David lo pan 2 Posted June 3, 2017 Report Share Posted June 3, 2017 Hello, I have a late model 260 I found a replacement door from a early model 240. Obviously the doors are different. My question is, if it possible to separate the hinges to swap between 240 and 260. So in Other words keep 240 door hinge and add 260 body hinge. Or is it to much trouble? Anyways the door is perfect and was basically free. Thanks guys Quote Link to comment
David lo pan 2 Posted June 7, 2017 Author Report Share Posted June 7, 2017 Figured it out. Quote Link to comment
David lo pan 2 Posted June 9, 2017 Author Report Share Posted June 9, 2017 So, I have a late model 260 with the big bumpers and beefier frame rails, bulkier trans tunnel. Apparently I have the early model doors. Same as the 240's. I just removed the outer skin and swapped it out with the appropriate frame. Bam! 1 Quote Link to comment
