Stoffregen Motorsports Posted June 26, 2017 Report Posted June 26, 2017 Correct me if I'm wrong Stoffregen; but maybe he's using a trashed pitman/idler arm and using it for testing purposes? :confused: Either way, I would still make sure it fits flush. Good point about bump steer. Have you test fit the new tie rod and cycled the suspension? 2 Quote
]2eDeYe Posted June 26, 2017 Report Posted June 26, 2017 Bump steer will remain the same, as the center link moves parallel to it's previous position. It is just below the arms now instead of above them. The center link is assembly 12 in the pic. Weird that it doesn't show the idler arm assembly..... 1 Quote
]2eDeYe Posted June 26, 2017 Report Posted June 26, 2017 Yes that correct, just a spare. I measured to ensure both centerlink and outer tie rods are the same diameter. I drilled the 11/16 through the other hole which fit better than the 45/64 in the pic. Nice, 11/16 bit is easier to get. :) 2 Quote
Moist Lightning Posted June 26, 2017 Author Report Posted June 26, 2017 OK, thanks...I was wondering what was going on! Thanks for sharing your findings. I will be doing this soon. I was going to use the goforits with TJ TREs, but with my truck being as low as it is, I don't want the center link to hit the ground before the bolt-in cross member. This gives me another option. I looked into this but couldn't find a m14 female, reverse threaded, tj tre to use. Did you already find the TRE's to do this? I found a TRE with a regular thread but it would only fix one side:( Would love the part # is you did find em. 2 Quote
2wheel-lee Posted June 26, 2017 Report Posted June 26, 2017 I haven't begun my research yet, but the first place I'll start is studying this page from Moog. Note that you can sort by certain attributes, but it still requires visually scanning down the page. Though it may not be needed, if you find one you like, you can click on the part number to see the application. http://www.moog-suspension-parts.com/universal_outer_tie_rod_ends.asp These are the "universal" TREs, and the list doesn't always include ones that are model specific. So to verify the specs of a specific model TRE, I'll go to rockauto, then get the spec I need and come back here and match what I need with other features (such as for female threads). Basically I cross-reference specs in multiple locations, but the Moog site is part of my base research. The one thing I don't like is that it's not easy to find the length of the taper. Knowing small and large is good, but I also want to see length. 3 Quote
Moist Lightning Posted June 26, 2017 Author Report Posted June 26, 2017 I haven't begun my research yet, but the first place I'll start is studying this page from Moog. Note that you can sort by certain attributes, but it still requires visually scanning down the page. Though it may not be needed, if you find one you like, you can click on the part number to see the application. http://www.moog-suspension-parts.com/universal_outer_tie_rod_ends.asp These are the "universal" TREs, and the list doesn't always include ones that are model specific. So to verify the specs of a specific model TRE, I'll go to rockauto, then get the spec I need and come back here and match what I need with other features (such as for female threads). Basically I cross-reference specs in multiple locations, but the Moog site is part of my base research. The one thing I don't like is that it's not easy to find the length of the taper. Knowing small and large is good, but I also want to see length. Damn I did that already hahaha. used orileys to look at ones that moog no longer produce too. Maybe you'll find something I missed. Post back if you do please:) 1 Quote
Charlie69 Posted June 29, 2017 Report Posted June 29, 2017 Has any one thought to ask Mike Klotz if he would be willing to design and produce the tapered insert to the secifications needed to do the flip easily and most of all safely. This is great information and I suggest making this thread a sticky so it does not end up in the bowels of Ratsun. 4 Quote
]2eDeYe Posted June 29, 2017 Report Posted June 29, 2017 Not sure if it would be worth Mikes effort, when there are other solutions available. I am keeping my eyes out for and truck and a car oil pan and pickup tubes. I want to try to develop an inexpensive rear sump pan to eliminate the need to flip the center link. 3 Quote
Moist Lightning Posted July 26, 2017 Author Report Posted July 26, 2017 Has been installed with 11/16 bit. I am quite happy with the results. Unfortunately I lost some pics due to a syncing error but should have enough still. Album Link: http://imgur.com/a/rcJW9 Before installing both sides, I first installed one end and tested the range of movement - Was more than pleased with results. Bonus: I will post a few extra things if found that weren't mentioned in any other KA swaps too First thing is these fused relays (alternative to Can/Am box) Have a few more things to add but don't have pic's or install done. Edit: I installed on l16 rubber mounts and un-altered KA mounts. l20b mounts: Roughly 1.9" L16 mounts: Roughly 1.5" Still needed to hammer the edge of the firewall up a tiny bit but didn't need to cut it off. Transmission has 4 degrees of tilt with this mounting setup. Adjustable outer's in the pic are from a early AWD 720. Later models will not work. 3 Quote
Moist Lightning Posted September 25, 2017 Author Report Posted September 25, 2017 Thought I would add a quick update as I think I completed this swap on a record low budget - total cost 1140$ CAD Engine + trans + harness + driveshaft = 400$ New clutch and other parts for engine = 300$ Engine hoist = 200$ Other parts used in install (mostly fuel system, electrical and intake) = 600$ Money made from l20b partout = 360$ Total = 1140$ I have an excel with all my transaction and exact dollar amounts although numbers above are rounded. Additionally, since I haven't seen it mentioned my driveshaft uses the front half of the 240sx and the rear of a 620 shaft. Arguably needs 1" spacer although those who use a 620 shaft are already losing .6" in spline engagement. 1 Quote
GERMS Posted October 26, 2017 Report Posted October 26, 2017 What bit did you use with the dremel to to open up the insert? 1 Quote
Moist Lightning Posted October 26, 2017 Author Report Posted October 26, 2017 What bit did you use with the dremel to to open up the insert? Cutoff disc. There are 2 kinds, you need the reinforced type for metal. 1 Quote
Trod8812 Posted November 5, 2017 Report Posted November 5, 2017 Does anyone know about a bolt on kit to make a 620 into a 4x4, this link says that there was no stock 4x4 620 but there was a low manufacturing bolt on kit to make it a 4x4? Anyone know anything about it? http://www.fourwheeler.com/how-to/tech-qa/1601-nissan-and-datsun-4x4-pickup-spotters-guide/ Quote
]2eDeYe Posted November 5, 2017 Report Posted November 5, 2017 No bolt on kit that I know of. Even if Low made one, you would be hard pressed to find one these days. Quote
RJRACIN240 Posted November 14, 2017 Report Posted November 14, 2017 Where did you get the replacement grease boots, they look good Quote
Moist Lightning Posted November 14, 2017 Author Report Posted November 14, 2017 Where did you get the replacement grease boots, they look good All new tie rod ends and idler arm from rock auto. there were a few different brands, some boots were better than others. I also over greased one and it popped so I shoved a boot from a different set on. 1 Quote
WallRocket Posted December 6, 2017 Report Posted December 6, 2017 NICE I just ordered my inserts, this is the fix i was looking for! Thanks! 2 Quote
MantisX620 Posted January 27, 2018 Report Posted January 27, 2018 Am I correct to say that I get a 11/16 bit, drill through the arm holes completely, gap the inserts with a dremel cut off wheel so that they squeeze closed enough to get into the new holes and bolt it back up now flipped? Thanks MantisX 1 Quote
Moist Lightning Posted January 27, 2018 Author Report Posted January 27, 2018 Am I correct to say that I get a 11/16 bit, drill through the arm holes completely, gap the inserts with a dremel cut off wheel so that they squeeze closed enough to get into the new holes and bolt it back up now flipped? Thanks MantisX Yup, you sir are correct. 2 Quote
MantisX620 Posted January 28, 2018 Report Posted January 28, 2018 Awesome, thank you sir for doing the write up and the research! MantisX 2 Quote
MantisX620 Posted June 24, 2018 Report Posted June 24, 2018 Did you remove your arms and drill press them or did do them with a hand held drill? Thanks MantisX 1 Quote
Moist Lightning Posted June 25, 2018 Author Report Posted June 25, 2018 Did you remove your arms and drill press them or did do them with a hand held drill? Thanks MantisX By hand only because the pitman arm won't come off. I've heard of people breaking pullers trying to remove them. its a real pain. Try yours if you have a puller, maybe you'll be lucky and it'll come off. 1 Quote
MantisX620 Posted June 26, 2018 Report Posted June 26, 2018 Well you sir are a trooper. I couldn’t get my bits to cut it. I even tried slowly increasing bit sizes. So I took the arms off the truck and to a drill press. Same result. So I’ll be taking the arms to a machine shop to do it. What kind of drill bit did you use? MantisX 2 Quote
Moist Lightning Posted June 26, 2018 Author Report Posted June 26, 2018 Well you sir are a trooper. I couldn’t get my bits to cut it. I even tried slowly increasing bit sizes. So I took the arms off the truck and to a drill press. Same result. So I’ll be taking the arms to a machine shop to do it. What kind of drill bit did you use? MantisX I used a cheap princess auto bit (canadian harbor freight) Although i had to sharpen it like 10 times to get the 2 holes done. It wasn't perfect but within acceptable tolerance. Definitely a better idea to drill press. I was just being lazy since my pitman was being a c**t. 2 Quote
MantisX620 Posted July 3, 2018 Report Posted July 3, 2018 Well the guy that made the samurai swords on the side must've forged my steering arms because I cant drill them and one machine shop has said they cant do it. Im taking them to another machine shop but I had no idea that this would be the hardest thing about this swap! I even got a cobalt drill bit and it did better but ultimately gave out! 2 Quote
