Sign in to follow this
datO)))
A12 blow through turbo
I have searched and searched for information on how to modify a stock a 12 carburetor to except blow through turbo. There's a lot of information that is all very similar but when it gets down to specific modifications to carb , it is vague .
Is there a detailed thread regarding blow through turbos on A motors ?
Specifically modifications to carbs including parts part numbers ?
Do you have to modify a carb if you build a full enclosure around it ?
Do you have to modify the carb if you use a top hat ?
The turbo I'm using is off of a 650 Yamaha seca bike.
Share this post
Link to post
Did you post this question on Datsun1200.com?
Share this post
Link to post
I guess I'm just gonna try boxing the whole thing in it makes the most sense
to pressurize everything as one and just monitor the tune.
Where just hope I don't lean it out and fry the thing
Share this post
Link to post
You may have already looked into the basics, this:https://www.youtube.com/watch?v=q4h69sTB2Dk
is an example of what you are looking for only a bit larger engine, a 280Z, but has good explanation of the components used and why. Perhaps this  may help??
Share this post
Link to post
Wow that guy really doesn't understand why a pop valve is needed at all. All of his electronics are not even secure...... HALF ASS.
Share this post
Link to post
If you box and pressurize the whole carb, you'll still need to increase fuel pressure proportionately to boost.
Share this post
Link to post
Yes . A couple buds of mine and I tossed some ideas around and that was brought up
For more investigation.
Share this post
Link to post
I did see this video and it too was vague. In areas.
Share this post
Link to post
Here is a video about how to turbo a CVK carb on a motorcycle. Same info applies to what you would like to do. If you log into Youtube you can PM the video author.
Share this post
Link to post
https://www.youtube.com/watch?v=EuqyoDsVIGo
Ok I'll check it out.
It's gonna be a challenge but I'm up for the learning process
Share this post
Link to post
All that info just to do a new motor now.
Datsun's are a sickness.
R16 to build now.
Share this post
Link to post
It leaks oil, gutless, . It's left me stranded a few times now. I'm going build the R16
To drop in. Then build the A12 up as a spare or to sell . When
I bought the wagon, it had issues. Fixing my DD is tapping out my wallet
And it's hard to buy anything anymore for the wagon knowing that a
It was a hack job. Haven't taken apart the A12 so it's always a gamble.
That was a bit winded lol but that's just proof of my stress with having a hobby
Like this .
Share this post
Link to post
Swapping out the A might give me a chance to build it and set the turbo up
And answer some questions we all may have .
Just a bit of positivity.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
