1985 720 4X4 No Power
SRB87
Just bought my 85 Nissan 720 Z24 4X4. I checked the timing its at 10 degrees, the firing order is correct, no vacuum leaks. Both coils are sparking. Truck runs, idles, drives but has no low end power. any help would be nice thanks
  • Replies 12
So up date, no Cat on truck. Adjusted valves, the spark plugs looked carbon up on cylinder 4 and a little bit on 3. 1 and 2 were wet with fuel. Need to check compression again after I adjusted the valves. Replaced spark plugs also. Does the vacuum have to 3-4 degrees with the vacuum advance unplugged or not? Thanks
Got the truck back together checked the timing when i put it down to 3-4 degrees it runs like crap, if i put it up to 25 degrees it works alright, not the best but has a little more power from where i started. When i hit the gas now it bogs down slightly.
This is how i got the truck. I am just trying to figure it out. I ordered head gasket set and just going to replace it and start from scratch. might as well do it correct so it lasts a long time.
I'm saying what you describe is virtually impossible. I believe you it's just there has to be a mistake in how you are doing it.
Can you confirm that the plug wires are going to the correct plugs. There are 8 and it's easy to mix up. The order is 1342 and there are intake and exhaust sides.
Update truck runs great now. The head gasket between 2 and 3 were blown out. After I replace it. Put the timing to the correct degrees. Changed oil and filter also the coolant. Now it's time to get a new header do to manifold being warped. Also have to turn up the torsion bars tonight.
$25 will get your manifold machined flat at a machine shop. You'll find most of us don't believe headers are worth anything on these trucks. The head itself is more restrictive than the exhaust.
Nice job getting it running.
