520 Gas tank 1966 - 1968
Droski
  • Replies 9
Does the tube/fuel line, on the inside of the tank, for the vapor separator line go all the way to the bottom like the supply line? That would be great for not agitating the fuel when the tank gets low. Not a good thing for fuel injection.
I don't believe any of the tubes except the pick up tube go to the bottom of the tank.
You can always add whatever you want to your original gas tank hogie....
I bought one of these as a pick up tube to change my 1/4 pickup to a 3/8 pickup tube... it's an npt fitting and you cut the tube to whatever length you want... radiator shop did it for me... not sure if they have different sizes or not, never looked beyond what I needed...
Screenshot_20170524-064626_zpsivccmwgu.p
