Temperature sensor
  • Replies 1
Several things can be wrong. The sender is located on the front of the thermostat housing. It will have a Yellow/White stripe wire to it.
Is the wire connected?
Is the wire and the sender clean snug and making good connection?
If yes ground the wire to the thermostat housing and turn the key to ON. What you should see is the gauge move to full HOT.
If it reads HOT then the gauge and the wire to it are alright and the sender would seem to be the problem. The Nissan part number is 25080-89900. Or try NAPA
If no change the problem is the wire or the gauge or somewhere between.
