datsun 510 front suspension
  • Replies 10
What about the springs???? zx won't fit. 510 will need cutting and the lower spring perches swapped. Then expensive coil overs or split collars for adjustability. Might even need camber plates and don't forget bump steer spacers. Mind you this can all be done for about $30 with a few wrenches an angle grinder and a pair of split collars yourself.
Before you ship it off to be worked on you better research what's really involved in this and know more about it or they'll take you for a long long, long long long.... long long, ride.
  • Like 4
