Jayroc Posted June 12, 2017 Author Report Share Posted June 12, 2017 Ah you want measurements. I though you wanted a cut out. I can get you measurements for sure. I'll be in the shop this week 1 Quote Link to comment
sebpv Posted June 12, 2017 Report Share Posted June 12, 2017 the sooner the better :) Thanks for your help! 1 Quote Link to comment
Jayroc Posted June 23, 2017 Author Report Share Posted June 23, 2017 Little more cutting and the start of some patches. This one still needs some work to make it fit. 1 Quote Link to comment
sebpv Posted June 23, 2017 Report Share Posted June 23, 2017 did you drill the spot welds under the exterior lip? Then all you'll have to do is re-spot weld 1 Quote Link to comment
Jayroc Posted June 23, 2017 Author Report Share Posted June 23, 2017 Todays progress. Was fighting with the welder all day. Kept burning though the cab. Ended up just doing a shit ton of tacs. With lots of grinding. 1 Quote Link to comment
Jayroc Posted June 23, 2017 Author Report Share Posted June 23, 2017 Sebpv, drill/grind the last of the old floor spot welds. It was in good shape for the most part. Had to make new lips by the tunnel and cab corner. How did those measurements work out for you? 1 Quote Link to comment
sebpv Posted June 23, 2017 Report Share Posted June 23, 2017 computed the findings. I messaged you as well. 1 Quote Link to comment
sebpv Posted June 23, 2017 Report Share Posted June 23, 2017 By any means, if those dimensions do not reflect my drawing or you measured them a specific way lemme know! :) thanks 1 Quote Link to comment
Jayroc Posted June 23, 2017 Author Report Share Posted June 23, 2017 Looks good to me. 1 Quote Link to comment
sebpv Posted June 23, 2017 Report Share Posted June 23, 2017 Thx Jayroc! I forwarded everything to a friend who will turn it on a lathe 1 Quote Link to comment
Jayroc Posted June 25, 2017 Author Report Share Posted June 25, 2017 Turing them out on a lathe. A little much I think. Though you were going something like a dimple die. Let me know how they turn out though. Quote Link to comment
Lockleaf Posted June 25, 2017 Report Share Posted June 25, 2017 I think he means turning the dies out 2 Quote Link to comment
Jayroc Posted June 25, 2017 Author Report Share Posted June 25, 2017 That makes more sense. 1 Quote Link to comment
Jayroc Posted June 30, 2017 Author Report Share Posted June 30, 2017 Drivers side floor pan is in. Lots of tacs. Need to clean up the tunnel area some more Quote Link to comment
Jayroc Posted March 1, 2018 Author Report Share Posted March 1, 2018 So weather is finally warming up so I need to get back into the shop and finish this. Got my carpet, windshield, and new door seals ordered and should be here by Friday 1 Quote Link to comment
sebpv Posted March 1, 2018 Report Share Posted March 1, 2018 We cant see your pictures anymore :/. And Im on my phone, so no photobucket fix for me... 1 Quote Link to comment
Jayroc Posted March 1, 2018 Author Report Share Posted March 1, 2018 Ya no pictures for me either. Need to change them over from Photobucket 1 Quote Link to comment
sebpv Posted March 1, 2018 Report Share Posted March 1, 2018 go on imgur. easier than photobucket 1 Quote Link to comment
Jayroc Posted June 12, 2018 Author Report Share Posted June 12, 2018 (edited) Back from dead. Just doing some body work and preping for my windshield . Edited July 25, 2018 by Jayroc Quote Link to comment
Jayroc Posted July 25, 2018 Author Report Share Posted July 25, 2018 No real big progress. Went to adjust my hood to help line up the fenders. Turrned into me strtipping the hood to bare metal and blocking it out. 2 Quote Link to comment
Charlie69 Posted July 26, 2018 Report Share Posted July 26, 2018 (edited) On 2/26/2017 at 5:49 PM, Jayroc said: So the weber I have never came with the throttle bracket. Didn't feel like paying 50$, shipping to Canada it's stupid. Made this one today, need to move the mount over to the left. It doesn't line up quite right. It's a little heavy duty but it's what I had in the shop. Tuned up the weber and had it running with the new setup. It's just off the header so it's a little loud. https://youtu.be/oRENHUaKSBY For the carb linkage on the throttle shaft use the one from the stock carb on your Weber. Edited July 26, 2018 by Charlie69 Quote Link to comment
Jayroc Posted July 27, 2018 Author Report Share Posted July 27, 2018 On 7/26/2018 at 12:51 AM, Charlie69 said: For the carb linkage on the throttle shaft use the one from the stock carb on your Weber. Thats what i have setup. It was the mount for the throtle cable that i fabed up 1 Quote Link to comment
datzenmike Posted July 27, 2018 Report Share Posted July 27, 2018 That's Ratsun... right there. 2 Quote Link to comment
Dawa Posted August 4, 2018 Report Share Posted August 4, 2018 I love longbeds and I love this truck! you are putting in some quality work! 1 Quote Link to comment
