datzenmike Posted May 15, 2019 Report Share Posted May 15, 2019 2 hours ago, sondat said: Back to it! Had a couple weeks of visiting family but off work this week so trying to finish up some loose ends on the truck. Having an issue with the turn signals. The hazards work but turn signals don’t, when TS lever is pushed the light goes on steady, no flashing. I’ve confirmed the signal light housings are grounded as well as the turn signal switch. Not sure if this matters but the hazard lights flash at a slow rate (might be normal?) I tried a different flasher unit for the signals with the same result. Any suggestions would be much appreciated. Cheers. Flashers are load dependent on old Datsuns. Turn the 4 ways on and look to see if all bulbs are working. Possibly one is burned out on both sides. 1 Quote Link to comment
sondat Posted May 15, 2019 Author Report Share Posted May 15, 2019 Good info fellas. The batteries brand new, I will check what it’s putting out. Only the tail lights are hooked up so the flasher is lightly loaded. Mike, is this the reason for the slower blinking with the hazards? Still not sure why the turn signals are acting the way they are though. 1 Quote Link to comment
mainer311 Posted May 15, 2019 Report Share Posted May 15, 2019 So, the fronts aren’t hooked up at all? That would be part of the problem. 1 Quote Link to comment
datzenmike Posted May 15, 2019 Report Share Posted May 15, 2019 Yeah the current flowing through the flasher warms a bi-metallic strip which will bend, opening the contacts turning the lamps off. It quickly cools and the strip un-bends, makes contact and this repeats. If a bulb burns out there is not enough current flow to make it work. If you were to run a trailer on these, the extra bulbs will cause the flasher to speed up. Newer cars have electronic flashers. The are 'solid state' transistor type with a set flash rate unaffected by load. A bulb could burn out and you'd never know it. 1 Quote Link to comment
sondat Posted May 17, 2019 Author Report Share Posted May 17, 2019 Have the front signal lights hooked up, they are only LED lights so I’m assuming it’s not adding much draw. I will pick up the solid state flashers tomorrow for turns and hazards. I’m not optimistic that this will fix my problem. Here’s some symptoms. Hazards work front and back with key on, hazards work back only with key off. Turn signals need key on (of course) but they only come on steady (no blinky), and the signal indicators don’t work at all, hazards or turn signals. I’ve rung out the indicator bulbs, there good. I’ve also bypassed the hazard switch giving the same results, so hazard switch is good. Thoughts? 1 Quote Link to comment
datzenmike Posted May 17, 2019 Report Share Posted May 17, 2019 Get an electronic flasher unit. I just go to any wrecking yard and grab one of a newer car or truck. 1 Quote Link to comment
sondat Posted May 17, 2019 Author Report Share Posted May 17, 2019 Will do Mike. Was playing around with newly installed led headlights tonight and noticed the right turn signal indicator does light up faintly when signal is on. Either a grounding issue or the required electronic flasher. I suppose I could pull the one from my 2008 F150 to try. 1 Quote Link to comment
sondat Posted May 17, 2019 Author Report Share Posted May 17, 2019 Success, two new electronic flashers and problem solved. There’s always something else to learn. thanks for the help 1 Quote Link to comment
mainer311 Posted May 17, 2019 Report Share Posted May 17, 2019 If you’re running LED bulbs, it’s practically required. 1 Quote Link to comment
sondat Posted May 18, 2019 Author Report Share Posted May 18, 2019 I get it now mainer311. I wasn’t optimistic going into it, thought I’d still have an electrical nightmare to chase down. What a pleasant surprise. Tested all the indicator bulbs in the gauge cluster, all rang out good but the left turn signal indicator isn’t working, maybe in the circuitry of the gauge cluster some where. What’s going on with your ride mainer311 back on the road? 1 Quote Link to comment
Charlie69 Posted May 18, 2019 Report Share Posted May 18, 2019 (edited) Clean the contacs for the light socket. Test the board contacts with a test light or multi meter to be sure your have current to light the bulb. Test the bulb and the socket. Try a differnt socket and bulb that you know works. Many was to test. Edited May 18, 2019 by Charlie69 1 Quote Link to comment
mainer311 Posted May 19, 2019 Report Share Posted May 19, 2019 23 hours ago, sondat said: What’s going on with your ride mainer311 back on the road? Yup! All back together and all is well. Well almost. My gas tank looks to have been plugged before by a PO, and it was a shoddy job, so I may be dropping the tank soon. Also just installed some NOS fender mirrors. 2 Quote Link to comment
BrothersGarage Posted May 19, 2019 Report Share Posted May 19, 2019 Goddamn, you have a beautiful truck. 2 Quote Link to comment
sondat Posted May 19, 2019 Author Report Share Posted May 19, 2019 (edited) I have a spare tank but I bet shipping would be pretty steep . It is out of our truck that we parted out. It looks about the same shape as the original tank that we wire wheeled the outside of and painted it up. I scoped the inside of both tanks and they looked comparable as well, just some small surface rust spots but overall pretty clean inside. I was thinking of taking the sending unit out for a spare. Your ride looks great, nice clean truck. I do like the mirrors, curious what the functionality would be like with them further from the driver position. We struggled with location of side mirrors since all the old holes were welded up which gave us a clean slate for placing them. We went near the no draft windows. I had the previous week off so got lots done. Wired up and installed new Lumen LED halo head lights, replaced flashers to electronic (as you know), permanently installed gauge cluster, heater, sun visors and front valance. The no draft windows were previously dissembled and powder coated black to match the rest of the look of the truck. My son and I spent about 5 hours in the basement today installing all the glass with all new rubbers/seals, also the re-upholstered door cards. I am going to start a separate post on our experience installing the glass, what a bear that was. Now that we got that process dialled in, others might like us to share. Edited May 19, 2019 by sondat 6 Quote Link to comment
mainer311 Posted May 19, 2019 Report Share Posted May 19, 2019 Jeez, those doors look awesome. In the location I put my mirrors (based off of some photo research I did on other 521’s) they’re basically blind spot mirrors like Mrbigtanker mentioned in my build thread. He’s right. For changing lanes and stuff, I’m looking over my shoulders anyway, so I use them for situational awareness. I’d definitely pay to have that tank shipped if you were willing to do it. We don’t have access to stuff like that up here in New England. If you’re serious about shipping it, name your price. 1 Quote Link to comment
sondat Posted June 20, 2019 Author Report Share Posted June 20, 2019 (edited) Update on the never ending project. Towed our 521 to a trusted shop for 2” exhaust with a super turbo muffler. They also did an alignment and fired it up confirming our thoughts on replacing the carb. Weber is on order, should be here any day. Also had the bed liner sprayed in. Things left are hang the doors, windshield wipers and motor install, bleed the breaks and clutch slave and order some seatbelts. List is looking a little more manageable. mainer311, I PM’d you a while back on that spare tank, sorry to say we’re going to hang on to it. Edited June 20, 2019 by sondat 1 Quote Link to comment
mainer311 Posted June 20, 2019 Report Share Posted June 20, 2019 No worries man. I've been monitoring mine, and it's not dripping (yet), so I'm going to run it as-is until it gets worse. 1 Quote Link to comment
sondat Posted July 29, 2019 Author Report Share Posted July 29, 2019 while tuning newly rebuilt L20b discovered issues with EI dizzy with remote ICM. Swapped out dizzy to original points distributor and runs like a top. Will look into issues with EI dizzy but for now will run the points dizzy (single set of points). Question, any concerns running the higher output coil with the points dizzy? 1 Quote Link to comment
mainer311 Posted July 30, 2019 Report Share Posted July 30, 2019 What’s the impedance of the coil? If the coil plus ballast is less than 3 ohms, you’ll burn up the points faster due to arcing. If there’s no ballast hooked up, you could temporarily add one back to prolong the life of the points. 1 Quote Link to comment
d.p Posted July 30, 2019 Report Share Posted July 30, 2019 Post a pic of the truck sondat. Lets see the finished product. 1 Quote Link to comment
sondat Posted July 30, 2019 Author Report Share Posted July 30, 2019 So I put the original coil and ballast resistor back in till I get the EI dizzy sorted out. Setting timing and checking carb adjustments tonight. Hey d.p. I know I haven’t posted pics lately, getting the doors on tomorrow and hopefully have it back on it’s feet soon (off the stands). I’ll post the latest progress probably in the morning and hopefully have it’s first test run and some pics of that soon. Thanks for the response mainer311 I should be ok since I went back to the original equipment (temporarily). 1 Quote Link to comment
sondat Posted August 10, 2019 Author Report Share Posted August 10, 2019 (edited) It's been over 3 years since we started this project and its finally on the road. still a few clean up things to do like mount the bumper, turn signal canceling pins and some interior work. The 3 point seat belts went in after some sweat and cursing. I managed to drop the backing plate we were installing down the passenger side B pillar. caught the string I had tied to it with a coat hanger through the striker plate hole then fished the top half of B pillar to get it back out. The windshield wiper pivot threads were stripped (large nuts that tighten on outside of truck). Machinist at my work had an adjustable die to cut new threads and then he made new nuts to match the newly cut threads. Also trimmed back the original fan shroud since the fan for the L20b is bigger. Picked my son up with it when he was finished his shift at work, he didn't know it was drivable. Great day. A few pics from around town. Edited August 10, 2019 by sondat 7 Quote Link to comment
BrothersGarage Posted August 12, 2019 Report Share Posted August 12, 2019 What a great feeling to have your car back on the road, and damn does it look good! 1 Quote Link to comment
sondat Posted August 13, 2019 Author Report Share Posted August 13, 2019 Thanks BrothersGarage, just have to get my son driving a stick. The lessons have started. 3 Quote Link to comment
sondat Posted August 26, 2019 Author Report Share Posted August 26, 2019 So the truck is running well, a couple issues to iron out. Has anyone experienced there reverse lights coming on for long periods of time while driving (when not in reverse)? They aren’t coming on when dog leg is put in reverse. The reverse lights were working properly when truck was first wired up. I’m thinking it is the switch itself. Quote Link to comment
