Sign in to follow this
rinigado
clutch line specs
I was just about to swap my clutch master and slave cylinders and see that the existing nut connecting the clutch hard line to the master cylinder is pretty chewed up. Is the clutch hard line here same spec as brake lines (3/16" line, m10x1.0 fittings)? I'll have to see if the LAPS has a length of line that's suitable.
Share this post
Link to post
Get the proper size brake flare nut wrench for this.
2012-02-05-17.12.10-flare-wrench-e132848
Share this post
Link to post
Yep. That's what went wrong with the existing nut...looks like a combination of wrong wrench and vise grip teeth screwed it up.
Share this post
Link to post
thanks shacks510. In case anyone else ever wonders the length on a 240z, I measured the line at just under 51" after pulling it off the car. Now for a quick run to O'Reilly for a 51" brake line. Glad it's a stocked length!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
