racerx Posted August 18, 2017 Report Share Posted August 18, 2017 Im not an expert like most people here but heard you need to pcv or else you can have a blowby. Quote Link to comment
KoHeartsGPA Posted August 18, 2017 Report Share Posted August 18, 2017 Well, by having the pcv plumbing you never see blowby because it gets sucked back in by the intake and burnt in the combustion chamber and out the exhaust.... Quote Link to comment
KoHeartsGPA Posted August 18, 2017 Report Share Posted August 18, 2017 Explanation of PCV https://en.m.wikipedia.org/wiki/Crankcase_ventilation_system Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 Okay so got an update. My rear passenger strut was snapped at the bolt and was made to look functional by the guy who sold it to me. lucky I made it home at all. so questioning everything that's been done to the truck. the Tach is wired all sorts of stupid and isn't connected to any power source at all. in fact its across the engine bay from the coil. the Ovalcraft breather tank is probably only half set up. Wont it be dangerous to jack up the truck with a snapped strut? going for a shot in the dark here but hoping to appeal to the sellers reason and get 200 deducted from purchase price to accommodate new rear struts. The Tach can be cut way back to good undisturbed wiring and given the appropriate heads to attach to my coil, and my carb choke right? Quote Link to comment
Crashtd420 Posted August 18, 2017 Report Share Posted August 18, 2017 stupid question... could one theoretically replace a auto wire with a speaker wire? 12 gauge that is. it's kind of ok .... depends on what your hooking up.... I'm not 100% sure the theory on it but I think it comes down to the number of strands of wire in the cable... speaker wire tends to have more strands of wire plus 2 wires in parallel then you have say a single multi strand cable and then you can get a 12gauge wire with just 1 strand. I guess the real question is what are you trying to use it for? Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 turned out I had 10 gauge wire and my tach needs 14. also followed all the tach wires and realized theres way excess wire and its looped to the wrong side of the engine bay. what rear struts should I get planning on a normal height or up to a 2 inch lift. I have KYB Gas-a-just front struts and was looking into kyb monomax for the rear. Quote Link to comment
Crashtd420 Posted August 18, 2017 Report Share Posted August 18, 2017 You sure you have struts? I think your calling it the wrong thing.... I think i saw one in one of your pics.. they should just be regular shocks ... Struts would have a spring with it... Unless previous owner did a conversion Tortion bars up front Leaf springs in the rear.. 4 shocks... A stock shock will be fine, if your going back to stock height and even with a 1 or 2 inch drop.... I think only once you get down to 3 or 4 or more inches people start to look for shorter shocks.... Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 You sure you have struts? I think your calling it the wrong thing.... I think i saw one in one of your pics.. they should just be regular shocks ... Struts would have a spring with it... Unless previous owner did a conversion Tortion bars up front Leaf springs in the rear.. 4 shocks... A stock shock will be fine, if your going back to stock height and even with a 1 or 2 inch drop.... I think only once you get down to 3 or 4 or more inches people start to look for shorter shocks.... Yeah I had that backwards. Shocks under my truckbed is what I need. stock is meaningless to me as performance parts are cheap and isnt getting a full KYB set gonna be more "in sync" if you will of an experience than grabbing stock ones? Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 Dangerous as all hell right? isn't that kinda a big deal to misrepresent that in a sale? from my end I feel relieved I made it home. but also feel I deserve a exchange to mitigate my loss by simply covering cost of new rear shocks to thereby make the truck in as advertised condition to begin with. granted this could all be wishful thinking, but "in a perfect world" doesn't that seem reasonable? Quote Link to comment
datzenmike Posted August 18, 2017 Report Share Posted August 18, 2017 A strut supports weight. A strut may incorporate a shock in it, as in a McPherson strut. A shock simply provides damping action. You have shocks. Air shock actually so the ride height can be adjusted up by adding air. The top thick shorter leaf. It needs to come off and be placed on the bottom of the spring pack. It's curved so match the curve to the rest of the springs. It looks upside down. Don't change or move the other leaves around only that top one. This is the cross rod. Loosen the nuts on each end and turn it. One way is tow in the other is toe out. Catch cans on a street car just make more work and mess. They collect condensed water, gas and oil fumes and need to be emptied every now and then,... so what do you do? throw it on the ground? in the land fill??? A stock set up pipes it into the carb to be burned. Simple, clean, nothing to do.. 1 Quote Link to comment
KoHeartsGPA Posted August 19, 2017 Report Share Posted August 19, 2017 I disagree on your catch can for street use comment, all you gotta do is drain if there's anything in there and blow out the filter with each oil change, no hassle and no mess whatsoever, they have a drain, all you gotta do is install it properly. 1 Quote Link to comment
Crashtd420 Posted August 19, 2017 Report Share Posted August 19, 2017 Yeah I had that backwards. Shocks under my truckbed is what I need. stock is meaningless to me as performance parts are cheap and isnt getting a full KYB set gonna be more "in sync" if you will of an experience than grabbing stock ones? When I said stock I wasn't saying oem factory correct.... Just stock in regards to fitment... So ya I would buy those kyb too ... Quote Link to comment
76Lil Hustler Posted August 19, 2017 Author Report Share Posted August 19, 2017 lol My bad, yeah figured if kyb gas a just on the front might as well make that whats in the rear. Quote Link to comment
76Lil Hustler Posted August 19, 2017 Author Report Share Posted August 19, 2017 I disagree on your catch can for street use comment, all you gotta do is drain if there's anything in there and blow out the filter with each oil change, no hassle and no mess whatsoever, they have a drain, all you gotta do is install it properly. I have doubts this is done right, the 2nd port hole is just blocked off. Quote Link to comment
KoHeartsGPA Posted August 19, 2017 Report Share Posted August 19, 2017 I got these for the fronts on my 620, they're for going low....very low... https://www.amazon.com/gp/aw/d/B01M8NWDAO/ref=mp_s_a_1_70?ie=UTF8&qid=1501002890&sr=8-70&pi=AC_SX236_SY340_FMwebp_QL65&keywords=shocks+qa1 Quote Link to comment
KoHeartsGPA Posted August 19, 2017 Report Share Posted August 19, 2017 I have doubts this is done right, the 2nd port hole is just blocked off. What?, Post pics please 1 Quote Link to comment
76Lil Hustler Posted August 19, 2017 Author Report Share Posted August 19, 2017 I got these for the fronts on my 620, they're for going low....very low... https://www.amazon.com/gp/aw/d/B01M8NWDAO/ref=mp_s_a_1_70?ie=UTF8&qid=1501002890&sr=8-70&pi=AC_SX236_SY340_FMwebp_QL65&keywords=shocks+qa1 oh hello naw lol I am moving away from lowered cause I cant go places. My truck will be doing multi-state travel up to 10 times a year maybe more. its a lowrider now has terrible speeds, has a beat up body under the passenger door and the muffler. This truck wont be a pretty princess. It'll be a champion. pics on the way. uno momento. 1 Quote Link to comment
KoHeartsGPA Posted August 19, 2017 Report Share Posted August 19, 2017 This is the catch can I've got installed in my 510 and ordering one for my 620 before I forget.... http://m.ebay.com/itm/Polished-Chrome-Universal-Oil-Catch-Can-Tank-KIT-9mm-Breather-Air-Filter-/161549881968?hash=item259d1f9270%3Ag%3Ak1kAAOSw6aVUrDCW&_trkparms=pageci%253Ac2025d56-847e-11e7-8397-74dbd1801221%257Cparentrq%253Af821f53e15d0ab4d29a1197bfff725fe%257Ciid%253A17 Quote Link to comment
datzenmike Posted August 19, 2017 Report Share Posted August 19, 2017 I disagree on your catch can for street use comment, all you gotta do is drain if there's anything in there and blow out the filter with each oil change, no hassle and no mess whatsoever, they have a drain, all you gotta do is install it properly. Yeah "all you gotta do is drain if there's anything in there and blow out the filter with each oil change". Well with the stock set up you don't have to do anything. And again my question is, where do you put the oily gas smelling contents you drain out? Recycle it? throw into the environment? the land fill? What about the fumes they vent out??? Catch cans are a joke and cause more problems and more work. They are for race tacks to catch oil blown out by an exploding engine and keep it off the track. They serve ZERO purpose on the street. Every car made vents the crankcase into the intake and they do just fine. Quote Link to comment
76Lil Hustler Posted August 19, 2017 Author Report Share Posted August 19, 2017 Quote Link to comment
KoHeartsGPA Posted August 19, 2017 Report Share Posted August 19, 2017 Yeah "all you gotta do is drain if there's anything in there and blow out the filter with each oil change". Well with the stock set up you don't have to do anything. And again my question is, where do you put the oily gas smelling contents you drain out? Recycle it? throw into the environment? the land fill? What about the fumes they vent out??? Catch cans are a joke and cause more problems and more work. They are for race tacks to catch oil blown out by an exploding engine and keep it off the track. They serve ZERO purpose on the street. Every car made vents the crankcase into the intake and they do just fine. Maybe you got a point, but my oil looks like it's been changed yesterday despite it having 1200 miles on it now, the carburator intake is clean as a whistle and air filter too, I haven't had to drain it yet, I tried but nothing came out of it, my engine bay smells no different from any other, so I don't understand the smell point.... Quote Link to comment
KoHeartsGPA Posted August 19, 2017 Report Share Posted August 19, 2017 How is it plumbed?, I see the valve cover hose going that direction, does it have the crank breather hose going to it? Quote Link to comment
datzenmike Posted August 19, 2017 Report Share Posted August 19, 2017 The stock engine is vented into the intake, either through the PCV or the valve cover hose to the carb, so no fumes or blow by escape while it is running. Unlike the catch can it is a closed system. Your oil should be clean but the catch can does not keep it any cleaner. How could it possibly prevent oil from becoming dirty? Quote Link to comment
76Lil Hustler Posted August 19, 2017 Author Report Share Posted August 19, 2017 the only tube. otherwise just a wing nut drain screw on the bottom me thinks. Quote Link to comment
racerx Posted August 19, 2017 Report Share Posted August 19, 2017 So if they are needed then why did they not come stock. Hence, PCV. Quote Link to comment
