Datsun 521 L20B
Hey guys,
Been lurking for quite some time, gathering lots of information and would like to give back.
Hope you enjoy the journey and encourage your opinion and expertise!
This was a sad day, the truck was involved in a hit n' run
This is the beginning
L20B donor
If anyone needs 620 parts, I don't have much use for anything besides the motor
Is there anything from a 76' that might be an upgrade for the 521?
Did an indepth clean
Test fitting some rallys
Front fender pulled to the best of my ability
  • Replies 114
This stabilizing bar mount was way beyond limits
Mount cut, front end prepped
Tank removal
Entire frame prepped and POR-15
Front end donor
Lots of rust, heat and smoke
Spray foam and plastic bottles
If anyone needs anything from a the J13 let me know
Lots of patches later..
  • Like 5
Ouch
Mock-up , really happy with the fitment
Rims, gas tanks metal etched
POR-15 applied, etching primer applied
L20B prep
Valve adjustment
Oil pan and pick-up swap / engine mounts
Blasted and pre-polish
  • Like 3
Weber 32/36 disassembly
Sneak peak
Had a work trip and met up with a veteran around here, datzenmike whom is a wealth of knowledge and gave me the ultimate tour of the island countryside in his 710. Thank you again
Much more to come!
  • Like 5
You're the man wayno! Yup side block vent and it is an L20B. Never ever seen this before. Has the L16/18 cast iron header on it too. Must be a very early L20B casting. Has the water warmed/cooled intake also. It's a real odd duck.
  • Like 3
I do have one question perhaps someone may be able to help me with. I have a spare 280z 5-speed I am contemplating throwing in, I have done alot of research but am a little unclear on the driveshaft options I have. Am I able to frankenstein parts of the driveshaft off a 620 and 521 to make it work or is cutting and welding the only option besides a custom one?
