Riceball Posted November 21, 2016 Report Share Posted November 21, 2016 Hi all Need some help. Can someone inform me of the possibility of cutting the two intake ends apart and bolting them onto an L20B with W58 head. I'm trying to find a intake solution to modify for fuel injection and forced induction. Thought I remembered someone posting that the manifold pattern on the two end ports match the L20B heads. My plan is to fab this to accommodate forced induction intake. I can't seem to attach a picture, but I the question is regarding a 280Z N74 intake Thanks in advance 1 Quote Link to comment
Lockleaf Posted November 21, 2016 Report Share Posted November 21, 2016 This seems to be an old thread but if anyone is interested: About 20 years ago when I built a EFI L18 510 for a customer/friend. I used a 280 Z ,manifold, cut out the two center runners, reworked the plenum to match up.. That was the most difficult part on the manifold as when the center was cut out there was a mismatch in alignment. I used the EFI parts from a 200sx and electronic ignition distributer from a later l20. I was able to tweak the air flow meter and some other settings. It worked out great. I don't remember a lot of the details after 20 years but I built some pretty mean 510s before I turned the shop over to my son. I probably notched the intake ports to be like the 280. 1 Quote Link to comment
datzenmike Posted November 21, 2016 Report Share Posted November 21, 2016 Yes it was done to an EFI intake but 10 years ago maybe. I think you need the earliest intake that is parallel to the head Because if the intake plenum is not parallel with the head, but angles towards it, when the center section is cut out, the front does not line up with the rear. I think the cure was to shorten the front two runners or lengthen the rear two runners so the two halves aligned for welding. It's not a case of cut out the center and weld them together. It's certainly do-able but tricky. Anyway this guy found the right intake... One obvious thing is the front two cylinders are forcing the air to make a more than 90 degree bend. Here's the post... http://community.ratsun.net/topic/2165-project-ghetto-efi/ 3 Quote Link to comment
Riceball Posted November 21, 2016 Author Report Share Posted November 21, 2016 Hi Lockleaf Thanks for the info. Do you happen to recall if the mounting holes on the intake runners to head line up. 1 Quote Link to comment
datzenmike Posted November 21, 2016 Report Share Posted November 21, 2016 You have to drill and tap single holes between each runner on the head. The L 4 cylinder heads have two that don't match. 1 Quote Link to comment
bananahamuck Posted November 21, 2016 Report Share Posted November 21, 2016 Here's one i got from HRH that i think his friend welded up for him,,, mounting hole is oblong because they miscalculated when they drilled it ,, and notice they cut tubes to angle the flange better.. No order to pictures as i just went out and snapped a few just now. It is just laying on another engine to get snaps. It's in a thread somewheres but i don't know what it's called not sure why they are all upside down though. 1 Quote Link to comment
Lockleaf Posted November 21, 2016 Report Share Posted November 21, 2016 Wasn't me who did it, just passing on info I saw 1 Quote Link to comment
LenRobertson Posted November 21, 2016 Report Share Posted November 21, 2016 If you haven't seen HRH's thread: http://community.ratsun.net/topic/22074-510-l20b-efi-conversion-the-project-is-finished/ you may find some useful information there. Unfortunately most of the pics are missing. Len 1 Quote Link to comment
