d.p Posted January 16, 2021 Author Report Share Posted January 16, 2021 So in the above picture I would jump White/Red stripe to White/Black stripe and White to Yellow? Quote Link to comment
datzenmike Posted January 16, 2021 Report Share Posted January 16, 2021 Top, Yellow/ Black stripe is the oil pressure sender. The Black/Yellow stripe is the starter signal to solenoid The one left over with the round lug..... don't know. What color is the wire? Black wire with lug grounds to the alternator case. Usually there is a bolt for this Plastic plug is self explanatory. White/Red stripe is the power out and goes to an insulated stud on back of alternator. The color wires for the 510 are... . Black White/Black Yellow White White/Blue White/Red Sometimes the white ages to a tan or yelowish brown. Use that plug and join the White/Blue Black and White/Red together. Now join the solid White to the solid Yellow. Pull any left over wires out so they never cause any problems. Plug into harness and done. Always solder and tape carefully or remember to slide some heat shrink tubing on and look professional. 1 Quote Link to comment
d.p Posted January 16, 2021 Author Report Share Posted January 16, 2021 Thanks Mike. That one starter wire is YELLOW. And duh forgot all about oil pressure sender wire. white/blue or white/black to white/red?! 1 Quote Link to comment
thisismatt Posted January 17, 2021 Report Share Posted January 17, 2021 (edited) WR to WB(lack) Edited January 17, 2021 by thisismatt 3 1 Quote Link to comment
datzenmike Posted January 17, 2021 Report Share Posted January 17, 2021 Thanks Matt yes WB, of course. If you have other than a 510 and it has electric choke this needs a couple more things done to it, but for a 510 it's good as is. 1 Quote Link to comment
thisismatt Posted January 17, 2021 Report Share Posted January 17, 2021 Yes, diagram was for a 510 but 521 is the same. 1 Quote Link to comment
d.p Posted January 17, 2021 Author Report Share Posted January 17, 2021 Got the switch done. Now I need to extend the reverse light wires as they won’t reach then new 5 speed. Would really like to delete the unused trans wires but not sure I have enough motivation to pull all those looms apart to remove them. 1 Quote Link to comment
datzenmike Posted January 17, 2021 Report Share Posted January 17, 2021 Reverse lights switch on the 4 speed is in the tail. The 71B reverse switch is at the front behind the clutch fork.... it should reach easily. Quote Link to comment
d.p Posted January 17, 2021 Author Report Share Posted January 17, 2021 11 minutes ago, datzenmike said: Reverse lights switch on the 4 speed is in the tail. The 71B reverse switch is at the front behind the clutch fork.... it should reach easily. Even so wires aren’t close at all. The harness wires are all loomed up and I got no interest in cutting it open. also the new reverse switch in bought is garbage. Basically fell apart in my hand. Was NOS too. Quote Link to comment
datzenmike Posted January 17, 2021 Report Share Posted January 17, 2021 There's no such thing as NOS. It's a myth. Doesn't the wire harness for the transmission come from the engine bay??? 1 Quote Link to comment
thisismatt Posted January 17, 2021 Report Share Posted January 17, 2021 Mike, you always say that, but that doesn't mean it's true. I have boxes of NOS parts... d.p. if the wires aren't long enough, probably the cleanest thing would be to buy matching bullet connectors and just make some extension pigtails. Unused wires I would use adhesive heatshrink to seal the ends and then loop them back onto the harness with some larger heatshrink. 1 1 Quote Link to comment
mainer311 Posted January 17, 2021 Report Share Posted January 17, 2021 Two words: solder sleeves. 1 Quote Link to comment
d.p Posted January 17, 2021 Author Report Share Posted January 17, 2021 I just took my old switch and spliced some wire into them. Wanted to do it to the new one but it died before I could. 2 Quote Link to comment
d.p Posted January 17, 2021 Author Report Share Posted January 17, 2021 (edited) And yes mike it comes from the engine side but it’s wrapped in a loom with a bunch of other wires that run the length of the truck. Those harness wires come off the frame way past the switch on the 280zx trans. So you have to make the wires longer or cut open the loom and pull the reverse wires out. Edited January 17, 2021 by d.p 1 Quote Link to comment
datzenmike Posted January 17, 2021 Report Share Posted January 17, 2021 New Old Stock or New Obsolete Stock..... original part never sold (although if sold and in original package unopened just barely under the wire) This does not include counterfeit packaging around re-popped parts. Nor parts made from original tooling that there is no Nissan quality oversight on. Nor a cleaned up used wrecker part with new wrapper. If it's a '71 510 wiper motor it's going to be at least 50 years old. If you bought them from a dealer probably, I won't say not. Anything else is just say so. Lots of people have no idea what JDM and NOS really means they just throw it into for sale ads. Carpe Diem... let the buyer beware 1 Quote Link to comment
datzenmike Posted January 17, 2021 Report Share Posted January 17, 2021 1 minute ago, d.p said: And yes mike it comes from the engine side but it’s wrapped in a loom with a bunch of other wires that run the length of the truck. Those harness wires come off the frame way past the switch on the 280zx trans. So you have to make the wires longer or cut open the loom and pull the reverse wires out. Didn't know but makes sense seeing as where the fuse box location is. My 710 transmission switch wires pass over the starter on their way. Well good to know. 1 Quote Link to comment
greenthumb Posted January 17, 2021 Report Share Posted January 17, 2021 1 hour ago, datzenmike said: New Old Stock or New Obsolete Stock..... original part never sold (although if sold and in original package unopened just barely under the wire) This does not include counterfeit packaging around re-popped parts. Nor parts made from original tooling that there is no Nissan quality oversight on. Nor a cleaned up used wrecker part with new wrapper. If it's a '71 510 wiper motor it's going to be at least 50 years old. If you bought them from a dealer probably, I won't say not. Anything else is just say so. Lots of people have no idea what JDM and NOS really means they just throw it into for sale ads. Carpe Diem... let the buyer beware Caveat emptor? 😬 1 Quote Link to comment
datzenmike Posted January 17, 2021 Report Share Posted January 17, 2021 Congrats! You get 10 internet points and a Tim's coffee for getting that. 1 1 Quote Link to comment
mainer311 Posted January 18, 2021 Report Share Posted January 18, 2021 Tim’s coffee? I rather go steep some moose poop. 1 Quote Link to comment
datzenmike Posted January 18, 2021 Report Share Posted January 18, 2021 What I find is that it's the same anywhere in Canada and no vile surprises when traveling and you just got to have that coffee taste.. I absolutely refuse to drink burnt acid Starbucks over the top priced fashion accessory coffees. McDees isn't bad now but used to be terrible. Changed in late '90s??? 2 Quote Link to comment
Charlie69 Posted January 18, 2021 Report Share Posted January 18, 2021 (edited) 6 hours ago, datzenmike said: There's no such thing as NOS. It's a myth. Doesn't the wire harness for the transmission come from the engine bay??? I have been buying OEM NOS parts since the seventies. I recently sold my last OEM/NOS speedometer in the original box would you like to see pictures? I have several OEM/NOS parts left. I bought out all the 520/521 & 320 truck parts from ABC Datsun/Nissan in the 90s. I buy OEM/NOS parts when I can find them. Maybe in Canada there is no such thing but here in the USA and other countries OEM/NOS parts do exist. I sold a OEM/NOS 520/521 windshield to Chris for his wife's 521 so they could get it out of the garage. This still had the plastic and the Nissan part # on it from ABC Nissan. This was a few years ago. Edited January 18, 2021 by Charlie69 2 Quote Link to comment
thisismatt Posted January 18, 2021 Report Share Posted January 18, 2021 7 hours ago, datzenmike said: New Old Stock or New Obsolete Stock..... original part never sold (although if sold and in original package unopened just barely under the wire) This does not include counterfeit packaging around re-popped parts. Nor parts made from original tooling that there is no Nissan quality oversight on. Nor a cleaned up used wrecker part with new wrapper. If it's a '71 510 wiper motor it's going to be at least 50 years old. If you bought them from a dealer probably, I won't say not. Anything else is just say so. Lots of people have no idea what JDM and NOS really means they just throw it into for sale ads. Carpe Diem... let the buyer beware I guess I'll throw this and more in the trash, then... 4 Quote Link to comment
Charlie69 Posted January 18, 2021 Report Share Posted January 18, 2021 Matt trumps me. Nice hoard Matt. 1 1 Quote Link to comment
banzai510(hainz) Posted January 18, 2021 Report Share Posted January 18, 2021 (edited) Like I said use the 4seped T/O bearing and collar. Its a 600kg clutch it should be stiff. the farther you move the clutch fork towards the rea the more your pushing on the clutch fingers. You want the clutch fork to go forward when released. then you adjust the ball and nut right up to it for about a 1/16 play. so when you push the pedal then the fork will go rearward and push on the pressureplate fingers. your doing to many thing at once and going to indruduce a proplem . example alternator swap ect….. make sure you don't have a auto choke otherwise battery goes dead Edited January 18, 2021 by banzai510(hainz) Quote Link to comment
datzenmike Posted January 18, 2021 Report Share Posted January 18, 2021 10 hours ago, thisismatt said: I guess I'll throw this and more in the trash, then... Noooooooooo Quote Link to comment
