Dawg1963 Posted June 13, 2017 Report Posted June 13, 2017 Hello, I have a 85 Nissan/Datsun 720 kingcab pickup. It has a z24 engine and 5 speed manual transmission. I recently replaced the clutch,pressure plate and bearing. The transmission is still not working correctly. It makes a loud scraping noise. My question is did I put in the right clutch kit? Even thought it's a 1983 truck the transmission tag says 12/92. Is there a difference between a 83 clutch and a 82 clutch? 1 Quote
wayno Posted June 14, 2017 Report Posted June 14, 2017 It sounds like the transmission lost a bearing. Does the scraping sound go away when you push in the clutch and put it in gear while it is running/idling? 1 Quote
Draker Posted June 14, 2017 Report Posted June 14, 2017 Seen this recently, it the input shaft bearing was toast and dropped ball bearings into the case. Sounds when clutch pedal is out.. no noise when pressing the clutch pedal down. 1 Quote
wayno Posted June 14, 2017 Report Posted June 14, 2017 Seen this recently, it the input shaft bearing was toast and dropped ball bearings into the case. Sounds when clutch pedal is out.. no noise when pressing the clutch pedal down. Why did he put it back in without fixing it? 1 Quote
Dawg1963 Posted June 14, 2017 Author Report Posted June 14, 2017 The noise is not all the time. It does stop when I push the clutch in. I've had the differential and u joints looked at, they work fine. The transmission works out of the truck. It shifts through all the gears. 1 Quote
Draker Posted June 14, 2017 Report Posted June 14, 2017 Why did he put it back in without fixing it? Different truck, but sounds like the same issue. 1 Quote
Draker Posted June 14, 2017 Report Posted June 14, 2017 The noise is not all the time. It does stop when I push the clutch in. I've had the differential and u joints looked at, they work fine. The transmission works out of the truck. It shifts through all the gears. Sounds like the input shaft bearing. 1 Quote
wayno Posted June 14, 2017 Report Posted June 14, 2017 The weak spot in them transmissions is the cluster gear bearing, if you continue to drive it/run it a single bearing can come out and get between the gears and totally waste the transmission, I had that happen to me just because I wanted to get back home(6 blocks from home), by the time I got back I had no 5th or rev gears because the cluster gear shaft got broke as I just had to get back home, if I had stopped I might have been able to replace the bearing and put it back together, but no, I had to get back home, it happened in the Safeway parking lot going 5mph when the cluster gear shaft broke, it shook the whole truck when it happened. If you push in the clutch and put it in gear and the noise stops, it's time to drop the transmission and fix it. 1 Quote
Dawg1963 Posted June 14, 2017 Author Report Posted June 14, 2017 Thanks, I will check that out. 1 Quote
datzenmike Posted June 14, 2017 Report Posted June 14, 2017 Was it making noise before? Was the clutch change to get rid of this noise? Noise that goes away when the clutch pedal is down is in the transmission. Counter shaft bearing just below the input shaft bearing is the weak point on these, as wayno said. Front cover must come off and the front case separated from the rest of the transmission but a gear puller and a hammer (plus a new bearing) should fix the problem. Should. If this bearing has failed there will be more wear elsewhere. 1 Quote
Dawg1963 Posted June 14, 2017 Author Report Posted June 14, 2017 It started making the noise. I thought it was the clutch so I replaced it. The noise is still there. Though maybe I put the clutch in wrong or maybe got the wrong part. That's why I asked if there was a difference between an 83 and 82 transmission since the transmission tag says 12/92. I will check the input shaft counter shaft bearings. 1 Quote
datzenmike Posted June 14, 2017 Report Posted June 14, 2017 12/82 is about half way into the '83 model year. I know, makes no sense, but the production year change is near June/July for Nissan. The Z22 changed into the Z24 engine around October. If you find any Z series transmission it will work as long as the length is the same but be sure to keep the release collar you have (but get a new bearing) just in case.. 1 Quote
Dawg1963 Posted June 16, 2017 Author Report Posted June 16, 2017 Well it was a bearing!! Whole transmission is toast!! Got to find another one. Anyone know if I need to stick to that year or are other years interchangeable? 1 Quote
wayno Posted June 16, 2017 Report Posted June 16, 2017 Did it ruin the front case? Just because the cluster gear bearing is toast doesn't mean the whole thing is toast, I have had the front bearing cover get busted, I just got another one and a bearing, cleaned it up, put it back together and I was good for another 5 years. I also have had the front cluster gear bearing hole get buggered up and I took it to a machine shop I know of and had them turn it out to the larger bearing. You can even just find another front case, but if you are having a shop do the repair, then it is cheaper to just find a good used transmission. 1 Quote
Stoffregen Motorsports Posted June 16, 2017 Report Posted June 16, 2017 Those transmissions are very easy to repair. The hardest part is getting it out of the truck. Find a shop that deals with older imports and have them replace the bearing. Even a full rebuild on that trans is only about $600, including parts. 2 Quote
wayno Posted June 16, 2017 Report Posted June 16, 2017 Those transmissions are very easy to repair. The hardest part is getting it out of the truck. Find a shop that deals with older imports and have them replace the bearing. Even a full rebuild on that trans is only about $600, including parts. I have found it harder to get back into the truck myself, but I am special. :lol: 3 Quote
datzenmike Posted June 16, 2017 Report Posted June 16, 2017 Any Z engine series that is the same length will work. Long 31.5 inches and short 26". Now make sure you are not being sold a 4x4 transmission as there is no speedometer drive in them. The '80-'83 S110 200sx also had the long 5 speed. 2 Quote
Dawg1963 Posted June 17, 2017 Author Report Posted June 17, 2017 Thanks. So I guess that since its a king cab I would need the 31.5"? 1 Quote
datzenmike Posted June 17, 2017 Report Posted June 17, 2017 Negative. It may or may not. Always measure. 1 Quote
Dawg1963 Posted July 22, 2017 Author Report Posted July 22, 2017 Can't seem to find a transmission close by. Think I might just sell it as is!!! 1 Quote
datzenmike Posted July 22, 2017 Report Posted July 22, 2017 The 71B 5 speed was available since '77. Millions made and with different front cases so they fit L, Z, SD, LD and CA engines. You have two possible lengths 26" and 31.5". All these below are 31.5" except possibly one from a 720 gas engine. Even if you have a shorter one you can swap a longer one in and shorten the driveshaft. All you may need to do is swap your Z series front case on. L series... '77-'79 620 truck '78-'80 810 '81-'84 Maxima '77-'78 280z '79-'83 non turbo 280zx Z series... '81-'86.5 720 gas engines '80-'83 S110 200sx '83-'86.5 S12 200sx LD series... '78-'80 810 '81-'84 Maxima SD series... '80-'86.5 720 Then there are the 71C from the D21 Hardbody that bolt right up and need only a driveshaft mod. 1 Quote
wayno Posted July 22, 2017 Report Posted July 22, 2017 There is an 83 in the Foster pick and pull(south yard) that has only been there 2 days. 1 Quote
wayno Posted July 22, 2017 Report Posted July 22, 2017 I have a longshaft 4 spd and a napZ front case if your interested, PM me. 1 Quote
DrvnDrvr Posted July 23, 2017 Report Posted July 23, 2017 Had a guy here in Bend Or rebuild mine for $510 2 Quote
