1972 510 Build VG30ET Swap
  • Replies 68
Used some emery to smooth out the lip and damaged area.  The rod/cap and the rod bearings seems tight.  The pics below might describe it better.  Tight around the bearings, with a small gap on the face where the rod cap and rod meet.  I have an e mail out to clegg to see if they have a hook up on single press fit rod, the ones I bought were refurbished and not a complete set (1,2,3,4,5,6) so I am hoping they have single refurbished rods.  Although if usable I would prefer to not go that route.  The bearing is static against the rod, and the dynamic surface will be rod bearings to crank which is a smooth surface.  Will the rounded cap rod faces make throwing a rod bearings inevitable?
EDIT:  I think the rod/piston and cylinder wall are ok.  I ran a hone through the #1 Cylinder and cleaned up the Rod.  Everything looks like it is OK.
So.... There were a lot of parts with this 510/VG.  I found 1x press fit rod/piston/cap hiding in a box.  What I cant figure out is if the Press Fit Rod/Cap I found could be used in place of the damaged one.  Can I swap the Piston over to the undamaged rod, and use it in place of the damaged one?  The parts are all stamped, but I cannot figure out what the markings mean.
Damage Refurbished Rod stamped with
901-1 16E-2
Random Garage Box Press fit Rod with Cap
25-1 02P
Extra 6x Press fit Rods without caps (could machine to mate cap with rod, right?  At that point could I just order new larger bearings?)
24-1 02P
Is everyone else having issues seeing the pictures?  They were embedded in my last 3 posts, and I can see them fine.
Friend took a look at the rod/cylinder and thinks its OK.  The face that the bearing presses against is unaffected (only on the outside face, where the bearing does not touch), and the rod opening size is unaffected.  I will still measure all of the openings and Plastigage the rod/crank to be sure.
Cylinder wall honed and is good.  There are still the vertical (see pic??) scores, but the wall is not scored.  Running a fingernail across it you would never know.
Again... I can see my pics.  If no one else can let me know.
  • 2 months later...
Back at it!  Had some issues with rings, but Hastings is great and got me all sorted out.  My goal is to be mocking the VG up in the dime by November!
Block, pistons, heads, water and oil pump are in.
I've been trying to find a clear drawing of coolant plumbing for the VG30ET (help?).  I am removing my heater and want to know what that does to plumbing.  Does coolant need to circulate from lower outlet just above the water pump, to the back of the block (below intake) and into the back of the intake.  See below, the piping with the 90 deg angle, does that connect to the outlet on the block just above the water pump?
  • 1 month later...
Hey ALL!  Almost done with the new motor mounts and test fitted the VG last week.  Everything looks like it should bolt right up to where the last owner had the engine/transmission.  Also got the VIN verified so I can register the car.
IF ANYONE KNOWS WHERE TO FIND A VG30ET MANUAL WIRE HARNESS I COULD USE THE HELP!
The next big step is wiring the engine and rather thank working through the frakenharness I have, I would prefer more of a plug and play option.  Anyone with a harness for sale, or if you know a work around to make a NA harness work, please let me know.
Thanks Lockleaf!  Love the Roadster.  Ok, Ill look at 280 harnesses.  I also found a site that looks like they have a 300zx harness for less than $200, however price is so much lower than others I have seen I am suspicious.
So before I mount the engine I want to figure out my water/cooling system.  There are 3 holes in the block and 1 on the intake, and I am not sure what any of them are for.  Eliminating heater, has simplified my coolant somewhat, but I still need to plug holes and plumb the turbo cooling lines.  Here are some pics of what I am trying to figure out.  Can all of the holes on the block be plugged, where does the turbo coolant stock come from?
Intake Opening, needs sealed our routed somewhere.
img%5D
Driver Side (Thinking this hole gets plugged, there is no room for anything else with the mounts I have)
img%5D
Passenger Side (This one I am not so sure of)
img%5D
Same
img%5D
  • 1 month later...
  • 2 months later...
Hey Forum.
Thank you guys for the response.  I think people have lost interest since Ive slowed my posts.  A cold winter killed my motivation.....
Getting started in the next few weeks, thank you for the link nl320what.  I figured out how to route my coolant through the throttle body and then the turbo.
Here is a pic from ~ December when we mocked up the mounts. Should be trying to bolt eh engine in the next month or two.
I don't know if you know this yet but the truck intake breathes better. Car intake looks better but yeah.
Somewhat tempted to do this myself but neither time nor resources and already kinda planning a vg30 620. Been seeing the vg used more as a swap recently though
