d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 Can someone merge my two threads? Would prefer to keep the other one. Not looking to slam it, just lower it and get some wheels flush with the fenders. Stock sits so far inside it should be illegal. Quote Link to comment
banzai510(hainz) Posted November 16, 2016 Report Share Posted November 16, 2016 I think just lower it with the stock wheels as it will get the tire to the rim within reason using 3 inch algle blocks( Belltech 2602) in back and just turin the torsion bar screws out. If you put the chevy ralley on there with 50 series you need to go lower to get the tire top near to close to flush with the fender. then you have to get bigger blocks and reindex the torsion bar then other issues make proplems for a daily driver , to me is not worth it. Quote Link to comment
thisismatt Posted November 16, 2016 Report Share Posted November 16, 2016 Thanks dubdlux, I used a pry bar to get them off but still managed to jam the shit out of my index finger. I don't know the build date, where can I find that? Got a link to the cube relay? I can do that no problem just need to know what to buy. I really want to get that cigarette lighter working and whats odd is that the black wire in the picture below is hanging down from dash in my truck, its not connected to the back of the lighter like the picture shows. That's correct. The second pic is not correct for a 521. Quote Link to comment
d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 That's correct. The second pic is not correct for a 521. What is correct? I assume I need to find the LgR wire and source the correct lighter for the truck? Took a look and there are more wires tucked up behind it and one that looks like it connects to the lighter (#1 in the pic below). 2 is the antenna but no idea what 3,4 and 5 go to. I think just lower it with the stock wheels as it will get the tire to the rim within reason using 3 inch algle blocks( Belltech 2602) in back and just turin the torsion bar screws out. If you put the chevy ralley on there with 50 series you need to go lower to get the tire top near to close to flush with the fender. then you have to get bigger blocks and reindex the torsion bar then other issues make proplems for a daily driver , to me is not worth it. Belltech 2602 is the part number for the blocks? Google didn't return anything for them. And I will lower it with the stock wheels because that's all I got right now, have a lead on some rallye wheels but they are a little far from me. Quote Link to comment
DanielC Posted November 16, 2016 Report Share Posted November 16, 2016 You can use the KC3300 relay from summit racing. Check for 12 volts on the female bullet connector hanging down by the cigarette lighter. Many Datsun 521 wires have a black plastic sleeve over the actual wire. The build date is on a tag, on the drivers side door frame, toward the back of the cab. Quote Link to comment
d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 You can use the KC3300 relay from summit racing. Check for 12 volts on the female bullet connector hanging down by the cigarette lighter. Many Datsun 521 wires have a black plastic sleeve over the actual wire. The build date is on a tag, on the drivers side door frame, toward the back of the cab. This it? https://www.amazon.com/KC-HiLiTES-3300-12V-Relay/dp/B0002MAE0M Got a pic of it installed in your truck? Bullet connector has 12 volts with the truck on so that's probably it? Build date is 11/70. I need the plastic switch for the heater and a replacement side mirror, or just the mirror but not sure I can source that. Anyone have a lead on either? Quote Link to comment
banzai510(hainz) Posted November 16, 2016 Report Share Posted November 16, 2016 the cig lighter is the black wire I believe. Its on the Common circut meaning Its has 12volts all the time. When you push the cig plunger in it shorts thus heating the element. Common circut on Datsuns means the cig lighter dome light and door buzzer most of the time. 12volt with key ON is for radio or heater or soemthing else depending on the size of the wire. thos eblack box relays you can get anywhere. most are made in China but you can go to the Junk yard in the ignition elelctrical box are full of them. Gfind the Jap or German made one and stack them up!!!!!!!!!!!! 1 Quote Link to comment
d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 the cig lighter is the black wire I believe. Its on the Common circut meaning Its has 12volts all the time. When you push the cig plunger in it shorts thus heating the element. Common circut on Datsuns means the cig lighter dome light and door buzzer most of the time. 12volt with key ON is for radio or heater or soemthing else depending on the size of the wire. thos eblack box relays you can get anywhere. most are made in China but you can go to the Junk yard in the ignition elelctrical box are full of them. Gfind the Jap or German made one and stack them up!!!!!!!!!!!! #1 black wire? You're right, it does have constant power, connected it to the lighter and it worked. Wonder why it was disconnected. Quote Link to comment
banzai510(hainz) Posted November 16, 2016 Report Share Posted November 16, 2016 they just fall out soemtimes Quote Link to comment
d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 (picture of differential) Normal. If front at the driveshaft is wet the pinion seal may need replacing. In any case if you buy be sure to empty and replace the differential oil with GL-5 80w90. There's no telling when it was replaced last. Should be checked every 15K and changed every 30K miles. (picture of front trans and engine oil pan) Looks like caked on dirt not wet with oil. This will power wash off. If there were fresh drips I would be more concerned. (picture of transmission underside) Bottom transmission pan is clean and any oil has transferred back from the engine by the wind. Again replace the transmission oil with GL-4 80w90 NOT GL-5. Check every 15K and change every 30K miles. (picture of valve cover and starter) Hard to tell. If dipstick has lost the rubber seal blow-by will wet the block nearby. Oil senders can sometimes weep oil. The fuel pump should have two gaskets and a plastic spacer between them. These can leak and also the pivot pin on the pump body. Best to power wash and de-grease with brake cleaner and watch for wetness... then fix. Over all I would just replace the valve cover gasket the biggest and most likely cause of an oil leak. Last is the crank pulley seal. These get old and drip and the fan and normal air blowing past spreads it over the engine. Check behind the crank pulley for wetness or a drip. But do the valve cover first as oil flows down hill. Revisiting this, its definitely leaking oil but not sure from where. Looks to be maybe the head gasket? Valve cover is dry, but its wet on the passenger rear side where the block meets the head and obviously below it. dubdlux replaced pretty much every gasket/seal except for the head. I found the plastic heater switch, but no way to attach it, does it use a screw? Quote Link to comment
Elkie Posted November 16, 2016 Report Share Posted November 16, 2016 Is that a stock blue? Looks unfamiliar to me. Quote Link to comment
d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 Is that a stock blue? Looks unfamiliar to me. Yeah as far as I know. What looks off about it? Quote Link to comment
DanielC Posted November 16, 2016 Report Share Posted November 16, 2016 There is a screw that goes in from the side of the fat part of the heater control lever. I believe it is a #4-40 screw. Before you put the heater knob back on, make sure the shaft it goes on rotates fairly easily. it only rotates a 1/4 turn, but that is enough to go from full flow, to shut off. Quote Link to comment
DanielC Posted November 16, 2016 Report Share Posted November 16, 2016 There is a good possibility that the truck is a "stock blue" The paint looks to be in very good condition, but also it could have been repainted. There is also a possibility that the truck lived a charmed life, and was garaged. Are there some stickers on the top of the radiator support, one having some emission control information, and another with the paint code? The wheels were repainted. Stock, they are grey. What do the floors look like in the truck. How much rust damage? Quote Link to comment
Stoffregen Motorsports Posted November 16, 2016 Report Share Posted November 16, 2016 This it? https://www.amazon.com/KC-HiLiTES-3300-12V-Relay/dp/B0002MAE0M Got a pic of it installed in your truck? Bullet connector has 12 volts with the truck on so that's probably it? Build date is 11/70. I need the plastic switch for the heater and a replacement side mirror, or just the mirror but not sure I can source that. Anyone have a lead on either? These guys always have a ton of stuff on their website, though I've never purchased from them before. http://www.new-datsun-parts.com/datsun-pickup-parts.html Quote Link to comment
banzai510(hainz) Posted November 16, 2016 Report Share Posted November 16, 2016 Hope you don't have to much OCD . Cause Datsuns at this age leak oil. Otherwise youll have to replace the head gasket if it really bothers you. Then next oil pan gasket. ooil sender switch may leak also. then the front and real seal. I wish I had this truck!!!!!!!!!!!!!!!!!!! I just leave my heater ON. as it don't put out much heat anyways but enough to keep me from freezing 1 Quote Link to comment
d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 There is a good possibility that the truck is a "stock blue" The paint looks to be in very good condition, but also it could have been repainted. There is also a possibility that the truck lived a charmed life, and was garaged. Are there some stickers on the top of the radiator support, one having some emission control information, and another with the paint code? Yeah they are there but the paint code is blank where it usually would be. I couldn't find any evidence of a respray either but I am not a professional by any means. 1 Quote Link to comment
d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 Hope you don't have to much OCD . Cause Datsuns at this age leak oil. Otherwise youll have to replace the head gasket if it really bothers you. Then next oil pan gasket. ooil sender switch may leak also. then the front and real seal. I wish I had this truck!!!!!!!!!!!!!!!!!!! I just leave my heater ON. as it don't put out much heat anyways but enough to keep me from freezing Going to make you wish had it even more because 99% of seals have already been replaced... head gasket the only that wasn't. New seals including rear main, timing cover, valve cover, valve stem, and oil pan (2010) New oil pressure switch (2016) New front main seal (2016) So might as well do that one and button up whatever else I can find. Also I think the heater is on already, but I would still like the switch to work. What are people doing about radios in these? More pics: 2 Quote Link to comment
d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 These guys always have a ton of stuff on their website, though I've never purchased from them before. http://www.new-datsun-parts.com/datsun-pickup-parts.html Yeah I emailed them already, waiting to hear back. 2 Quote Link to comment
DanielC Posted November 16, 2016 Report Share Posted November 16, 2016 That is one of the best looking 521 trucks I have seen! I know it is your truck, but if I had it, I would be trying to get it as close to factory showroom stock as possible. 1 Quote Link to comment
banzai510(hainz) Posted November 16, 2016 Report Share Posted November 16, 2016 Radios?????????? I keep MINE stock am radio. I was hoping someone was going to steal it but all I get is other 521 AM radios thrown on the seat. SO i guess its a anti thef device. Really I tried to pull mine out and gave up . too much hassle and I listen to am radio in the morning anyways 1 Quote Link to comment
d.p Posted November 16, 2016 Author Report Share Posted November 16, 2016 Haha. Well I would need a speaker for mine as its MIA. Found out today the wipers don't work so well, the move fine but only actually touch 1/3 of the glass. Anyone recommend a good pair? 1 Quote Link to comment
hobospyder Posted November 16, 2016 Report Share Posted November 16, 2016 Stock and or rain x 1 Quote Link to comment
banzai510(hainz) Posted November 16, 2016 Report Share Posted November 16, 2016 I run 16inch wipers. Just the way it is on these. 1 Quote Link to comment
DanielC Posted November 16, 2016 Report Share Posted November 16, 2016 The wiper arms on a 521 are just pushed on the post coming out of the cowl, and it is the same size as a lot of American cars. Remember, the body dimensions of a 521 are measured in inches. You can get new wiper arms at most any auto parts store, with a stronger (newer) spring. 1 Quote Link to comment
