Sign in to follow this
BabbitMike
Thanks for the add
Hi folks. Thanks for adding me! New member to the forum and a new owner of a 1986 D21 that has been molested. I have had to replace the seats and carpet as it had been tossed due to the PO PO being a smoker and cig burns. The guy before me was in the process of converting this over to a carb from EFI and I made an adapter plate for the carb to manifold. So far it has been a major headache with "WTF did he do and why?" moments every time I turn around. Right now the only thing that is holding me up from being able to drive this thing is the distributor. The ECM controlled distributor was removed and went to the same place as the seats along with the ECM. It was replaced with an electronic distributor with a vacuum advance. The problem in the distributor is that the control module in it is bad and a bit on the spendy side which is making me consider just dropping a 302 Ford or 350 Chevy it it. This has the Z24 engine in it and I would like to just bypass all of the electronics in it and just go with a points and condenser or perhaps an electronic upgrade that will fit this distributor. I am a 30 year experienced machinist so if I could even come up with a 4 cyl point distributor I could do what machining I would need to to make this work. Any and all suggestions will be appreciated.
 Thanks again for the add!
      Mike
Share this post
Link to post
ttt
Share this post
Link to post
1978 620 came with an HEI style distributor that you could use an off-the-shelf HEI module from a GM vehicle.
Share this post
Link to post
Welcome! I used the module from a 78 Camaro. Get the best quality one you can and make sure the back of the module is well grounded and on something that doesn't get too hot.
Share this post
Link to post
I finally get her up and running with an '81 Datsun distributor. I was also able to scavenge a couple more control modules and 2 new pickup yokes. The carb I think is a bit weak knee'd though. It's a 5200 series Holley that supposedly came off of a '79 Omni. As far as I can tell the Omni was a 1.7L and this being a Z24 I think that the jets are too small to be able to supply enough fuel. She starts and runs nice in neutral and will motivate along but falls flat on her face when you try to pick up some speed. The Holley is supposed to be around 250 to 280 CFM and I am eyeballing a Motorcraft 2150 that I already have rebuilt and sitting on a shelf which will be running about 350 CFM.
 Hey datzenmike, I love your Heisenberg sig.
Share this post
Link to post
That /\ Holley was also on the pinto, capris and other cars back in the day. Very similar to 32/36 weber. I even think they partnered together
Share this post
Link to post
Only takes Holly jets.
Share this post
Link to post
B-b-b-benny and the jetssa
Share this post
Link to post
I finally got the carb issues all straightened out and will go to the dmv this Monday and get it registered. The jets are what is called for on a 2.3l Pinto motor. Since all the wiring has been nackered I don't have any working tach, oil pressure or temp gauges that work. I have a couple of sets of after market gauges that I will put on and a junk yard speedo when I can get out there until then I will rely on my Magellan to get my speed.
Share this post
Link to post
Hi newb, if you can find a decent hosting site, post oics!
Share this post
Link to post
      Mike
Share this post
Link to post
What hosting sites are the best and free? Photobucket is out.
Share this post
Link to post
Thanks Mike! I think I got it going now. I've been able to drive my 86 for a couple of months and I love this little truck! I need to come up with a core transmission and transfer case and rebuild them so I can just R&R the pair. I am finding out that there must have been some issues with the input shaft bearings going bad and making some nasty racket. At 1st it sounded like a throw out bearing but there is a different sound for each gear and 5th sounding terrible. So far I have 750 miles on it and other than the trans I am happy with it. I replaced the exhaust and eliminated all of the leaks. I think it was on this forum that there was a lengthy post covering eliminating the EFI and carbing it. I made a couple of mods myself to be able to control the fuel flow on the return line and I have not noticed any stumbling or flat spots in the throttle response. Anyway, here's some pictures of the truck and the carb setup. I also added an aluminum toolbox to the bed after these pics were taken.
   Mike
https://imgur.com/a/ugMO4
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
