Michael Rankin Posted December 29, 2016 Report Share Posted December 29, 2016 Anyone know where I can get a small diameter crank pulley ? Quote Link to comment
Stoffregen Motorsports Posted December 29, 2016 Report Share Posted December 29, 2016 Rebello had a batch of them made about 15 years ago and couldn't give them away. When I left Rebello he still had a box full of them. Try giving them a call. Quote Link to comment
Michael Rankin Posted December 29, 2016 Author Report Share Posted December 29, 2016 thanks I will try them Quote Link to comment
flatcat19 Posted December 29, 2016 Report Share Posted December 29, 2016 I could be interested in one. Quote Link to comment
datzenmike Posted December 29, 2016 Report Share Posted December 29, 2016 Anyone know where I can get a small diameter crank pulley ? Why??? Easier to make a larger water pump or alternator pulley if wanting to slow them down. 1 Quote Link to comment
Stoffregen Motorsports Posted December 30, 2016 Report Share Posted December 30, 2016 On a L4, the water pump and crank pulleys are so close to touching each other already that a smaller crank pulley may be the better way to go. Quote Link to comment
scooter Posted January 2, 2017 Report Share Posted January 2, 2017 Some chevy water pump pulleys work if you drill the center a little bit bigger, and they are slightly larger than stock. Spacing is similar. Dont know if it would hit on the stock pulley, but it doesnt hit on my setup (ati damper with chevy lower pulley) Quote Link to comment
datzenmike Posted January 2, 2017 Report Share Posted January 2, 2017 Could you chuck it in a lathe and turn it down? Appears to be a cast one piece Quote Link to comment
Michael Rankin Posted January 3, 2017 Author Report Share Posted January 3, 2017 I ended up buying the BHJ race pulley (4" vs 6" diameter) thanks for all the help. Quote Link to comment
Stoffregen Motorsports Posted January 3, 2017 Report Share Posted January 3, 2017 Cool. Which one? Quote Link to comment
Michael Rankin Posted January 4, 2017 Author Report Share Posted January 4, 2017 OK, BHJ says 4 weeks to get the pulley, I do not have that much time.....any other ideas ? Quote Link to comment
Stoffregen Motorsports Posted January 4, 2017 Report Share Posted January 4, 2017 Stock 240Z damper/pulley. Quote Link to comment
Michael Rankin Posted January 9, 2017 Author Report Share Posted January 9, 2017 I bit the bullet and bought a pulley dampner combination from Rebello, a little expensive but the right thing to do for a race motor. Quote Link to comment
Stoffregen Motorsports Posted January 10, 2017 Report Share Posted January 10, 2017 Did you get the Nismo damper? Quote Link to comment
Michael Rankin Posted January 10, 2017 Author Report Share Posted January 10, 2017 Don't know, since I'm new to 510's I trusted Rebello and Troy Ermish on this. 1 Quote Link to comment
scooter Posted January 15, 2017 Report Share Posted January 15, 2017 Post an oic of this beast Quote Link to comment
flatcat19 Posted January 15, 2017 Report Share Posted January 15, 2017 Post a link. Quote Link to comment
Colbino Posted January 26, 2017 Report Share Posted January 26, 2017 http://www.bhjdynamics.com/index.php?main_page=index&cPath=10&zenid=4tfvkjdgiqjpu6b07nmhkgsp40 Quote Link to comment
flatcat19 Posted January 26, 2017 Report Share Posted January 26, 2017 Dammit. Now I want to spend money! Quote Link to comment
red13 Posted January 31, 2017 Report Share Posted January 31, 2017 why not gilmer? http://datsunstuff.blogspot.com/2014/08/l-series-gilmer-belt-drive.html Quote Link to comment
