f1ndM3aTaco
The Geisha
aHAop9rRG2YecXBTHRhTivgaDxE8wwxJrKYNXKR5
Crossmember bolt is still being a real pain in the ass
0c4DRpp8ZKKQOXoGTYyoWYCNS8dyNgyIAWm257Fu
So are the flange bolts on the drive shaft... :sneaky:
Any suggestions on either? Sawzaw the xmember bolt? Flange bolts also have very little height to them to get a proper grab on them. Been spraying them with pb blaster for days now.
Share this post
Link to post
Give some heat for the nuts/bolts with heat gun or torch and get longer lever arm to bust them open. Glad to see another B310/210 on the forum!
Share this post
Link to post
I'll give it a shot. Love your build too, can't wait til I have a garage where I can weld like you are.
74hFyGKT_PYT-QWEoWNKUQ2BdcZ2JXvNDvTqL4u8
Suggestions on cleaning/painting of rad without damaging?
41fvbz9Z1ZFlx5Q4q5rXuQ05bIR_45LUAsXwCVgL
Really can't wait til the rad support can be addressed. Looks like I'll be able to keep enough of the front valence that it wont need too much chopping but I don't know, only hoping. :wacko:
Share this post
Link to post
Your front looks just like what mine was  :rofl: Must be common with these. I just cleaned my rad, first checked if it was too soft or not. If you're able to poke your finger through the fins just like that, then it might be good to consider about new one or have it redone by someone (new core). But if it seems ok, i just sanded down the frames + top and bottom, sprayed zinc paint to the sidemounts because they began to rust. Then some primer and finishing color. I didn't do much with the core itself, just light spraying with mattblack spray paint to make it look a bit better  :rofl:
Share this post
Link to post
I cleaned mine up a fair bit and think it will hold up. I heard grill paint, as in actual fire grill, works bretty good too.
Share this post
Link to post
DNXj3RNO54RwXGa2xFXtWeE9cgMryZbv8RvSpd0j
Today's set up
JI_x0GWlL5hO8bbBxTUy3nVBFgvVwGt_3sDHmokk
Finally smacked the exhaust out of the manifold. Gonna bring it to a shop and have them build me something similar. Considering i'm going to be driving cross country what's a good size/setup that won't destroy my ear drums? Stock really wasn't that bad in my opinion but I don't know.
Share this post
Link to post
0dyfY6YBV-hxvG0qPB6q-QfT6SvVxMEVn8z_i9IR
Since the exhaust was out, that meant the manifolds could finally come out too.
x0JESQoWwngfCSsQ0hzW8zv1jl0iLzrc0f0eJbMn
Got the intake nice and shiny with a little brushy brushy. Gonna need some more degreaser though...  :P
Share this post
Link to post
Taco doing something even hobo doesn't like doing. Walking around barefoot in grass....
Share this post
Link to post
Thats great, I do the same thing.... try pulling an L20B over 30ft in soft grass and wet on a engine stand without tipping!!!
This is real Shade Tree mechanic work here, before Hot-Rod TV was Spike and Velocity.... Love It.
Keep up the pics, its good to see your real progress.
Share this post
Link to post
I don't like the feel of the grass on my feet. I'll walk a gravel road barefoot over 2 steps in grass
Share this post
Link to post
dZYu8UDNDbr_9Z0I9BcOCxuvduvPG7oaZ7kFQA9x
Got the carpet out last week or so, hosed it down to get the coolant out of it and had it rest in the sun for two days. Then I took it into my basement where I let two dehumidifiers and the heater take care of whatever moisture was left.
Erf2EUBGuCn36hH3595cseS8L31NQij4YKlsz0uB
Brushed down everything with an old exterior painting brush and followed behind with the vaccum cleaner.
Share this post
Link to post
IbXp_XIpkPA36O5U-ARWV2H6Uwa5FKLEUsihUlz7
Reattaching the speedometer cable and the wiring behind the cluster needs really tiny hands, not fun.
BCwWY-EfbjiHGqcqkxiIQQYxfw3qlQ9mRlWxvQ-5
Replaced all the original lights with LED's. Hope they aren't anything obnoxious, just want better light than stock from 40 years ago, although will still keep them on hand considering the fact they still work.
Share this post
Link to post
k7lBTtmGmvESDvtvFCilYAJFcc7829QZ7_h5DtxA
Finished rebuilding the heater core too. New blower motor resistor came in today, same as 720 resistor for those who want to know.
Share this post
Link to post
YipWeavGkqiw9XHHjnXoUY7kHQxu5LPqXzz4h9RT
and the wiper bottle holder/assembly.
Dn2meZKYinqkSO2ZUiA2TKTBl61lH1Uf1K-6IgqQ
Using copper based anti-seize on all the pieces that need it. Wiper screw too.
Share this post
Link to post
s_63vMyxYl8cG6DSqQiaKaePQpzoQHLb_YC80PB9
Vacuuming the carpet one more time
FYGKB1etLtrH2NdqnZK5oRN7jTeEhC_M4L8X2d_w
Did not have fun putting the front dash/cluster/heater core back together, but I can safely say that I know it inside out and backwards now. Dash panel finally cracked, but was expecting that to happen eventually. Not a bad crack so I can fix it too. Looked into Eastwood's dash stuff.
KC70wUizr6OKXFf6racYXX2BJaQwErvsF-vuH6Hc
Cracked at least 5 different screw holes in different spots, "fixed" them with an electrical soldering pen like I know Atomic has. Didn't matter how gentle I was some still cracked. What can you expect from 40 year old plastic? it really got me thinking about one day having all of these parts rendered and remade through a 3d printer using better plastic.
  • Like 3
Share this post
Link to post
UXBhSlNs5J16xDZNvClbFuAwjCqYiRyo0SaUWR6w
got a better idea of the rust situation today.
mEwYI8P-ikxysBrduujzlB3PM-YtGGoMt3QiIqBo
behind spare tire compartment.
032HkdFe5xV53ghensNMXvn7Ribu7eL4l3SCCFO1
Driver's side bumper/frame rail
G5iq2q9FtwBHn_0Ttr7ROJnNeHukTDm0seoFujcq
Behind rear drivers wheel. Both sides look about the same.
So I was thinking about how to tackle these before I put the gas tank back in and get this car back on the road. I don't care if the car has primer spots. Just want to know that the rust isn't going to get worse or at least too bad until I have the money for a proper body shop to fix it.
I was thinking wire wheel, brush with vinegar, wash with baking soda and water, rust converter and then maybe another coat or two of primer? Any suggestions?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
