willz Posted March 4, 2017 Author Report Share Posted March 4, 2017 It's been off the road for about 4 years, I started making the throttle cable bracket last night, not sure what cable I'm going to go with yet since the linkage on the carb is a ball type and the factory one is a cylinder Quote Link to comment
Crashtd420 Posted March 4, 2017 Report Share Posted March 4, 2017 Well your getting closer.. once the linkage is done is there anything else to get done before you can drive it?.... Quote Link to comment
willz Posted March 4, 2017 Author Report Share Posted March 4, 2017 Plenty lol. None of the cab mounts are bolted in. I think they're all sitting on the rubber but no bolts through them. And the core support has the wrong ones I think. Need to weld in a 90 for my exhaust, mount the bed and filler tube for the fuel cell, needs a turn signal switch/stalk, bolt the seat in, register it, get a wideband 02, finish the coolant line that goes from one side of the block to the thermostat Quote Link to comment
willz Posted March 4, 2017 Author Report Share Posted March 4, 2017 And I forgot I also need to get new U bolts for the rear end and maybe a 3" lowering block since I lost one, and re-stack the leaf springs Quote Link to comment
