Sign in to follow this
Rudde120086
1972 datsun 1200 KA24DE SWAP
Hey guys I have a 1972 datsun 1200 and I have plans on doing a ka24de swap. They don't make kits or motor mounts for a datsun 1200. They make kits for the 510s and trucks so I was wondering if anyone on the forum has done this swap, please help thanks
Share this post
Link to post
Yes, its been done. Buy a welder and start welding. No kits, not a honda.
Share this post
Link to post
So go read the answer in the identical thread you started.
Share this post
Link to post
I've been working on a KA24E swap into a 1200 on and off for a few years now. If I had to do it again I wouldn't.
5457C1A8-34A4-4000-9129-BB159C9C7767_zps
Share this post
Link to post
oh ok,was it that bad, what crossmember did you
Share this post
Link to post
They (Datsun1200.com) have done l-series swaps on 1200's, which have the same motor mounts as K ans SR. I think you need a Ute member to start off with and from there is cutting the tunnle and making a tranny mount. From there self explanatory same as every other swap. probably really hard to fit
Share this post
Link to post
On my 1200 sedan project I was looking at swapping in an A10 crossmember. Honestly, It looks pretty straightforward.
My plan:
Redrill the LCA holes in the crossmember to match what the 1200 wants.
Redrill the frame mounting holes in the crossmember to line up with the 1200 frame holes.
Trim off any excess from the outside edges of the crossmember.
Bolt into car.
If you can find an A10 donor in the junkyard, you could also use the LCAs, TC rods, etc for later swapping in 280ZX struts/brakes.
Share this post
Link to post
Also, there are places that makes swap kits for 1200s, they just aren't in the US.  ;)
In Australia these cars are just as popular as 510s, if not more so. They know what's up.   B)
I have this crossmember in my car now, and a KA24 should be a straight bolt-in using this.
http://www.maddat.com.au/fitting-kits/1200-b110/sr20-datsun-1200-engine-fitting-kit
  • Like 3
Share this post
Link to post
 So pretty. Then I look at the price  :o
Share this post
Link to post
Yeah, I just bought the crossmember and urethane mounts. Everything else I made myself.  ^_^
FYI, with the current exchange rate that's $910 US. If you want it, but aren't in a huge rush, I suggest keeping an eye on the exchange rates. They can fluctuate a lot.
I bought my parts from Maddat at a time when it was around 2-1, so the whole kit would've only been about $600.
I watch the yen weekly because when it's down is the only time I order stuff from Japan.   :rofl:
Share this post
Link to post
Also if your car was originally a 5spd you will need to cut tranny tunnel... automatic tunnels require no work
Share this post
Link to post
The 1200 didn't come with a 5 speed in fact even the later B-210 didn't have one until April '76.
Share this post
Link to post
I've thought about swapping my 1200 but the A series is just such a cute little motor.
  • Like 4
Share this post
Link to post
In some markets it did.   ^_^
But he was using the term "5 speed" generically to mean a manual transmission.  ;)
Share this post
Link to post
Yes it is.  :wub:
1901830_10152049363682983_1717531969_n.j
  • Like 4
Share this post
Link to post
Cute?.....ppppfffftttt. That right there is sexy.  If it were mine, I don't know if i would drive it or take it out back and have my way with it B).
  • Like 3
Share this post
Link to post
I did the full swap 3 years ago.
Custom fabbed everything. It's a lot of work. You have to be creative to get it done but it's worth it.
'73 2 Door Sedan
KA24DR, Twin Weber 38/38 Sync.
Crower Stage 2 Cams / Supertech SS Valves
Forge Arias Pistons/ Eagle Rods
Eaton M62 SC 12 lbs. Boost / 175hp Progressive Nitrous
GM 2 Speed Poweglide/Transbrake 3500 Stall
Narrowed Ford 8.8 Posi 4.30 gears
Share this post
Link to post
This needs more engine bay photos.^^^^^
Share this post
Link to post
Here's a picture under the hood and the car. Any questions just ask.
  • Like 6
Share this post
Link to post
nice set up
just curious why the carbed draw through turbo rather than fuel injected turbo
video sounded great
Share this post
Link to post
It's a draw through supercharger. I'm not a real big turbo fan.
The distributor is an MSD Chevy V8 using every other contact. It was fabbed by using the shaft of the stock KA and the upper half of the MSD.
Ran a 11.49 last week at Pacific Raceway in Kent, WA.
200hp shot of nitrous on top of 10 1bs of boost.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
