Chevy rallye tire size/brand?
d.p
Got some 15x8 chevy rallyes w/trim rings for $120.  Will most likely PC them but in need of tires, I think the consensus is 195/50r15??  If so anyone recommend a tire? And goddamn tires are cheap in this size, used to paying $1000+ for tires.
Will post pics soon.
  • Replies 81
I have a 521. I used 195/65R15.
3" blocks and a few springs removed.
Bars turned and tightened in the front.
A few people will jump on here saying the size I listed was too big.
I have proven it is not. 15x8 with my tire size is barely any different than OE diameter.
I like the way the fill the wheel well vs. running a smaller tire and needing to slam accordingly to make up for the lack of rubber.
I barely rolled the rear fenders. I more just flattened the lips. No stretch.
I wish I had a better pic. I think they fit, and look, perfect.
  • Like 4
I have a 521 as well and both of those trucks look great.  I had saved some of your truck pics last night when was I searching. Jester you got a lower offset than most?  You guys rattle can the wheels or have them powder coated?
Mine were PC.
How does it ride with the leafs removed?  I want to reduce the wheel gap on mine but not trying to sacrifice the ride completely to do it.  I figure 3" blocks and lower the front via the torsion bars (not low enough to have to reindex).
225/60R15 BFGoodrich Radial T/As - old school with lettering out.  3" blocks and bars indexed.
Rubs all over the place.  :rofl:  Why wasn't I told this wouldn't work, dammit?!  But I still kinda like it.  Think I'd go 195/65 next time - like when I rub through a tire. Was good until I lowered.
26952017-9bd7-4d7e-9b0e-292118830996_zps
Well I got new shocks on mine but still don't want to be bouncing all over the place.  I guess without reindexing I can always just raise it back up.
Tucson620 your tire 30mm wider with a taller sidewall which is way bigger than what I read is recommended (195/50r15).
After flattening the lips on my rear fenders, I don't ever rub.
If I was to haul a huge amount of cargo I could/would.
195/50 will fit, obviously. Too small for my eye-and a big enough difference that speedo will be affected-though, not by a lot.
I love the look of yours flatcat, but not sure I want to remove the leafs, just not at that stage in my life where I could put up with a shit ride.  If I just do 3" blocks and lower via torsion bars is the ride going to suck? If it won't I can go with a slightly taller tire to make up for the gap.  Tucson can you post a side pic of your truck?  And how did you lower yours?
Don't scared to remove a leaf or two.
My previous owner removed 3 and it rides OK. I'd probably do it again, if that matters.
Like I said before, my shocks are junk. KYB Gas-A-Just are on the post-Xmas shopping list.
Can always put them back if I don't like it.
These what I am looking for? http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=7698&gclid=CNnhhOz9htECFYdsfgodSAQBHw
Found them in the 520 forum.
