8m0untainman8 Posted December 25, 2016 Report Share Posted December 25, 2016 Hey guys i recently bought a new battery and an alternator (noticed on another thread that might have been a poor choice). I hooked everything up properly, ive replaced the terminals on every end of the wires because they were broken or worn badly. I just test drove my truck and the charge light was still on. What is the chance the external voltage regulator has gone bad? Is there a way to test it? Or does anyone have other suggestions/ questions for more detail? The charge light was honestly on for quite a while before it ever died if i remember correctly , so i didn't think much of it at first (Durrp). Quote Link to comment
datzenmike Posted December 25, 2016 Report Share Posted December 25, 2016 A fully charged battery will keep a vehicle running for a very long time. The time is greatly shortened if you start it a lot or use the headlights and heater. Replacement (cheap rebuilds) are unreliable, so hopefully you kept the old ones and didn't turn them in. What if it's the VR and you put a bad alternator in? If possible, take the alt in and have a free charge test done on it. If you have the old one, do it also.... for a spare. Have them check that this is the correct alternator for an external voltage regulator. (the '78 and up had a built in regulator) I guess the last thing is to replace the VR. You can get non mechanical (solid state) external VRs. Quote Link to comment
8m0untainman8 Posted December 25, 2016 Author Report Share Posted December 25, 2016 Alright, thanks for the advice man. Sadly I did not keep the other alternator, but it looked the same as the remanned one. A couple friends have suggested swapping a chevy style single wire alternator that i believe is internally regulated. Have you heard of that, or have advice? Also my truck has been getting sputtery at around 2900 - 3200 rpms. (I wont even deny im a complete newbie) and this didnt start until the same time my battery was drained. Not sure what is causing it, for all i know it could be fuel delivery, and poor spark that started it but its apparent now. especially once i get above 45mph. MERRY CHRISTMAS, by the way. Thanks for responding. Quote Link to comment
datzenmike Posted December 25, 2016 Report Share Posted December 25, 2016 Low battery will not fire the plugs properly. Yes you can swap in an internally regulated alternator by splicing two pair of wires together, unplugging the auto choke heater and splicing the choke heater to the idle cut solenoid wire. Keep in mind that the 620 does not have a lot of space for a physicaly larger alternator. It's all in the search function, top right of page. Try 620 alternator swap 1 Quote Link to comment
8m0untainman8 Posted December 25, 2016 Author Report Share Posted December 25, 2016 Could the regulator cause it to get less than effective spark if its going bad? Thats what im concluding. Quote Link to comment
datzenmike Posted December 25, 2016 Report Share Posted December 25, 2016 If it's not charging the battery, then the battery is low or will be soon. Poor battery voltage may cause poor ignition. Then again it could be the carburetor or valves needing adjustment. If the charge light is on and the battery not charging this is the problem you need to fix first. Worry about all other problems in order. 1 Quote Link to comment
mcordero8 Posted December 26, 2016 Report Share Posted December 26, 2016 You might want to try tightening the fan belt some and see if the problem goes away. Try the easy stuff first. Good luck. Quote Link to comment
distributorguy Posted December 26, 2016 Report Share Posted December 26, 2016 Points ignition will run decent down to about 10V. Electronic needs 12-14V to perform normally.. That could be it. Or you could have low fuel supply. I've seen many different alternators installed in Datsuns - from a 1-wire Delco to the Mazda alternator in our race truck. Just move the upper bracket to make it fit. Quote Link to comment
8m0untainman8 Posted December 26, 2016 Author Report Share Posted December 26, 2016 Im going to check the external voltage regulator later today. Its 12v reg, from 40 years ago with no weather protection on the back of it. Lol Quote Link to comment
8m0untainman8 Posted December 30, 2016 Author Report Share Posted December 30, 2016 Hey guys, thanks for all the help, i have a complete newbie question, but what all could cause the charge light to stay on that you know of? Ive gone and replaced all of the extremities of the charging system, could it simply be poor/ slightly loose connections, or bad grounds keeping my charge light on? Quote Link to comment
datzenmike Posted December 30, 2016 Report Share Posted December 30, 2016 There must be a good ground connection from the voltage regulator to the body. There must also be a good solid connection between the body and the battery negative terminal. If you look on the negative cable there will be a separate wire to a ground screw near the battery. Make sure the voltage regulator is screwed down tight and well grounded to the sheet metal. Possibly someone has replaced the battery cable with something generic from NAPA. (which won't have this) You can make a ground wire out of 10 gauge wire and connect from the valve cover bolt to the fire wall. Quote Link to comment
