konig209 Posted December 15, 2016 Report Share Posted December 15, 2016 (edited) So to end all the questions. "which i know more will still be asked cause people don't like to freggin read." el oh el. Konig209 521 KA24DE Swap 001 by Carlos Ortiz, on Flickr well to start of you need a 521 1969.5-1972. that came with the l series for this write up to help you out. if you have a j series.....ehhhhh you're shit outta luck but this may still help. second you'll need a 1991-1998 nissan 240sx ka24de engine set mated to a 240sx 5 speed transmission, wiring, ecu, and maf. Update 4-19-19 in all honesty if you can get an s13 setup its better than an s14. S14 head has a part in the cast that blocks the throttl cable. Its a pain in the ass but easy to fix. no the frontier ka24de engine will not work as easily. it is a rear sump oil pan and it is not interchangeable with the 240sx pan and pickup tube. no i don't know if any other trans will work with the info im giving. no you don't need to cut into the trans tunnel for it to fit. no there is no fabricating to make it fit. yes it will drop in with the trans mated to the engine but you will need to remove the crank pulley, alt and water pump. to avoid any hassle sitting the transmission in its place undo your torsion bolts as far back as you can then set back in after your done. so parts list. ka24de 240sx motor set engine bracket kit from ]2eDeYe You can contact him on here fb or ig instagram @i2edeye ratsun ]2eDeYe fb page https://m.facebook.com/i2edeye/?ref=bookmarks He also makes them for 620 received_3203421339776217 by Carlos Ortiz, on Flickr TIP!!! when dropping in bolt the motor mounts to the engine gives another inch of clearance when setting in place then carefully bolt it into its place. 20170313_201308 by Carlos Ortiz, on Flickr 20170313_201318 by Carlos Ortiz, on Flickr 20170313_201326 by Carlos Ortiz, on Flickr trans mount from energy suspension part # 3-1108r https://www.summitracing.com/parts/ens-3-1108r Konig209 521 KA24DE Swap 007 by Carlos Ortiz, on Flickr to fit oem radiator you need upper hose part #d71236 Konig209 521 KA24DE Swap 012 by Carlos Ortiz, on Flickr lower hose is oem. I recommend a aluminum radiator upgrade to help with cooling. ebay ones work great. 521 shares radiators with the 510 to make it easier with a 10" fan. a custom 1 piece driveshaft needs to be measured to fit your truck. average is about 51" inches. "some trucks depending on height or suspension setup will affect this." 2017-12-06_12-17-16 by Carlos Ortiz, on Flickr wiring; icehouse member on here makes a great product to make it a almost plug and play setup with his canam box. comes with full how to tie it in to the harness. http://community.ratsun.net/topic/28097-canam-production-easy-wiring-boxes-for-efi-works-for-kas-srs-vgs-cas-and-more/ SECOND METHOD OF WIRING Custom wiring done by "J's wire technologies" Located in modesto ca. Justin Phone # 4088911336 $325 for regular loom $375 for higher grade mesh loom. Looks much nicer like pictured. 2017-04-18_10-13-36 by Carlos Ortiz, on Flickr buy 1 or 2 12" fans and place them where you like. pull push your choice. Konig209 521 KA24DE Swap 011 by Carlos Ortiz, on Flickr to do a single belt setup. use a single cam ka water pump pulley, alt bracket, thermostat water neck housing, (and belt to fit will update later with part #.) Konig209 521 KA24DE Swap 014 by Carlos Ortiz, on Flickr get an egr delete kit. usually cheap. http://www.frsport.com/EGR-Block-Off-Plate-Kit---Nissan-KA24DE_p_62895.html?gclid=CLuw-InM9dACFYVXfgodWCkHDQ Konig209 521 KA24DE Swap 006 by Carlos Ortiz, on Flickr for the intake you'll need 2 3" 90 degree elbows from autozone http://www.autozone.com/intake-system/intake-coupler/spectre-performance-air-intake-tube-coupler/939533_0_0/?cmpid=PS:3:1:90 Konig209 521 KA24DE Swap 018 by Carlos Ortiz, on Flickr 2 pieces of 3" piping for the intake and a filter of your choice. don't forget to connect the hose from the throttle body to the intake or it wont idle Konig209 521 KA24DE Swap 020 by Carlos Ortiz, on Flickr remove all but 1 vacuum to the fuel pressure regulator. use a walboro 255 in line fuel pump it works or a 280zx fuel pump works to "i think" Konig209 521 KA24DE Swap 005 by Carlos Ortiz, on Flickr water routing will be your deal i ran almost none no heater nothing so i got no tips. there is an orange wire that ties into the starter signal.....dont forget to wire it in lol. for exhaust you can use the stock manifold. use the oem down pipe and have it routed however you like. for the alt wiring unplug your voltage regulator and make 2 jumpers. jump white to yellow and red/white to white black http://community.ratsun.net/topic/63851-burnt-alternator-wire-after-3-hour-drive/page-4 i will update as needed. now do it and go roast some tires!!!! Konig209 521 KA24DE Swap 023 by Carlos Ortiz, on Flickr 2017-12-06_12-24-38 by Carlos Ortiz, on Flickr https://youtu.be/mb_OSZ2UlTg Edited June 20, 2023 by konig209 Update 16 Quote Link to comment
flatcat19 Posted December 15, 2016 Report Share Posted December 15, 2016 Good info to have around here. 1 Quote Link to comment
kelowg Posted December 15, 2016 Report Share Posted December 15, 2016 Napz (z series)trans mate up to ka's as well. 1 Quote Link to comment
konig209 Posted December 15, 2016 Author Report Share Posted December 15, 2016 Keogh the issue with that information is this. Will the driveline work with that trans. Does it mount the same with marks kit for the ka trans i dont know the answers. I know others trans work. But i dont know if theyre longer or shorter 1 Quote Link to comment
kelowg Posted December 15, 2016 Report Share Posted December 15, 2016 Z trans sits same as zx trans and u do have to put trans in place before motor. driveline should b measured and made to each truck. cause there r slight differences from truck to truck. 2 Quote Link to comment
]2eDeYe Posted December 15, 2016 Report Share Posted December 15, 2016 Excellent thread :) 1 Quote Link to comment
mrbigtanker Posted December 15, 2016 Report Share Posted December 15, 2016 I will say good write up. 1 Quote Link to comment
Draker Posted December 16, 2016 Report Share Posted December 16, 2016 Thanks for posting this! 1 Quote Link to comment
flatcat19 Posted December 16, 2016 Report Share Posted December 16, 2016 Z trans sits same as zx trans and u do have to put trans in place before motor. driveline should b measured and made to each truck. cause there r slight differences from truck to truck. Z series/KA transmissions do not sit the same as a ZX/L series trans. They lean opposite directions. 1 Quote Link to comment
konig209 Posted December 16, 2016 Author Report Share Posted December 16, 2016 This post needs to get pinned 1 Quote Link to comment
Charlie69 Posted December 16, 2016 Report Share Posted December 16, 2016 Nice writeup Konig. How is the quality of the Black Market Innovations mount kit? I wold say ask Redeye to pin it but you did not buy his mounts. LOL Quote Link to comment
konig209 Posted December 16, 2016 Author Report Share Posted December 16, 2016 Nice writeup Konig. How is the quality of the Black Market Innovations mount kit? I wold say ask Redeye to pin it but you did not buy his mounts. LOL Dont even know who redeye is nor that he made a kit. Mark is local to me and in all honesty if i had the money to afford his time and labor i would have him build my truck for me. His work is simply amazing. So far not a miss with his kits. 2 Quote Link to comment
mikec4193 Posted December 16, 2016 Report Share Posted December 16, 2016 Hey Konig Wow I am impressed...nothing like that even left in the junkyards to pick parts from around here... So how quick will this truck be when it is all said and done?? Thanks for sharing on here... MikeC 1 Quote Link to comment
kelowg Posted December 16, 2016 Report Share Posted December 16, 2016 Sits the same as zx front to back wise(trans mount wise) 1 Quote Link to comment
]2eDeYe Posted December 16, 2016 Report Share Posted December 16, 2016 Dont even know who redeye is nor that he made a kit. Mark is local to me and in all honesty if i had the money to afford his time and labor i would have him build my truck for me. His work is simply amazing. So far not a miss with his kits. Me lol. My 521 kits are just finished, wasn't able to get a test subject until recently. Still need to order plates for my first production run and develop a transmission mount for the longer 240sx trans. :) 1 Quote Link to comment
datson4life Posted December 16, 2016 Report Share Posted December 16, 2016 Nice writeup, Would like to add that the 38 mm sensor adapter from mishimoto is a very tight fit, but it works, but 36 mm would be better, heres how it looks installed Also, these ears lay right in between the torsion bar bolts, CUT THEM OFF, they are useless and are the only things u will put up a fight with when installing trans, unless u remove torsion bolts and put back after trasnmission is installed, but either way its a bit of a tight fit and life is better without those tranny ears. It should also be added the cost, all the little stuff really add up. I can make a price list later 3 Quote Link to comment
datson4life Posted December 16, 2016 Report Share Posted December 16, 2016 Oh and i also vouch for blackmarkit's mounts, i call them better than oem Heres his whole kit with his plug and play box 2 Quote Link to comment
mrbigtanker Posted December 16, 2016 Report Share Posted December 16, 2016 Looks good one day I will be as cool. That kick panel plate looks good. Does it mount first and then you lay your kick panel over. 1 Quote Link to comment
datson4life Posted December 16, 2016 Report Share Posted December 16, 2016 Looks good one day I will be as cool. That kick panel plate looks good. Does it mount first and then you lay your kick panel over.Ka 521 is so 2015 tho Ls 521 is the new cool 4 Quote Link to comment
konig209 Posted December 16, 2016 Author Report Share Posted December 16, 2016 Hey Konig Wow I am impressed...nothing like that even left in the junkyards to pick parts from around here... So how quick will this truck be when it is all said and done?? Thanks for sharing on here... MikeC Well my truck has been taken down to 2040lbs with me in there. Its fast. Ive left astovk evo 8 behind diesel trucks. Few v8s. I was toying with a new camaro ss the other day. Kept side to side with him up to the top of 4th about 104mph. Hit 5th and was left it lacks the umpff after that but i am impressed on how fast it is. 1 Quote Link to comment
mikec4193 Posted December 17, 2016 Report Share Posted December 17, 2016 Well my truck has been taken down to 2040lbs with me in there. Its fast. Ive left astovk evo 8 behind diesel trucks. Few v8s. I was toying with a new camaro ss the other day. Kept side to side with him up to the top of 4th about 104mph. Hit 5th and was left it lacks the umpff after that but i am impressed on how fast it is. Wow...104 mph in a Datsun truck...that is stupid fast for sure...can I assume the suspension isn't all stock anymore is it??.... MikeC 1 Quote Link to comment
EastBay521 Posted December 17, 2016 Report Share Posted December 17, 2016 Good shit. Im starting mine tomorrow. 1 Quote Link to comment
datson4life Posted December 17, 2016 Report Share Posted December 17, 2016 Good shit. Im starting mine tomorrow. Sweet! 1 Quote Link to comment
konig209 Posted December 17, 2016 Author Report Share Posted December 17, 2016 Wow...104 mph in a Datsun truck...that is stupid fast for sure...can I assume the suspension isn't all stock anymore is it??.... MikeC Ive maxed it out at 134mph. Um it has coilovers on all 4 corners, 4 link ball joint disk brakes and plenty more. 1 Quote Link to comment
HOGIE Posted December 17, 2016 Report Share Posted December 17, 2016 Um it has coilovers on all 4 corners, 4 link ball joint disk brakes and plenty more. I'll be getting to this point some day. Just need the $$$ 1 Quote Link to comment
