KoHeartsGPA Posted August 17, 2017 Report Share Posted August 17, 2017 except theres pics. its called page 1. Negative, there are none, like your pic count. Quote Link to comment
racerx Posted August 17, 2017 Report Share Posted August 17, 2017 If tdc, is not clearly seen, good time to mark it with white out or something that can easily be seen. Quote Link to comment
paradime Posted August 17, 2017 Report Share Posted August 17, 2017 OP" "as it stands Ratsun.net has not had the best time with photo posting so if you want photos to help with guiding me through my many newbie questions you can feel free to pm me for my email or phone number." Private photos only if you want to help guide him. Or he could... Nah never mind, that would be asking too much. Quote Link to comment
76Lil Hustler Posted August 17, 2017 Author Report Share Posted August 17, 2017 I posted images on page one from imgbb which others had no trouble viewing so I don't know what to tell you. My tach is broken sounds like I should fix that first. I will post more image links of my carb as one of the lines running off it was plugged by a pencil by the previous owner. makes me feel like some set up parts may not be as they should. i will take pics of my pully as well in an attempt to identify said marks. thanks again for all the helpful info mike! whats tdc? once again pics on page one post #19. Quote Link to comment
Jesse C. Posted August 17, 2017 Report Share Posted August 17, 2017 except theres pics. its called page 1. except they are called links, on page 1 2 Quote Link to comment
76Lil Hustler Posted August 17, 2017 Author Report Share Posted August 17, 2017 except they are called links, on page 1 I will accept that one. I'm new, this was my first posting, teach me how to import photos directly from imgbb and I shall. My point to the others was that I did provide info they requested. obviously not the way ya'll wanted but hey! They exist! Quote Link to comment
Draker Posted August 17, 2017 Report Share Posted August 17, 2017 I posted images on page one from imgbb which others had no trouble viewing so I don't know what to tell you. My tach is broken sounds like I should fix that first. I will post more image links of my carb as one of the lines running off it was plugged by a pencil by the previous owner. makes me feel like some set up parts may not be as they should. i will take pics of my pully as well in an attempt to identify said marks. thanks again for all the helpful info mike! whats tdc? once again pics on page one post #19. Top Dead Center Where piston 1 is at the top of the stroke, and the cam lobes are at the 10 and 2 position. 1 Quote Link to comment
76Lil Hustler Posted August 17, 2017 Author Report Share Posted August 17, 2017 Top Dead Center Where piston 1 is at the top of the stroke, and the cam lobes are at the 10 and 2 position. Thanks for explaining Draker! Quote Link to comment
datzenmike Posted August 18, 2017 Report Share Posted August 18, 2017 testing photos. 1st my truck. 2nd where timing is set and 2nd B is internal of electric ignition. (complete newbie so might be wrong/getting a timing light asap) 3rd is my carb. 4th is overall engine after purchase. my manual was eaten by mice/rats what I do have is a Chilton's tune up and repair manual. open to hear a better hosting site but for now to make things somewhat functional here's links to imgbb. https://ibb.co/grbiuv https://ibb.co/cZO2nF https://ibb.co/hJFySF https://ibb.co/hfNpZv weber 32/36 https://ibb.co/gtp6ga Well, you could post the actual image rather than a link... Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 kinda off topic but I have my truck lowered from purchase, I don't like it and want to get some height clearance instead. question 1. can I swap the blocks to on top of the axel as a lift to level out with the adjustable front? question 2. If so which end should I adjust first? will add pics to my imgbb of suspension shortly. @datzenmike Ooooh I must have an extra chromosome! I will try to do that with my suspension pics and my pully measurement teeth. *lawl! it was just a copy paste. deeerrrrp. Quote Link to comment
datzenmike Posted August 18, 2017 Report Share Posted August 18, 2017 If you have blocks, and just remove them, the truck ride height will go up the thickness of the blocks. The front torsion bars can be adjusted to set the front ride height. Keep in mind ANY front end height adjustment will mess with the toe in alignment. Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 okay so I adjust the front inner and outer tire rods to realign yes? Here's back blocks. here's more. desired tires of original size. Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 phone is charging then I will post more engine images. anything specific I should post? Quote Link to comment
KoHeartsGPA Posted August 18, 2017 Report Share Posted August 18, 2017 Bout fucking time! Welcome to Ratsun! :poke: 1 Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 Bout fucking time! Welcome to Ratsun! :poke: lol I'm only a little special I swear. 1 Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 posting images of front suspension and struts to figure out how far I can safely lift. (don't want a super lift but a truck that can actually go places like gravel/logging roads and the like.) horridly newbie question. usually its straight forward but I cant see under my truck far cause its so low. can I see a pic of a 620 torsion bar location? googling it too but I trust a ratsun member more than the open web. I understand such a thread probably already exists a link to said info works just as well. Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 Also when I'm done tuning and think its close to being perfect or think its good to go I want to share a video of how it sounds and where my marks are set etc. just because I like having confirmation of work from those with ample experience. Thinking of investing in this, PerTronix electronic Ignition. seems way easier on the engine in the long run. https://autoplicity.com/1668041-pertronix-module-kit-for-1741?gclid=CjwKCAjwoNrMBRB4EiwA_ODYv8vah2as34zJfynYvwI_PCPmyv7SC4omqvDeqn6Jr9DUlYWUirwVixoCil0QAvD_BwE Quote Link to comment
racerx Posted August 18, 2017 Report Share Posted August 18, 2017 I've had that on several ol skool cars, works well, you have to have a single point distributor to make it happen. Stay away from knock off brand, hotspark. Good luck. Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 I've had that on several ol skool cars, works well, you have to have a single point distributor to make it happen. Stay away from knock off brand, hotspark. Good luck. So I should get the whole new PerTronix ignition distributor then yeah? Quote Link to comment
racerx Posted August 18, 2017 Report Share Posted August 18, 2017 No, you can modify ur dual points to single points or get a single point. A lot of guys here also get the elec. Dizzy from later L series engines. What's wrong with he set-up? Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 No, you can modify ur dual points to single points or get a single point. A lot of guys here also get the elec. Dizzy from later L series engines. What's wrong with he set-up? Nothings wrong, was just wondering if I needed a married set. I will post more pics of my existing distributor. looks real fresh and clean. cant imagine it needs too much adjustment or anything. electronic ignition seems extremely more reliable. either that or drive around with an extra 3-4 sets of points and condensers in the glove box. Quote Link to comment
racerx Posted August 18, 2017 Report Share Posted August 18, 2017 The reason why I got pertronix was because I had a bitchen time adjusting dual points and a friend of mine sold me the idea of pertronix. If your dist. Is good still keep it that way till it takes a dump. If you don't know how to adjust points, read up on it and practice. And yes do keep sets in your glove box, you never know. 1 Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 Definitely new to setting points but I have a Chiltons repair and rebuild book. Quote Link to comment
racerx Posted August 18, 2017 Report Share Posted August 18, 2017 Go on line, YouTube, and watch how they adjust dual points, then practice. Good to have a dwell meter but not really needed if you can adjust properly. Ur location? Quote Link to comment
76Lil Hustler Posted August 18, 2017 Author Report Share Posted August 18, 2017 it looks like a dual point... :( Quote Link to comment
