Sign in to follow this
42corrina42
720 water pump
Remove ALL the bolts?  No special tools needed, just 10mm and 12mm wrenches.  Unless some of the bolts have been replaced with ones with bigger heads.
Once all the bolts are loose (one can't be removed all the way, it's trapped behind the pulley) it pulls straight off.
Share this post
Link to post
knock vertically on the pulley. My PO had RTV instead of a gasket so it was glued good on the front cover...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
