Motopilot Posted June 26, 2017 Report Share Posted June 26, 2017 I was wondering if anyone cam comment on swapoing a 620 wheel onto a 521. I am confident the spline is the same. Any issuers with fitment for the column in regards to keeping the stock 521 turn signals. I am not concerned about turn signal auto cancelling at all. I assume that the horn will work... just need to connect the wire..but I don't know that for sure. Thank you for any replies Quote Link to comment
spdcrazy Posted June 27, 2017 Report Share Posted June 27, 2017 yes it will fit just fine. splines are the same. looks good too! I had this on mine for a short time. I can not comment on the horn, but its a simple piece of technology, so I don't see why it wouldn't give it power and when you push, make sure the connection is made so noise happens. a 620 center console fits pretty well also, completes the "package" kinda. just a thought. Quote Link to comment
Motopilot Posted June 27, 2017 Author Report Share Posted June 27, 2017 Thank you. I was hoping it would swap across. Cheers 1 Quote Link to comment
