d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 Thanks @DanielC any idea if a 510 filler plug is the same thread pitch as the 521? Saw mike posted part # 48060 U2000 and found people using these as well on 510s: https://www.mcmaster.com/9847K13/?SrchEntryWebPart_InpBox=%239847K13 which are 3/8 BPST. 1 Quote Link to comment
datzenmike Posted December 27, 2020 Report Share Posted December 27, 2020 4 hours ago, d.p said: Can someone tell me how to measure how much I need to shorten my driveshaft? Like from where to where do I measure? Stock 521 4 speed is just a c hair over 26" the 71B 4 and 5 speeds are 31.5" so the difference is just a c hair under 5.5" removed from the front drive shaft to allow it to fit. 2 Quote Link to comment
DanielC Posted December 27, 2020 Report Share Posted December 27, 2020 (edited) I believe 510's are metric, so I would not think so. But if the steering box on a 510, and a 521 are thread the same, it could work. Datzenmike just replied. About the driveshaft. Edited December 27, 2020 by DanielC 1 Quote Link to comment
d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 (edited) 39 minutes ago, datzenmike said: Stock 521 4 speed is just a c hair over 26" the 71B 4 and 5 speeds are 31.5" so the difference is just a c hair under 5.5" removed from the front drive shaft to allow it to fit. Thanks man,,any idea on the steering gear filler plug replacement? Do these have a slit in the bottom to allow them to vent? Edited December 27, 2020 by d.p 1 Quote Link to comment
datzenmike Posted December 27, 2020 Report Share Posted December 27, 2020 Same one is also used on the 620 box. No need for venting the steering box does not get hot enough. The one in my 710 is also rubbery too and fits 510/610/B210/210/A10/S10/S110 and 810. I don't know why car ones are a different part number. Also a different number doesn't always mean it won't fit. 1 Quote Link to comment
d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 So a 510 gear plug will fit a 521? 19 minutes ago, datzenmike said: Same one is also used on the 620 box. No need for venting the steering box does not get hot enough. The one in my 710 is also rubbery too and fits 510/610/B210/210/A10/S10/S110 and 810. I don't know why car ones are a different part number. Also a different number doesn't always mean it won't fit. 1 Quote Link to comment
datzenmike Posted December 27, 2020 Report Share Posted December 27, 2020 No where does it say that. It says the 620 used the same one. It also says the car ones are a different part number 1 Quote Link to comment
d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 Ahh fuck me 620 one seems to be NLA as well. I really just need the thread and pitch so I can get something else. 1 Quote Link to comment
Crashtd420 Posted December 27, 2020 Report Share Posted December 27, 2020 17 minutes ago, d.p said: So a 510 gear plug will fit a 521? I'm 99% certain an npt plug fits it..... I have a spare steering column in the basement.... I can pull the plug out and verify the npt size you need.... Just give me a day... 2 Quote Link to comment
d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 (edited) Thanks crash. I bought a 3/8” NPT and it doesn’t thread but that’s all they had that looked like it might work. Edited December 27, 2020 by d.p 2 Quote Link to comment
d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 Stock vs 3/8 NPT: 2 Quote Link to comment
Crashtd420 Posted December 27, 2020 Report Share Posted December 27, 2020 3 minutes ago, d.p said: Stock vs 3/8 NPT: Yup that's what I am using, just checked... 2 Quote Link to comment
d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 (edited) 1 minute ago, Crashtd420 said: Yup that's what I am using, just checked... interesting, I wonder why it doesnt thread in all the way for me? Edited December 27, 2020 by d.p 1 Quote Link to comment
Crashtd420 Posted December 27, 2020 Report Share Posted December 27, 2020 Oh it didnt thread.... then its bspt.... I think I chased the threads.... You can take the plate off and run a 3/8-18 npt tap into it... 2 Quote Link to comment
d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 (edited) Cant I just chase it without taking the plate off? put some grease on the the tap to catch the shavings? Edited December 27, 2020 by d.p 1 Quote Link to comment
Crashtd420 Posted December 27, 2020 Report Share Posted December 27, 2020 Just now, d.p said: Cant I just chase it without taking the plate off? put some grease on the the tap to catch the shavings? I thought I want supposed to do that because of the worm gear and putting it back together. Ya you can do that too.... You wont disturb the worm gear only the adjuster.... The grease would be easier.... You don't make a lot of chips... 3 Quote Link to comment
d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 (edited) I went ahead and ordered a 3/8 BPST male plug from McMaster-Carr and if that doesn't work Ill chase it with 3/8-18 and use that nylon plug. Edited December 27, 2020 by d.p 2 Quote Link to comment
datzenmike Posted December 27, 2020 Report Share Posted December 27, 2020 D.P. I can't see any reason for a soft plug except that maybe because it can't be tightened at all and doesn't seal that well and might act as a vent. 2 Quote Link to comment
d.p Posted December 27, 2020 Author Report Share Posted December 27, 2020 Just now, datzenmike said: D.P. I can't see any reason for a soft plug except that maybe it can't be tightened at all and doesn't seal that well and might act as a vent. The bottom of my soft plug is cracked/split so I was just trying to replace it with something that isn't damaged. 2 Quote Link to comment
mainer311 Posted December 28, 2020 Report Share Posted December 28, 2020 (edited) Original plugs were plastic that softened over time from being exposed to petroleum. (Kinda like the factory natural rubber ball joint boots.) Factory roaster steering box plug is a straight metric thread. I suppose the truck could be BSPT, but I doubt it. The plug you posted above doesn’t look tapered to me. If you find a replacement plug that works, and it’s plastic, I would only install it hand tight. Edited December 28, 2020 by mainer311 2 Quote Link to comment
d.p Posted December 28, 2020 Author Report Share Posted December 28, 2020 (edited) 50 minutes ago, mainer311 said: Original plugs were plastic that softened over time from being exposed to petroleum. (Kinda like the factory natural rubber ball joint boots.) Factory roaster steering box plug is a straight metric thread. I suppose the truck could be BSPT, but I doubt it. The plug you posted above doesn’t look tapered to me. If you find a replacement plug that works, and it’s plastic, I would only install it hand tight. You're right it doesn't look tapered but again that 3/8" NTP only threads like 1 turn so I know its not 3/8" NPT and no one seems to know what size a 521 steering gear plug size is. All I could find on the internet is for 510s and that is 3/8" BSPT. Also when I was at ACE the stock plug threaded into a 1/2" compression nut with ease but there weren't any 1/2" NPT male plugs to be had. So maybe it is 1/2" NPT? Will pick one up from HD tomorrow and find out. Edited December 28, 2020 by d.p 1 Quote Link to comment
thisismatt Posted December 28, 2020 Report Share Posted December 28, 2020 3/8" npt doesn't fit but you want to try 1/2" npt??? 🤣 1 Quote Link to comment
d.p Posted December 28, 2020 Author Report Share Posted December 28, 2020 Just now, thisismatt said: 3/8" npt doesn't fit but you want to try 1/2" npt??? 🤣 No I do not. 1 Quote Link to comment
wayno Posted December 28, 2020 Report Share Posted December 28, 2020 Just flatten the broken end, use a hack saw or cutting wheel to slot it and put it in with a screw driver until you get a new one. 9 hours ago, d.p said: Stock vs 3/8 NPT: 1 Quote Link to comment
d.p Posted December 28, 2020 Author Report Share Posted December 28, 2020 Welp 1 foot forward 2 steps back. Fucked up my steering box when I originally tried to take out the column to replace the firewall grommet and mistakenly thought it came out through the cab. I guess I dislodged the end bearing and when I put it back together that bearing got wedged in-between the worm gear and the end of the steering box. When I turned the wheel it blew/pushed out out the cap on the bottom and mangled the shit out of the bearing. Stupid mistake and now I need to figure out how to fix it? I assume I need a new steering box and can replace the bearing? If not I guess I need an entire column and box? 1 1 Quote Link to comment
