge pin out. Once the hinge pins has been moved as far as you can with the punch, you can use a long nail to finish removing the hinge pin.
The newer to you tail gate may not fit onto your bed exactly, but try it anyway. The tailgate top is held by the tail gate latches, the bottom of the tail gate is aligned by bending the hinges.
Share this post
Link to post
Angela buy a 25.00 spray gun go tofinish masters and have them match it up and re do it. It will be fun and look better in the long run.
If your not looking to learn to paint and want the color a little closer...
Another way is take the paint code to an auto paint stores, some have the ability to make a rattle can in the exact color, even with the clear mixed in if you wanted....
Either way what you did looks pretty good...
Share this post
Link to post
I forgot about that Crash...thx for the reminder. I actually am interested in learning to properly paint a car (just not right now) since I used to do a bunch of airbrushing & went to art school & stuff  :geek: . I'd like to transfer my skills from the canvas to metal someday.
Share this post
Link to post
It's really not bad actually I had a little learning curve when I started, but if you can air brush, and can lay a decent finish with a rattle can you could definately paint with the guns....
I've been painting my 521 with a HVLP spray gun in my garage, and i have zero skill.
Getting the guns set wasn't too bad, but it's different for differnt paint...
My biggest mistake was not cleaning the gun good enough... after I found a screen inside I missed... things went much better after I realized that....
Goodluck ....
Share this post
Link to post
I know that. But still shoots like shit. Just better paint. It will all turn out in the end good.
Share this post
Link to post
In another life I painted '74 and '75 Chev truck boxes at GM. About a year (or maybe two) after I left it was all done by robots. I knew how to paint but nothing about how the gun worked. It was a moving line.. if there was a problem you grabbed one of the spares at your station and kept painting. A maintenance man would come and replace it in seconds and take it away to 'maintain and clean it'. Paint and air was supplied under pressure to the gun which had an electrostatic charge which made the paint attract to the grounded box. You stood on a raised cat walk with a river flowing under you to catch the over spray that was pushed down by the filtered air supplied from above. Perfect ceiling to floor lighting. All you had to know was how to hold a gun and move your arm. Two hundred and thirty boxes a shift although with 1/2 hour break every 2 1/2 hours and one of those 1/2 hours was prep you did about 140 in 9 hours. You only did one side and the inside. In the 11 months there I (slightly) fucked up one job. White paint. Hard to see the surface properly. I didn't know when I started that everyone else thought the metallic colors were hard. A German guy named Carl was my mentor. I really liked that job and I have missed it.
  • Like 4
Share this post
Link to post
