1981 720 King Cab 2WD gas motor rear brake line
I can not access the flare nut on the frame side of the rear brake line. Here's where I've been on this:
- Jacked up, on stands, rear wheels removed
- Pass. side axle bumper removed
- tubing wrench will grip but no clearance to turn from any position
- tubing crows foot will grip but no clearance for ratchet, swivel, extension of any combination or size drive
Is there some secret trick to this because it is sure looking like the options are drop the fuel tank, take out the bed bolts and jack that up or cut a window in a box end and put fire to the handle and bend up a custom wrench. If anyone has run in to this I could use some advice. Thanks
  • Replies 6
Thanks Mike. I have the FSM and for some reason never bothered to look it up there. I'm 'bout 99% convinced I can cut an inch or so off a tubing wrench and get at it. The others were still at factory torque and came off without a struggle. 36 years and 294,000 miles...... brake hoses are the last on my list of things to do before I feel comfortable driving this thing around.
