SRB87 Posted January 25, 2017 Report Share Posted January 25, 2017 Any ideas of the wiring for the two of these? Or trouble shooting steps to check them out? Thank you Quote Link to comment
datzenmike Posted January 25, 2017 Report Share Posted January 25, 2017 I'm going to assume your gauges are not working? Temp gauge... If gas gauge works then not the fuse. Find the sender, should be below the top rad hose where it leaves the thermostat . It will have a single Yellow/Black stripe wire to it. Check that the wire is connected, that it is clean and securely attached. If still no reading ground this wire to anywhere on the intake and your gauge should read full HOT. If YES the sender is no good. If NO it's likely in the dash, wiring or the gauge is not working.. Quote Link to comment
