[new title] 77 280z w/ l28et regeneration
brapattack
Hey,
     I joined this forum a couple years ago then had to put off getting a z car until a few weeks ago.  I picked up this as my starting point.
There are a lot of things I want to change and weird/janky choices a previous owner made that I am trying to undo.  For instance, someone decided to lower the car by heating the springs...so i knew that I would find more surprises.
Today I tried doing a valve adjustment and found this:
No rocker arm springs!  Also, isn't there supposed to be another nut above the spring retainer clip to do the actual adjusting?  Not sure what the goal was here, is this some strange mod i've never heard of?  Im going to order parts today and if you guys have any insights on pieces to pickup other than the springs and nuts, let me know.
  • Replies 63
Valves seats may have worn down and the valves sunken, making setting the lash impossible. The missing parts are AKA mouse trap springs.
Pop a rocker arm off and see what the pivot post looks like. The pivot post should have a place for a wrench for turning it up and down..
I took off the cam and pulled out one of the rocker pivot posts out and it looks like this:
All the images I see of these, they are supposed to be threaded with a hex spot on it for a wrench so i'm not sure what these are.  I should point out this 280z has a 280zx turbo motor swapped in but even those look like they have the same rocker pivot post when I search for the part.
Also, my camshaft sprocket doesnt seem to have any of the 'V' grooves for checking the chain wear against the locating plate behind it (the has the '-' mark.  I have been using a Clymer 280zx manual for referencing these engine parts and I am not sure if the manual is off or if some strange parts were swapped in.
Hey CGraves, what would you like to see of the swap?  I'll take photos.  A previous owner did it and I am still trying to sort out all the things they did/didn't do right.  A lot of vacuum stuff was blocked off and hardlines removed so I am learning about that system too.
I'd like to do either a z31 AFM and ECU upgrade or Megasquirt to get away from this flapper MAF but haven't decided which route to go yet.
Hey,
Mechanical adjustment is not necessary if you have hydraulic pivots.  Rat trap springs are most definitely necessary.
Heh, Datzenmike are the hydraulic lifters that bad?  Will be putting in the ratrap springs for sure.  Trying to decide if I want to remove the intake and exhuast manifolds and head while I am in here to replace gaskets.
Guess I can't put in any high lift cams with this head.
Move it ahead one and see if you feel any changes. Generally a stretched chain subtly favors top RPM power but reduces low speed torque. If you can't tell it's unimportant.
No V in it is likely after market... meaning it was changed for a fresh one.
Before taking it apart yesterday, I was having problems with tough starting in the cold (I think they removed the cold start injector) and while idling it had random misses.  Had some low RPM stumble until it was really warmed up from a few miles of driving.
The spark plugs look and consistent, cold compression tests had all cylinder between 145-155psi.  I was expecting cylinder 1 to have poor readings because it looks like it could have had a small headgasket leak up front.  No oil in the radiator.
Since finding the lack of the ratrap springs, I'm hoping that clears a lot up.  Will check the timing once its all backtogether.
IMG_6163_zpsnjbdr7hw.jpgRight now I don't have bumpers, and the driver side fender is a red replacement.  Oh and look at that coffee can sized exhaust!  Going to try and replace a lot of the window rubber to keep moisture from getting in, then sand and address a few rust spots.  Floors and rails seem to be in good shape, which is why I went with this one as a starting point.
A compression leak into the cooling system will over pressurize it. This will force coolant out the over flow tube past the 13 PSI rad cap. You would find you need to constantly top it up or if bad enough it would overheat. If you have a coolant recovery system it may not be apparent.
Looks good without the bumpers and the '77 still looked like a Z car.
Is there any reason why you wouldn't be able to run a high lift cam with these? As far as I know that shouldn't cause any problems.
Main reason is that if you float the valves, the hydraulic lifter instantly take up the slack, making them too tight, and holding the valves off the seats, until they bleed down.
Better springs will help prevent this.
I'll dig around, see how many spare 'rat trap' springs I have.
Here is the mess I am trying to figure out.  Also, why I didn't post more pictures before.  Trying to sort out what the hell this person did for the swap, lots of un attached wiring, and blocked off, removed or left open vacuum stuff.
I have a Clymer manual for the 280zx turbo and am still trying to figure out exactly what each wire does.  I know a lot of people cleanup their intakes an vac systems but its hard to tell exactly whats here and what is required.  The car ran and drove but was definitely running poorly.  I think the cold start is gone, AAC valve seems to be removed and blocked off.  Not exactly sure what was blocked off from the throttle body yet.  Trying to look up pictures of correctly setup stuff with labeling is what I have been hunting for.
Thanks Hainz, i'll look up your videos.
Yeah I decided I might as well go ahead and pull the head to do that gasket, take a look at the cylinder walls, replace valve oil seals and all that.
I don't have a timing chain wedge in there, just a hook for the chain to keep tension on it.  Guess i'll have to pull the water pump to reset the guides?
Ooof getting those intake and exhuast manifolds off was a chore.  Found out why I was having some exhaust leaks though.  The studs at the front and rear were both broken off.  No for the fun of drilling them out of the head and putting in a coil.
Got the front cover off and front seal replaced.  Unfortunately both my chamshaft sprocket and timing chain are the types without marking and bright links.  SO they much ave been changed but I don't know how recently and its tough to say which hole to install them on (they were on hole 1).
Learning a lot though and glad i'm crossing off some problem areas while I have the time to do the work.  Found that the thermometer wire was not attached to anything (does this matter?) also the O2 sensor wasn't plugged into anything.  seems like a lot of data that just never go routed back to the ECU.
I would not be surprised if there are at least two sensors for coolant temp.  One for the ECU, and one for the temp gauge.
On the four cylinder L-engines, with stock timing chain parts, you set the crankshaft at TDC, and there is a small "V" notch in the back of the cam sprocket, that lines up with another small groove in the cam sprocket thrust plate, when the camshaft is at TDC position.
