906-Runner Posted October 20, 2021 Report Share Posted October 20, 2021 I just recently bought a 1984 Nissan/Datsun 720. It's a single cab 5 speed 4x4 with 122k miles. The previous owner out in a 32/36 Weber carb so it runs good but its in need of a rebuild. I stumbled uppon this thread and am intrigued by the work @Crytek89 has done swapping in a KA24DE into his 720. While my truck still runs and drives I am pondering the possibilty of accumulating parts based off your list to eventually do this myself once it is no longer my daily driver. That being said I have a few questions for you and others who have done this swap. Regarding the motor I have found there are two options, FWD and RWD; logic would say get a RWD motor but most of the ones I have found are out of S14 or 240sx and are more expensive. Would a FWD motor work? Visually I can't really tell the difference between the FWD and RWD motors. Next would pertain to the wiring aspect of the fuel injection system. Did you go with a standalone ecu, or did you reuse the KA24DE ecu? I'm sure ill have to get wiring diagrams of my truck as well as whatever vehicle my donor motor comes out of to figure out my wiring. Next is mounts. I see that @]2eDeYemakes mounts for the 620 pickup that seems to work for this swap but need minor modification? Other than motor mounts, all existing mounts will work? And finally Im wondering about the oil pan setup. I know it needs to be modified and cut/rewelded. will my truck being a 4x4 change anything? Will it clear the front differential or will I have to go another route? This is not a project I plan on tackling in the immediate future; but would like to start gathering parts now. Any help/info/advice from all you would be great. Quote Link to comment
datzenmike Posted October 20, 2021 Report Share Posted October 20, 2021 The S13 or S14 240sx are RWD (rear wheel drive) engines. A FWD (front wheel drive) engine is mounted transversely (or sideways) in the engine bay. The Stanza/Altima have FWD KA engines. The car KA is also much heavier than the Hardbody truck block. The car intake manifolds are nicer than the truck intakes and the car wiring is on a separate harness that is much easier to separate from the car than the truck harness is from the truck. If using ]2eDeYe's engine mounts and the 720 transmission that all you need. If swapping in the stronger 71C transmission already on the KA then you will need a different transmission mount (I think Steve has those also) and the drive shaft will need to be shortened. 240zx engines have a large crank girdle and modifying the oil pan for use in the 720 is more work. Even more work if clearing a front differential. A truck KA is similar to the 720 with a 'front sump' so probably easier to mod. 1 Quote Link to comment
906-Runner Posted October 20, 2021 Report Share Posted October 20, 2021 So then I guess what I'm wondering is this; if I pull the KA24/71C out of a 4x4 D21 I theoretically wouldn't have to do as much screwing around to get it in the truck(mounts are available to be bought)? But then I'd want to think about getting the intake maifold and wiring harness from a car KA24? And then it'd just be figuring out the wiring for the injectors etc. Quote Link to comment
]2eDeYe Posted October 20, 2021 Report Share Posted October 20, 2021 1 hour ago, 906-Runner said: So then I guess what I'm wondering is this; if I pull the KA24/71C out of a 4x4 D21 I theoretically wouldn't have to do as much screwing around to get it in the truck(mounts are available to be bought)? But then I'd want to think about getting the intake maifold and wiring harness from a car KA24? And then it'd just be figuring out the wiring for the injectors etc. Yes, this is essentially the way to go. I am still not sure why the mounts were modified, but these trucks are old and sometimes used as trucks and may not be as straight as they once were? I have had one other person have an issue like that with his 720, not near as drastic. I made him a custom mount to correct the issue when he contacted me about it. The wiring is fairly straightforward if you can read a wiring diagram or 3 and you trucks original wiring hasn't been too hacked on. Currently helping a guy who got a truck that was swapped and had all the wiring unplugged and all the relays on the floor. Quote Link to comment
Crytek89 Posted October 21, 2021 Author Report Share Posted October 21, 2021 I think DatsunMike hit the nail on the head with his answer. ]2eDeYe, in doing my frame swap I made a video detailing each area of the swap with the cab off (coming soon). On my original frame the mount seemed to be bolted back further than what it should have been. Not sure if the mount was replaced at some point or not though. I'm finding lots of goodies as I get deeper into this project 😂 With the new frame, originally SD25 diesel, i had to drill new bottom mount holes, in which case I could have kept your original mounts as-is and adjust my drilled holes accordingly. 1 Quote Link to comment
Crytek89 Posted October 21, 2021 Author Report Share Posted October 21, 2021 (edited) 21 hours ago, 906-Runner said: Next would pertain to the wiring aspect of the fuel injection system. Did you go with a standalone ecu, or did you reuse the KA24DE ecu? I'm sure ill have to get wiring diagrams of my truck as well as whatever vehicle my donor motor comes out of to figure out my wiring. While there's lots of standalone ECU options available (megasquirt, nistune, haltech, Enthalpy etc..), I went with the stock ECU, mind you there are many different versions and some will benefit you more than others. Each stock ECU will have a number on it, this indicates whether it's OBDI, OBDII, Federal Emissions, Cali-specific, manual or auto. I went with a Federal Emissions with Auto ECU, and I only did this because the auto ECU has no speed limiter. Edited October 21, 2021 by Crytek89 Quote Link to comment
Dboy021 Posted January 30, 2022 Report Share Posted January 30, 2022 This thread is a life saver. Bought an 86 720 with a truck KA24E, and no idea where to start. Please do keep this going. It's already made my swap worlds easier. Now to get ahold of ]2eDeYe and Icehouse for mounts and CAN/AM box, respectively 2 Quote Link to comment
Crytek89 Posted January 31, 2022 Author Report Share Posted January 31, 2022 (edited) On 1/30/2022 at 1:06 AM, Dboy021 said: This thread is a life saver. Bought an 86 720 with a truck KA24E, and no idea where to start. Please do keep this going. It's already made my swap worlds easier. Glad to help anyway I can! I'll also be updating the how-to to add clarity and expand on some of the steps hopefully soon. Was planning on adding some additional photos but a ton of snow changed those plans on my last trip up doing my frame swap. Edit: Well got around to adding a photo or two, lots of clarification and some grammatical changes. More changes coming soon! Edited February 14, 2022 by Crytek89 1 Quote Link to comment
Jitenshakun Posted July 19, 2022 Report Share Posted July 19, 2022 Great thread. Can anyone comment on how a KA24DE fits in a 4x4? The oil pan on the Z22 and Z24 4WDs are wacky enough... Quote Link to comment
datzenmike Posted July 19, 2022 Report Share Posted July 19, 2022 The oil pan for the '80 L20B 4x4 is a one year only and has the bulge on the opposite side to the Z engines. The KA-E was used in the D21 4x4. Although the 720 and D21 front differentials are probably not exactly the same the KA 4x4 oil pan might clear the 720 front. Worth looking into. Quote Link to comment
Jitenshakun Posted July 19, 2022 Report Share Posted July 19, 2022 Always the oil pan (I am still looking for a L20B 4WD pan). It seems that if going to the hassle of a KA in a 4WD 720 one may as well go all in and add a turbo to the mix. Quote Link to comment
datzenmike Posted July 19, 2022 Report Share Posted July 19, 2022 This is an '80 720 L20B oil pan as viewed from the front. You can see the L series engine block's 12 degree tilt to the right. the '80 front differential is to the right side and the pan bulge is to the left. All Z22/Z24 front differentials are to the left side of the truck and the pan to the right. I don't need it. 1 Quote Link to comment
Jitenshakun Posted July 20, 2022 Report Share Posted July 20, 2022 6 hours ago, datzenmike said: This is an '80 720 L20B oil pan as viewed from the front. You can see the L series engine block's 12 degree tilt to the right. the '80 front differential is to the right side and the pan bulge is to the left. All Z22/Z24 front differentials are to the left side of the truck and the pan to the right. I don't need it. PM sent! Quote Link to comment
DerekC Posted August 28, 2022 Report Share Posted August 28, 2022 Any chance you could post more pictures or videos on the oil pan modification? Quote Link to comment
Jitenshakun Posted August 28, 2022 Report Share Posted August 28, 2022 I can when I get there. Quote Link to comment
Crytek89 Posted August 28, 2022 Author Report Share Posted August 28, 2022 12 hours ago, DerekC said: Any chance you could post more pictures or videos on the oil pan modification? Try and ignore the rust and crappy bushings, it's already been fixed/replaced 😅 1 Quote Link to comment
DerekC Posted August 28, 2022 Report Share Posted August 28, 2022 Thank you. So I understand, the flange part that mounts to the motor is from the ka24de. The part that drops down in the back of your picture is from the d21 pan. What's the Frankenstein looking part from in the front? Quote Link to comment
Crytek89 Posted August 28, 2022 Author Report Share Posted August 28, 2022 47 minutes ago, DerekC said: Thank you. So I understand, the flange part that mounts to the motor is from the ka24de. The part that drops down in the back of your picture is from the d21 pan. What's the Frankenstein looking part from in the front? That's exactly right, yup. The "frankenstein" part in the front is a result of the D21 pan isn't squared at the front, but rather it slopes on one side, so to get it to square up with the KA flange I had to add some extra metal to compensate. 1 Quote Link to comment
DerekC Posted August 28, 2022 Report Share Posted August 28, 2022 I really appreciate that. I think it makes a lot of sense now. Tha k you for the entire article and everyone especially comments. 2 Quote Link to comment
DerekC Posted April 19, 2023 Report Share Posted April 19, 2023 What coolant hose did you use for the lower radiator? I tried the one for 240sx, but it didn't work. 1 Quote Link to comment
Crytek89 Posted April 19, 2023 Author Report Share Posted April 19, 2023 4 hours ago, DerekC said: What coolant hose did you use for the lower radiator? I tried the one for 240sx, but it didn't work. I used an aftermarket 240sx hose for both the upper and lower rad hose. "GPlus" is the brand. 1 Quote Link to comment
DerekC Posted April 19, 2023 Report Share Posted April 19, 2023 Was your radiator for a 240sx or 720? 1 Quote Link to comment
Crytek89 Posted April 19, 2023 Author Report Share Posted April 19, 2023 2 hours ago, DerekC said: Was your radiator for a 240sx or 720? 240sx, but they're very similar. I went went a dual-core aluminum Mishimoto. 1 Quote Link to comment
