Moist Lightning Posted June 15, 2017 Report Share Posted June 15, 2017 So after some research it seems all tapered inserts are made for jeep wranglers. There are three common sizes with the stock tj being the smallest.TJ Tie Rod End - bottom of stud (larger end of taper) = .62" 620 Tie Rod End - bottom of stud (larger end of taper) = .60" The Goferits used in the ka24de build are too big and will allow no pivot in the TRE.Bellow I will post instructions on how to modify teraflex inserts to fit like stock.These are the inserts As you can see there is a slit that allows for expansion. In order to make these fit you must open that slit with a dremel and slowly pinch it together in a vice being careful not to distort the shape. Below I will post a before picture: As you can see the insert goes all the way up the TRE without seating properly.this can also be seen in acehaole_620 Ka24de Forum: Here is the after shot: Here Is stock Fitment The new outer Diameter of the insert is .7" from .75" I am going to fastenal's to get a 45/64 drill bit to test these on a spare idler arm. Will update soon. 6 1 Quote Link to comment
]2eDeYe Posted June 15, 2017 Report Share Posted June 15, 2017 I can see why some guys were trimming off the head of the insert.Thanks for this :thumbup: Looking forward to results. 3 Quote Link to comment
Draker Posted June 15, 2017 Report Share Posted June 15, 2017 Just so we are clear, this is an alternate way of modifying the centerlink rather than flipping it and re-machining the tapers? You drill the taper all the way through, flip it, then sleeve it with these inserts? 2 Quote Link to comment
Moist Lightning Posted June 15, 2017 Author Report Share Posted June 15, 2017 Just so we are clear, this is an alternate way of modifying the centerlink rather than flipping it and re-machining the tapers? You drill the taper all the way through, flip it, then sleeve it with these inserts? Yes that is correct, additionally the teraflex don't require welding. The benefits of tapered inserts over tapering are cost and ease and strength (compared to a double taper). For reaming you should weld the other side shut (before re-tapering) rather than having a double taper. Reaming should also be done on a milling machine (possibly drill press) not by hand or by drill. 3 Quote Link to comment
flatcat19 Posted June 16, 2017 Report Share Posted June 16, 2017 Good info to have around here. 1 Quote Link to comment
GERMS Posted June 16, 2017 Report Share Posted June 16, 2017 Damn it! Now what am I going to do with the goferit inserts I recently bought lol If this works I'll sell them on ebay and get these. Thanks! 2 Quote Link to comment
Moist Lightning Posted June 16, 2017 Author Report Share Posted June 16, 2017 Damn it! Now what am I going to do with the goferit inserts I recently bought lol If this works I'll sell them on ebay and get these. Thanks! No probs, sorry I didn't get this up sooner for ya. Drill bit should be here wednesday. will update then. You could maybe shave the top of them a bit but it probably won't have as much play as stock still (Especially since the rod I was testing on didn't even have a rubber boot to clear). 2 Quote Link to comment
Moist Lightning Posted June 21, 2017 Author Report Share Posted June 21, 2017 Test fitment went well; will be installing on truck. Image of test fitment: Image of secured good tierod with boot. Image of test fitment after the good tierod was pressed in to expand 3 Quote Link to comment
]2eDeYe Posted June 21, 2017 Report Share Posted June 21, 2017 Excellent work. Great option, possibly the best one, definitley the cheapest :cool: I added a link to my thread on the mounts. Hope you don't mind. 2 Quote Link to comment
]2eDeYe Posted June 21, 2017 Report Share Posted June 21, 2017 Is this the insert? https://teraflex.com/shop_items/528ffa7fead962f416e73022 1 Quote Link to comment
Moist Lightning Posted June 22, 2017 Author Report Share Posted June 22, 2017 Is this the insert? https://teraflex.com/shop_items/528ffa7fead962f416e73022 That link seems to just take me to this page for some reason This is what I got: https://www.summitracing.com/int/parts/tmi-990175 Inner diameter isn't listed but the smallest outer diameter is .75" Also fully tightened it went up slightly further than stock so I will be getting a 11/16 to try as they will probably be easier for most people to source too. Will update again when I get it. Excellent work. Great option, possibly the best one, definitley the cheapest :cool: I added a link to my thread on the mounts. Hope you don't mind. Thanks, glad its helpful. No probs. Quote Link to comment
]2eDeYe Posted June 22, 2017 Report Share Posted June 22, 2017 Oops I was messing up some links last night while going back and for copy pasting. :lol: https://teraflex.com/shop_items/528ffa7fead962f416e73022 It is the same part number that I was looking at, cheaper on summit. :cool: Edit: fixed the link in my previous post. :lol: 1 Quote Link to comment
GERMS Posted June 23, 2017 Report Share Posted June 23, 2017 Which insert will you try next? Link? 1 Quote Link to comment
Moist Lightning Posted June 23, 2017 Author Report Share Posted June 23, 2017 Which insert will you try next? Link? Sorry if I wasn't specific; i'm trying a small drill bit not a different insert. Original test was .703mm(45/64) new one will be .682 mm(11/16") from my research there aren't any smaller insert to try. If you find inserts ment for anything but a jeep or chevy 1 ton let me know and i'll check em out. 1 Quote Link to comment
Stoffregen Motorsports Posted June 23, 2017 Report Share Posted June 23, 2017 I would still machine the tip of the insert so that it sits below the surface of the forging. If you were careful, you could knock it down on a belt sander. 3 Quote Link to comment
]2eDeYe Posted June 23, 2017 Report Share Posted June 23, 2017 I would still machine the tip of the insert so that it sits below the surface of the forging. If you were careful, you could knock it down on a belt sander. A washer between the nut and forging would also be a good idea. 2 Quote Link to comment
Stoffregen Motorsports Posted June 23, 2017 Report Share Posted June 23, 2017 A washer between the nut and forging would also be a good idea. That depends on the height of the cotter pin hole. If a washer will make it impossible for a cotter pin to be installed, then you shouldn't use a washer. And vice-versa. 2 Quote Link to comment
Moist Lightning Posted June 23, 2017 Author Report Share Posted June 23, 2017 I would still machine the tip of the insert so that it sits below the surface of the forging. If you were careful, you could knock it down on a belt sander. 11/16 hole had better fitment. ill post pic when i install on truck an you can see. The movement should not be reduced by the lip on the insert. Edit: I miss read the first time, I will sand down insert if needed to clear cotter pin. 2 Quote Link to comment
thisismatt Posted June 24, 2017 Report Share Posted June 24, 2017 Wouldn't you want to take it down so that the insert couldn't possibly shift the amount it's sticking out on the nut side? 3 Quote Link to comment
Moist Lightning Posted June 24, 2017 Author Report Share Posted June 24, 2017 Wouldn't you want to take it down so that the insert couldn't possibly shift the amount it's sticking out on the nut side? Probably wouldn't be a bad idea. Realistically I don't see it happening due to the pressure but ya never know. I probably will now that you mention it, just for peace of mind. 2 Quote Link to comment
Stoffregen Motorsports Posted June 24, 2017 Report Share Posted June 24, 2017 Wouldn't you want to take it down so that the insert couldn't possibly shift the amount it's sticking out on the nut side? That's what I was thinking. The cotter pin thing was secondary. 1 Quote Link to comment
2wheel-lee Posted June 26, 2017 Report Share Posted June 26, 2017 What I don't understand is why you're flipping the link at the end position of pitman and idler arms. Isn't the center link on the middle hole of those arms? If you flip the tie rods, you might be into some bump steer. And if you swap the center link position with the tie rods, your steering is going to be jacked. Test fitment went well; will be installing on truck. Image of test fitment: Image of secured good tierod with boot. Image of test fitment after the good tierod was pressed in to expand 1 Quote Link to comment
GERMS Posted June 26, 2017 Report Share Posted June 26, 2017 Correct me if I'm wrong; but maybe he's using a trashed pitman/idler arm and using it for testing purposes? :confused: Quote Link to comment
Moist Lightning Posted June 26, 2017 Author Report Share Posted June 26, 2017 What I don't understand is why you're flipping the link at the end position of pitman and idler arms. Isn't the center link on the middle hole of those arms? If you flip the tie rods, you might be into some bump steer. And if you swap the center link position with the tie rods, your steering is going to be jacked. Correct me if I'm wrong Stoffregen; but maybe he's using a trashed pitman/idler arm and using it for testing purposes? :confused: Yes that correct, just a spare. I measured to ensure both centerlink and outer tie rods are the same diameter. I drilled the 11/16 through the other hole which fit better than the 45/64 in the pic. 2 Quote Link to comment
2wheel-lee Posted June 26, 2017 Report Share Posted June 26, 2017 OK, thanks...I was wondering what was going on! Thanks for sharing your findings. I will be doing this soon. I was going to use the goforits with TJ TREs, but with my truck being as low as it is, I don't want the center link to hit the ground before the bolt-in cross member. This gives me another option. 2 Quote Link to comment
