Jalj47 Posted April 1, 2017 Report Share Posted April 1, 2017 I have a 73 620 with a L16, I think my diff is giving out, I have a differential too a 93 hardbody. Will that work if it? Quote Link to comment
wayno Posted April 1, 2017 Report Share Posted April 1, 2017 Probably not unless it is an H190 in the hardbody. There is also the rear gearing to consider, the 1973 likely had either 437 gears, or maybe 411 gears, the hardbody could have anything in it. What makes you think your differential is giving out, noise, clunking, knocking, a whine? Quote Link to comment
datzenmike Posted April 1, 2017 Report Share Posted April 1, 2017 If 2wd and a 4 cylinder, probably it's an H-190 but the gearing, like wayno says, will be terrible. Could be the U joint (vibration and or high pitched squeal, sometimes it lets out a loud ping sound like someone tapping the driveshaft with a hammer) in the driveshaft or an axle bearing which growls or groans, sometimes on turns.. Is the front of the diff wet? The seal is gone. Take the plug half way up the back of the diff and check the oil. You should be able to dip your little finger in the oil, which should be level with the hole. If low fill it up. If dry the diff is probably toast. 1 Quote Link to comment
Jalj47 Posted April 1, 2017 Author Report Share Posted April 1, 2017 If 2wd and a 4 cylinder, probably it's an H-190 but the gearing, like wayno says, will be terrible. Could be the U joint (vibration and or high pitched squeal, sometimes it lets out a loud ping sound like someone tapping the driveshaft with a hammer) in the driveshaft or an axle bearing which growls or groans, sometimes on turns.. Is the front of the diff wet? The seal is gone. Take the plug half way up the back of the diff and check the oil. You should be able to dip your little finger in the oil, which should be level with the hole. If low fill it up. If dry the diff is probably toast. Well I just hear a metal clanking noise coming from the rear end, when I'm in 4th gear everything starts to shake or rumble. When I'm at a stop it's normal and when I drive it makes that noise again. What can that be Quote Link to comment
willz Posted April 1, 2017 Report Share Posted April 1, 2017 Sounds like something's loose. Check the center bearing, maybe poorly balanced wheels? If it was the diff, you'd hear it in more gears than just 4th 1 Quote Link to comment
datzenmike Posted April 1, 2017 Report Share Posted April 1, 2017 Well I just hear a metal clanking noise coming from the rear end, when I'm in 4th gear everything starts to shake or rumble. When I'm at a stop it's normal and when I drive it makes that noise again. What can that be A dry U joint will bind and make a ping or clang sound usually on take offs. Sounds like a hammer tap on the hollow drive shaft. If shaking this would indicate worn U joint also as it allows the spinning mass of the drive shaft to shift off center. This will cause much vibration. You have 3 U joints and a carrier bearing. The carrier bearing seldom goes bad but the rubber surrounding 'doughnut' does rot away and the unsupported driveshaft will flop around. This thing... You have a two piece driveshaft. The rubber isolator is at the back of the front driveshaft. Quote Link to comment
banzai510(hainz) Posted April 1, 2017 Report Share Posted April 1, 2017 my bolts always fall out. ck that first. add oil 1 Quote Link to comment
Scgreen620 Posted April 2, 2017 Report Share Posted April 2, 2017 Sounds like either tires not balanced .. Or u joints .. What every one else is saying lol Quote Link to comment
Jersey Posted April 3, 2017 Report Share Posted April 3, 2017 A dry U joint will bind and make a ping or clang sound usually on take offs. Sounds like a hammer tap on the hollow drive shaft. If shaking this would indicate worn U joint also as it allows the spinning mass of the drive shaft to shift off center. This will cause much vibration. You have 3 U joints and a carrier bearing. The carrier bearing seldom goes bad but the rubber surrounding 'doughnut' does rot away and the unsupported driveshaft will flop around. This thing... You have a two piece driveshaft. The rubber isolator is at the back of the front driveshaft. I've had that ping sound on take off and it's been the u joint(s)...The last time it happened I noticed the zerk had fallen out of the center u joint and it had a lot of play. I replaced the u joints and the one missing the zerk was missing All of the needle bearings in the cup. I was surprised I didn't drop the driveshaft... 1 Quote Link to comment
Jersey Posted April 3, 2017 Report Share Posted April 3, 2017 my bolts always fall out. ck that first. add oil A girlfriend of mine back in the '80s had the bolts on her Chevy Luv fall out. Quote Link to comment
banzai510(hainz) Posted April 3, 2017 Report Share Posted April 3, 2017 I did a motor was with pulling the trans once and I th9nk it was slightly loose from that many years ago. first was the front bolts then just lasdt year the rear 2 fell out . then notice my truck shaking. jack up and moved stuff around and VISUALLY ck also. then bam 2 bolts out another loose Quote Link to comment
Scgreen620 Posted April 3, 2017 Report Share Posted April 3, 2017 Don't forget to use thread lock it has helped me mine kept falling off ... The nuts .. The truck nuts I should say ... I had to replace my whole drive shaft because the ujoints kept breaking causing wear ... Quote Link to comment
wayno Posted April 4, 2017 Report Share Posted April 4, 2017 A girlfriend of mine back in the '80s had the bolts on her Chevy Luv fall out. Flatcat's sister drove her 521 till the rear drive line fell on the ground, it got towed home and I went over and fixed it, where the U-joint cap is supposed to be in the flange was a giant hole that finally was so big the U-joint finally just fell out, I asked her if it vibrated any and she said yea, but she just kept driving it till it fell out, she didn't break it from dumping the clutch, it just got so bad it fell out. :rofl: 1 Quote Link to comment
Jersey Posted April 4, 2017 Report Share Posted April 4, 2017 Flatcat's sister drove her 521 till the rear drive line fell on the ground, it got towed home and I went over and fixed it, where the U-joint cap is supposed to be in the flange was a giant hole that finally was so big the U-joint finally just fell out, I asked her if it vibrated any and she said yea, but she just kept driving it till it fell out, she didn't break it from dumping the clutch, it just got so bad it fell out. :rofl:That's too funny! I get this call from the Carl's Jr. pay phone (remember those....?) "Hey babe the truck won't go..." Luckily I didn't need a tow truck. I fixed it there in the parking lot. I asked if it was making any noise and I got a yes answer. At least she was honest with me! I had another girlfriend that tore my torsion bar anchor completely off the bolt. I get in to drive it and notice right away. I ask her about it and she denied doing it...I said you're the only one that drives it besides me and I know I didn't do it. She still denied it: She never drove another one of my vehicles after that. And soon she was history. Quote Link to comment
G-Duax Posted April 4, 2017 Report Share Posted April 4, 2017 my bolts always fall out. Mine loosen all the time, probably the way I hammer the thing on a daily basis. Going to talk to ARP to see what they might have in that size range, before my 'L16' goes in, as it will surly put the hurt on them. Quote Link to comment
distributorguy Posted April 4, 2017 Report Share Posted April 4, 2017 I brought my driveshaft in to get balanced for the race truck after installing new U-joints. I got royally chewed out because 2 of the cups were not a press fit into the yokes. Those yokes got replaced, and the shaft got balanced. $$$ Safety first? If they're loosening up on you, I'd spend the $300 and get it fixed for real, so its no longer a hazard for you or the idiot tailgating you. Quote Link to comment
