compression
510 guy just got a 240z....now what?
First off, sorry no pictures in this post. Those will come later, when I have time to sort through them all.
Man, I did a lot of work to the car over this winter (2017/2018). So many things changed. I am calling this Phase 1 mods (L-series, suspension, wheels/tires, brakes, etc). If I decide I love the car and want to keep it forever, I will plan Phase 2 for another year or two down the road (body/paint, engine swap, interior, etc)
So this winter been hard at work on the following:
-Reassembled an L28 I got off of craigslist. Replaced all critical parts (yes, I used an OEM head gasket)
-Sent the SU's off to Z-therapy for a rebuild...still waiting for those to come back....
-Removed every non-critical component from the engine bay, they cleaned and painted it
-New brake master cylinder (for disc brakes) and new brake lines along with a Wilwood prop valve
-Reassembled L28 and dropped it in with new everything pretty much
-installed electronic distributor
-Redid engine bay wiring
-Made new spark plug wires
-New clutch and resurfaced flywheel
-same 4-speed transmission
-Installed MSA 6-1 header and matching 2.5" exhaust system (great fit by the way!)
-took out fuel tank and treated/coated the inside and got the exterior powder coated
-installed electric fuel pump by fuel tank (mechanical one went bye-bye)
-Removed ALL suspension from the vehicle front and rear and power washed the complete underside of the car
-installed BC Racing coilovers
-Got all suspension brackets and arms powder coated and installed new poly bushings
-Installed T3 GTX2 front control arms
-Toyota 4-piston calipers and 300zx rotors on the front
-Maxima rear calipers and 300zx rotors on the rear, with working parking brake
-All stainless braided teflon brake hoses
-New OEM rear hub bearings
-Suspension techniques swaybars front and rear
-New front hub bearings
-New tie rods and refreshed the steering rack
-New wheels, 16x8F, and 16x9R Rota Grids (yeah I know, but they will work for the time being until I find something I really like or get a custom wheel set made)
-MSA bolt-on ZG flares and all the corresponding wheel well cutting that goes with these
-installed some sparco seats
-installed sparco steering wheel
I think that is about it.....Once the carbs come back, then I can fire this thing up!
Share this post
Link to post
Lot of work getting done..... nice job....
Just a heads up what's the fuel pressure on the electric pump your using....
I dont know if you did or plan to, but You might wanna install a pressure regulator and gauge. At minimum check the pump output psi....
I've seen people (including myself) struggle to set carbs when all along the electric fuel pump was putting out to many psi....
I used a low pressure Holley 12-804 it's 1-4 psi... and you can install a gauge in the second output port.....
Share this post
Link to post
Yep, I have a plan for monitoring and regulating the fuel pressure. Thanks for the tip though!
Share this post
Link to post
Seen you doing a whole lot of work, Just wanted to make sure the start up went good....
Keep up the good work....
Share this post
Link to post
You're a good photographer, and you should know better.   ^_^
Share this post
Link to post
OK John, you talked me into it! :-) Here are some teasers
Share this post
Link to post
Consider me teased sir...   ^_^
Been thinking of doing the plug wires that way on the current 510 I'm working on. Did you start with a DIY kit? Thinking stock length isn't long enough...
Share this post
Link to post
Me too.... the plug wires do look super clean that way....
And damn that's some tire back there.....
Share this post
Link to post
I made the plug wires using an MSD "Street fire" kit. The kit came with a crimping tool.
245/45/16...because an L28 needs all that tire.... ha ha haaaa.
Share this post
Link to post
And now Summit is sending me one too. Thanks!   :thumbup:
Share this post
Link to post
Don't forget David Irwins headlight and parking light relay harnesses. Plug and play. It will save the fuse block and combo switch.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
