MantisX620 Posted January 9, 2017 Report Share Posted January 9, 2017 Hi all, I am converting my distributor into a programmable unit using a CB performance black box. I took apart one of my old points distributor to see what I was up against to lock the distributor mechanical advance. Am I correct in assuming I need to prevent the weights from being able to open up to lock timing? Heres a pic. Thanks all MantisX Quote Link to comment
datzenmike Posted January 9, 2017 Report Share Posted January 9, 2017 Would help if you said your reason for this. Like what is the black box going to do that the factory advance doesn't already do? 1 Quote Link to comment
MantisX620 Posted January 9, 2017 Author Report Share Posted January 9, 2017 I can set the timing to what I need at whatever vaccuum/boost reference. Also has 2 step. Quote Link to comment
datzenmike Posted January 10, 2017 Report Share Posted January 10, 2017 Ahhh a turbo application. I think Keith Law has the vacuum advance diaphragm reversed somehow and turbo pressure retards the timing. Quote Link to comment
banzai510(hainz) Posted January 10, 2017 Report Share Posted January 10, 2017 seen people JB weld the slots so the weights dont move 1 Quote Link to comment
