Kennyt Posted December 11, 2016 Report Share Posted December 11, 2016 Sometimes she works when door opens. Sometimes she dont. Only works when cold outside. Anyone have a wiring diagram? 1 Quote Link to comment
Rhino13 Posted December 11, 2016 Report Share Posted December 11, 2016 I thought mine was messed up when I first got it but you may just have to pinch the switch and move it forward or back. Middle is off, forward is always on, back is on when door is open. 1 Quote Link to comment
datsunaholic Posted December 11, 2016 Report Share Posted December 11, 2016 Year matters- some 720s (like my '83) has a fade-out timer when you close the door. But in your case I'd suspect that the door switch is the culprit, they tend to get stuck pushed in (which leaves the light off). 1 Quote Link to comment
Kennyt Posted December 11, 2016 Author Report Share Posted December 11, 2016 Thanks. I will check the switch today tonsee if stuck or has any issues 1 Quote Link to comment
datzenmike Posted December 11, 2016 Report Share Posted December 11, 2016 They rust. Work the push button by hand 30-40 times to clean the contacts. 1 Quote Link to comment
MaxChlan Posted December 11, 2016 Report Share Posted December 11, 2016 If that doesn't end up working for you, I have a FSM with the wiring diagram for the 1984 model year that I could send pictures of. 1 Quote Link to comment
DanielC Posted December 11, 2016 Report Share Posted December 11, 2016 A typical door light switch works by supplying a ground to a light that always has power supplied to it. 40 or so years of wear, dirt, rust and corrosion can make the ground go away. Try removing it, and cleaning the contacts, and the connection between the switch body, and cab sheet metal. check also the contact between the wire going to the switch and the moveable part of the switch. 1 Quote Link to comment
Kennyt Posted September 24, 2017 Author Report Share Posted September 24, 2017 I know it has been a while but still no luck. However when it is cold outside the light will work. Any ideas? 1 Quote Link to comment
datzenmike Posted September 24, 2017 Report Share Posted September 24, 2017 The door switches are rusty. Push them in and out many times to clean them. They rust. Work the push button by hand 30-40 times to clean the contacts. 2 Quote Link to comment
mx71 Posted September 24, 2017 Report Share Posted September 24, 2017 My guess is one of the door switches is failing or you have a bad ground. Clean the holes that the switches screw in to. Could also be a failing door timer switch under the passenger seat. I ended up just bypassing my door timer altogether. 2 Quote Link to comment
Kennyt Posted September 24, 2017 Author Report Share Posted September 24, 2017 Thanks. Do u have a pic of the timer? Quote Link to comment
datzenmike Posted September 24, 2017 Report Share Posted September 24, 2017 This is the fuel pump relay/timer which is very similar to the wiper delay timer which is also very similar to the interior light timer. Just different timer settings.It's under the passenger seat. It will have.... Black............. ground Black/Red..... Driver's side door, grounds to turn light on, sets timer when door closed. Red/Black..... passenger side door, grounds to turn light on, sets timer when door closed. Red/Blue ..... power at all times from the #13 fuse 3 from the right side. BrownRed ... grounds the interior lamp to turn it on. King Cab does have a 3 way switch on the dome light to turn room lamp off. 1 Quote Link to comment
