heywier427 Posted January 3, 2017 Report Share Posted January 3, 2017 I read a bunch about it, and short of converting over to a newer cap/filler neck, there are no fixes. Anyone think this may work? Or at least help a whole lot. http://mikeschevy.com/57-1957-chevy-gas-tank-fuel-filler-tube-check-valve/ Diameter is too much at 2-7/16 o.d. But its an extremely simple design to make up out of 2" Put it in right at the filler neck so the gas nozzle pushes it up/open. Im thinking slide it in and hose clamp it in place from the outside. Seen a bunch of rollover type ball/float valves, but I dont think they will work due to the horizontal angle of our filler tube. Any other ideas? Quote Link to comment
Draker Posted January 3, 2017 Report Share Posted January 3, 2017 That is a interesting idea if you are stuck on staying with the stock setup. However, the Mazda fuel neck retrofit is a great mod and you can fit newer nissan caps. 1 Quote Link to comment
bananahamuck Posted January 3, 2017 Report Share Posted January 3, 2017 That is a interesting idea if you are stuck on staying with the stock setup. However, the Mazda fuel neck retrofit is a great mod and you can fit newer nissan caps. And done with cheap tools you probably already have around the house. Quote Link to comment
heywier427 Posted January 4, 2017 Author Report Share Posted January 4, 2017 Gonna make my own design. Will be better than the one pictured. Vertical delrin flap pushed/held down by a light spring. Seated on a small step to stop/seal it. Inside of a 2" diameter tube. Slide it into the filler tube and hose clamp in place. 2-3" inside the filler neck. Pushed open by the filler nozzle. A project I will never get to... Quote Link to comment
heywier427 Posted January 4, 2017 Author Report Share Posted January 4, 2017 And yes, stuck on the stock looking filler. Quote Link to comment
datzenmike Posted January 4, 2017 Report Share Posted January 4, 2017 Gas can't spill out if the cap has a good seal. Some caps vent but only inward others are sealed tight. Check your rubber gasket. Quote Link to comment
heywier427 Posted January 4, 2017 Author Report Share Posted January 4, 2017 I tried. Its new. I used a few different types of sealing surfaces, but they all leaked. Im also being anal. When I say "leaked", its a full tank of gas, driving like a loon, and it was a single bead going down the body. But every trip. Its just annoying. I got an nos one to seal almost all the time (by stacking 2 seals), but the new repop one wont. The metal is not strong enough to keep the compression tight. The easier thing to do is send the nos one to get anodized. I also have a tough time with that type of twisting motion with my thumb. Many boxer fractures under its belt. Even with my new cars/caps. I just like inventing/tinkering and starting 13 projects in the middle of my 13 other projects. You know, like the rest of us :) Quote Link to comment
datzenmike Posted January 4, 2017 Report Share Posted January 4, 2017 What about the surface the rubber seals against? Could be dented? Had a rad cap like that ran a flat file over it. Quote Link to comment
heywier427 Posted January 4, 2017 Author Report Share Posted January 4, 2017 Wish it was that easy. The surface looked flat, but I filled it, then sanded/polished it. That made it much better, but still a bit of a weep. Im also being hindered by the fact that I have a 2 stroke and mix the oil in the tank. The oil helps it find its way out/hang around, instead of just evaporating. Quote Link to comment
datzenmike Posted January 4, 2017 Report Share Posted January 4, 2017 A two stroke 510? The gas tank should not leak, they didn't design them this way. Quote Link to comment
heywier427 Posted January 4, 2017 Author Report Share Posted January 4, 2017 Rotary :thumbup: They should not leak, and of course they were designed not to, but many people complain about this issue. And its not just Datsuns. Many 50-70's cars with this simple designed cap and a damn near horizontal filler tube has/had slosh issues. Its one of the main reasons the american cars moved the filler from the rear end of the cars, to the sides. Quote Link to comment
