Sign in to follow this
LawrenceL
Flex Plate Needed
I'm a newby to this site, and really could used some help.
I need a good flex plate for a '71 510 wagon with a Borg-Warner transmission, and have posted a wanted ad with no results.
Rod's Datsun parts still has none, and this is all that's keeping a new motor from being installed and enjoyed.
If anyone has a tip or a source to persue, any help would be appreciated very much.
Thank you            = )
Share this post
Link to post
Have you tried Rockauto?
Share this post
Link to post
If it's just the starter ring you can buy them separate and have it welded on.
Share this post
Link to post
If you can not source one I have in the past carefully removed the starter ring gear and flipped it and welded it back on the center.
Share this post
Link to post
The last [and only] time I bought a starter ring gear, [for my RL411 BYW] I found that the ring gear and  flex plate assembly came pre-balanced and was far less expensive than the ring gear alone.  No spot welding and then find a sober balance technician! Check your would be suppliers!  RockAuto was the real source.
Share this post
Link to post
Have you asked busta? He's literally your neighbor.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
