datzenmike Posted May 9, 2020 Report Share Posted May 9, 2020 Still good for the differential. 1 hour ago, mainer311 said: You can always just get the GL-4 manual trans fluid from the dealer. I’ve tried Amsoil and Redline. They don’t really make any difference in these old transmissions. Protection wise it's way above over kill but for how well it acts.... well worth the price. Faster, easier, smoother shifting when cold and after warm up. Silky smooth downshift without grinding. It can't fix a broken transmission but it gets rid of annoying things that thick 90w oil does. 1 Quote Link to comment
fivetenguy Posted May 9, 2020 Report Share Posted May 9, 2020 I got some gl4 from nissan. I can get the part number when I get home from work. 1 Quote Link to comment
d.p Posted May 9, 2020 Author Report Share Posted May 9, 2020 Thanks guys, will pick some up from the dealer. Also my side view mirror went limp and the only way for me fix it was break the glass that was glued into it. I don't even know if this is an OEM mirror, is it? if so I assume the glass was originally glued in as well? After I got the glass and inch worth of glue off this is what I am left with: Its apparent why it got loose because if you turn it left or right the screw backs out or in. Not to mention its bent like a crooked wiener. I guess I am going to get a new screw and try to figure out a way to let it articulate without backing the screw out at the same time. 1 Quote Link to comment
d.p Posted May 9, 2020 Author Report Share Posted May 9, 2020 57 minutes ago, fivetenguy said: I got some gl4 from nissan. I can get the part number when I get home from work. Is this it? https://www.courtesyparts.com/oem-parts/nissan-75w85-manual-trans-fluid-must-ship-via-standard-ground-no-usps-999mpmtf00np 2 Quote Link to comment
mainer311 Posted May 9, 2020 Report Share Posted May 9, 2020 1 hour ago, d.p said: My dumbass ordered some NAPA and it ended up being gl5. Nissan dealer sell gl4? Shit is hard to come by in store. N Yes, they do. It’s not cheap, but neither is the Redline or Amsoil. 1 Quote Link to comment
mainer311 Posted May 9, 2020 Report Share Posted May 9, 2020 27 minutes ago, d.p said: Is this it? https://www.courtesyparts.com/oem-parts/nissan-75w85-manual-trans-fluid-must-ship-via-standard-ground-no-usps-999mpmtf00np Yep. Great price too. 1 Quote Link to comment
thisismatt Posted May 10, 2020 Report Share Posted May 10, 2020 (edited) I found this tranny for you on one of my local Facebook groups. Even comes with the shifter. Maybe Mike can identify... Edited May 10, 2020 by thisismatt 1 1 Quote Link to comment
datzenmike Posted May 10, 2020 Report Share Posted May 10, 2020 Manual sconce 1 1 Quote Link to comment
d.p Posted May 10, 2020 Author Report Share Posted May 10, 2020 @thisismatt Maybe you should buy that tranny and then never put it to use like all the other shit you buy. 1 1 Quote Link to comment
wayno Posted May 10, 2020 Report Share Posted May 10, 2020 (edited) Looks like someones home made door light assembly to me. Edited May 10, 2020 by wayno 1 Quote Link to comment
fivetenguy Posted May 10, 2020 Report Share Posted May 10, 2020 (edited) 10 hours ago, fivetenguy said: I got some gl4 from nissan. I can get the part number when I get home from work. Part number 999MP-MTF00NP I believe this stuff is gl4, but not 100% sure. I just read everything on the bottle, but it does not state what GL it is. I hope it is because I put it in one of my transmissions. Edited May 10, 2020 by fivetenguy 1 Quote Link to comment
fivetenguy Posted May 10, 2020 Report Share Posted May 10, 2020 (edited) 9 hours ago, d.p said: Is this it? https://www.courtesyparts.com/oem-parts/nissan-75w85-manual-trans-fluid-must-ship-via-standard-ground-no-usps-999mpmtf00np I didn't see this post before I posted mine. That's the exact bottle I have. Only the part number on mine does not have the N in it. I bought mine at least 6-7 years ago. You probably got the new part number. I looked my part number up and it does not exist any longer. I will edit my previous post so people don't look up the wrong part number. Edited May 10, 2020 by fivetenguy 1 Quote Link to comment
thisismatt Posted May 10, 2020 Report Share Posted May 10, 2020 1 hour ago, d.p said: @thisismatt Maybe you should buy that tranny and then never put it to use like all the other shit you buy. ooooooh 2 Quote Link to comment
gene knight Posted May 10, 2020 Report Share Posted May 10, 2020 10 hours ago, mainer311 said: Yes, they do. It’s not cheap, but neither is the Redline or Amsoil. i got 2 gallons of GL4 from amazon 1 Quote Link to comment
d.p Posted May 10, 2020 Author Report Share Posted May 10, 2020 6 hours ago, gene knight said: i got 2 gallons of GL4 from amazon 2 gallons of the Nissan stuff? Quote Link to comment
KELMO Posted May 10, 2020 Report Share Posted May 10, 2020 What the hell, I'll chime in too. Been using the NAPA Sta-Lube gear oil for years. 85W90 multi purpose hyoid The label says API/GL-4 Part # SL24239 (Gallon jug) If memory serves, it's about $30.00 per gallon. BTW, I work at a Nissan dealer. I'll read some bottles tomorrow. Seems I have seen one or two that say GL4. Quote Link to comment
wayno Posted May 10, 2020 Report Share Posted May 10, 2020 I use Sta-lube also, the container says GL4 on it, when I bought it last(3 years ago??) it was available at the local auto parts store(Baxters), don't know if it's available there anymore. The price quoted above sounds about right, but it has been a while. Quote Link to comment
d.p Posted May 10, 2020 Author Report Share Posted May 10, 2020 @banzai510(hainz) is this the same clutch setup that Datsunparts sells? https://www.ebay.com/itm/233202857988 Quote Link to comment
d.p Posted May 10, 2020 Author Report Share Posted May 10, 2020 Amazon has the Stalube for $28 CRC 24239 Multi-Purpose Gear Oil 85W90 SAE-Gallon, 128. Fluid_Ounces https://www.amazon.com/dp/B000M8RYMC/ref=cm_sw_r_cp_api_i_ppjUEbV47YRSD Quote Link to comment
mainer311 Posted May 11, 2020 Report Share Posted May 11, 2020 2 hours ago, d.p said: @banzai510(hainz) is this the same clutch setup that Datsunparts sells? https://www.ebay.com/itm/233202857988 I believe Dean sells genuine Nissan 650kg pressure plates with an Exedy friction disc. That eBay link says 600kg, and everything is Exedy. That’s the brand I used when I had my transmission out. Seems like good quality stuff. Quote Link to comment
banzai510(hainz) Posted May 11, 2020 Report Share Posted May 11, 2020 Good price Quote Link to comment
d.p Posted May 11, 2020 Author Report Share Posted May 11, 2020 (edited) 11 hours ago, mainer311 said: I believe Dean sells genuine Nissan 650kg pressure plates with an Exedy friction disc. That eBay link says 600kg, and everything is Exedy. That’s the brand I used when I had my transmission out. Seems like good quality stuff. Does the PP really matter? Everything else in that kit is the same as far as I can tell. And Exedy = Daikin. "Yes we verified the clamping force/ load test. Exedy's design department dug out the blueprint and we have it. You wipe off the Dust. A great, less expensive, alternative to the Nissan kits with a great reputation. Comes with Japanese disc, throw-out bearing, pilot bearing & clutch dowels. Use for any 1600 or 2000. If it don't say NSC-581 it ain't heavy duty!" 10 hours ago, banzai510(hainz) said: Good price yeah it is and nothing against datsunparts but the guy who runs it just comes across so crass when I ask a question, turns me off from buying anything from him. EDIT: Wait the PP in that auction is the same one Dean sells, except the brand name which is the same company. NS581 "NSC - 581 NLA Heavy duty 600 kilogram Clutch Pressure plate" Both say 600 so assuming they are the exact same thing just cheaper on Ebay. And Mainer I referring to the 1483DAIKIN part on Deans site and not the other more expensive kits. Edited May 11, 2020 by d.p Quote Link to comment
d.p Posted May 11, 2020 Author Report Share Posted May 11, 2020 Can anyone tell me difference between this thermostat housing and a stock one? What would the water outlet be used for? https://www.ebay.com/itm/Datsun-510-Pick-Up-610-620-L16-L18-240Z-Genuine-Thermostat-Housing-Gaskets-OEM/313069755647?hash=item48e4695cff:g:AjQAAOSwaKxeo3ZG Quote Link to comment
datzenmike Posted May 11, 2020 Report Share Posted May 11, 2020 This one has a threaded T V V for the EGR (not used on a 521) facing you. I plugged mine on my 710 with a hex plug I scooped from a KA intake. The L series were all the same except some of the later z cars had up to four threaded holes for sensors for the EFI, some of the early ones didn't have coolant by pass and relied on a juggle valve. In '79 they all changed to 3 bolt top cover. I think we have more than one post on Datsunparts and what they're like. 600 or 650kg is more than enough grip. Car L20Bs are 400-450kg and truck L20Bs-Z24s 500-550kg. Quote Link to comment
d.p Posted May 11, 2020 Author Report Share Posted May 11, 2020 Just now, datzenmike said: This one has a threaded T V V for the EGR (not used on a 521) facing you. I plugged mine on my 710 with a hex plug I scooped from a KA intake. I think we have more than one post on Datsunparts and what they're like. 600 or 650kg is more than enough grip. Car L20Bs are 400-450kg and truck L20Bs-Z24s 500-550kg. Thanks Mike, any idea what the thread/pitch is? I will just scoop the ebay clutch kit. I was looking at Datsunparts dual choke cables but they are pricey and again if the dude selling them is painful then I will just look elsewhere. Do you have a link to a post about them? I know the rep about California Datsun but didn't know Datsun parts had a bad one as well. 1 Quote Link to comment
