old guy in Seattle needs possible heater help on his Datsun( from Tana)
vindats1
  • Replies 40
Ok, so Herb's heater valve showed up. shipped from Japan so it took a while.
ereF6C2E4DE-A155-4C7B-99F5-31370F0941CD_zps
Here is a side by side comparison. I was looking for the tubing to be the same with a mounting solution I could live with.
6A5FF980-6658-4D69-BBE8-DDAFB9402C5A_zps
Looks like the tabs are not oriented correctly to use the original bracket to mount up
7EB2FE67-D12E-40C5-89FE-34B513102B61_zps
So I cut off the bracket and used some machine screws to attach the valve to the original mechanism
44C7CC6D-C33F-487C-812C-B3BC20751108_zps
83A59F4A-97AC-4B98-AA72-9216BBE1E9F8_zps
And back together with new hoses I had laying around
24CE0627-8D09-4E8B-97FD-785572AA3025_zps
D8000B2E-571A-42EC-9245-FD1C6DA991DE_zps
Pressure tested and repair confirmed!
Time to call Herb and set up an install time
  • Like 9
Got Herb's heater up and running today. Worked out just fine.
I have a request for the community here. His wipers stopped working due to a worn out motor linkage pivot. Anyone have one they can part with? Here is a picture of what I am looking for
8C296794-70AA-4B68-8E25-7D3D296FD2F2_zps
B8B1F242-1C55-4D71-8606-50895349114F_zps
BB1F1DD5-EAF9-4A16-921C-C2332713EB4C_zps
Amazing fix on the heater valve! Now if only we could find a similar valve for the 510.. anyone?
Taking some copper pipe to Al today so his radiator guy can fix my cracked pipe, I'll disassemble the valve itself and replace the o-rings, I'll make a thread when i get it back next weekend to explain and post oics of what he did, i don't think there's a worse one than mine and he said he can fix it, :thumbup:
