willz Posted March 19, 2017 Report Share Posted March 19, 2017 Previous owner hacked the ignition switch and harness off and threw some cheap universal switch in. Now there's only 4 wires instead of what I would assume would have been 5? It's a 6 plug with 5 pins. Did he wire it correctly? I'll be mating this to the dzstart harness and want to make sure I know exactly what wire is what. Quote Link to comment
datzenmike Posted March 19, 2017 Report Share Posted March 19, 2017 No way to know as that isn't a Nissan plug. Might as well be for a Ford. What I can tell you is where the '78 wires should go. Large thicker White wire..... main power wire from the fusible link to ACCY, ON and START Black/Yellow........................ sends a start signal to the starter solenoid when ignition is in the START position Black/White......................... powers the ignition coil + terminal, also ignition relay, transistor ignition in the ON and START ignition positions Blue..................................... goes to the transistor ignition and to the coil negative terminal in ACCY and ON positions. Quote Link to comment
HOGIE Posted March 19, 2017 Report Share Posted March 19, 2017 That's not a factory switch. The factory switch would've had 5 spade prongs. The factory harness would've been a 2X3 female connector with just 5 hole occupied by wires Quote Link to comment
willz Posted March 19, 2017 Author Report Share Posted March 19, 2017 That's what I'm saying, they nixed the whole harness and wired in some crap switch that doesn't fit. I'm trying to figure out how to hook it up to datsundaves push button kit. Quote Link to comment
willz Posted March 19, 2017 Author Report Share Posted March 19, 2017 From skib Black fused - 12v Yellow - Starter White - Ignition Blue - Accessory power The green wire is for use with points ignition to keep any feedback IIRC. Quote Link to comment
willz Posted March 19, 2017 Author Report Share Posted March 19, 2017 That's the dzstart harness^^ Quote Link to comment
datzenmike Posted March 19, 2017 Report Share Posted March 19, 2017 You have a '78...... Electronic ignition ... no Green points wire. Only four wires used Quote Link to comment
willz Posted March 19, 2017 Author Report Share Posted March 19, 2017 So from the factory harness to the DZ White - Black Blk/yellow - Yellow Blk/white - White Blue - Blue Would this be correct? Quote Link to comment
Doctor510 Posted March 19, 2017 Report Share Posted March 19, 2017 Previous owner hacked the ignition switch and harness off and threw some cheap universal switch in. Now there's only 4 wires instead of what I would assume would have been 5? It's a 6 plug with 5 pins. Did he wire it correctly? I'll be mating this to the dzstart harness and want to make sure I know exactly what wire is what. After market switch, looks to be wired correctly Quote Link to comment
Apollo77 Posted April 10, 2018 Report Share Posted April 10, 2018 Hey datzenmike, I have a 5wire ignition. I want to wire in two switches one for ignition and one for the starter. What I can't seem to get an answer for is what I do with the resistor wire Quote Link to comment
datzenmike Posted April 10, 2018 Report Share Posted April 10, 2018 You'll need a third switch. Although it will likely start without it, the supply of 12 volts directly to the coil increases the spark voltage during starts. You can't run 12 volts continuously or the coil will over heat and points will arc and burn out in 50-100 miles. Ignition goes to the ballast resistor. Start goes to the starter solenoid. 3rd switch goes around the ballast directly to the coil positive terminal. Turn on when starting the engine and turn off when engine starts. If you use a double pole single throw switch with one to the starter and the other to the coil. That would work. It's just plain easier to use a proper ignition switch. One to the starter and one to the coil Quote Link to comment
