stevenzak Posted March 9, 2017 Report Share Posted March 9, 2017 Bolt Pattern: 4x100, 4x114.3 Manufacturer Part Number: MST-01-5816-0-BLK Hub Bore: 73.1 Rim Material: Alloy Rim Structure: One Piece Rim Width: 8 Quantity: 4 Rim Diameter: 15 Rim Brand: MST WHEELS Offset: 0 Hello was wondering if this will fit my 1977 Datsun 280z, stock height, spring, shocks, and stock fender. Goal: if possiblestock height stock fender Front Tires: 205/55R/15 Rear Tires: P215/60R/15 Thanks in advance for info and opinions Quote Link to comment
banzai510(hainz) Posted March 9, 2017 Report Share Posted March 9, 2017 I had some panapsorts that where 15x7 and came off a 810. I think they should fit perfect. I had some enkies on a 77 280 and thery were 0 also I think and fit perfect. I had 205/50 and 225/50 in back and filled up wheelwhell good. car was lowered abit also Quote Link to comment
stevenzak Posted March 9, 2017 Author Report Share Posted March 9, 2017 I currently have Nissan 280zx 1983 Original Alloy wheels on the 280z 15x6.5 Offset 0 front and Rear Tires: 205 60 15 Front 215 60 15 Rear Front currently has 1.5" clearance at max turning, from front strut to tire/rim, with 280zx wheels. I am thinking a 1.5", .75" width on each side (15x8), increase wont be too much of a problem with the 205/55r/15. or should I aim for 205/50/15 on front? I prefer not to use spacers but, I might have too. Looks like more than enough clearance on the rear. Also will the 3" lip be a problem? Sorry first time doing wheel fitment. Quote Link to comment
banzai510(hainz) Posted March 9, 2017 Report Share Posted March 9, 2017 Have to ask a Z guy. I sold that Z car. I think youll be fine Quote Link to comment
stevenzak Posted March 10, 2017 Author Report Share Posted March 10, 2017 thanks for the help I am now 99% sure it will fit with no problems. I will try out what you suggested for the rear. 15x8 0 offset 3" Lip Front Tires: 205/55R/15 Rear Tires: 225/50R/15 Quote Link to comment
