d.p Posted August 6, 2017 Author Report Share Posted August 6, 2017 Nah I'm straight. Also I've found that it's much easier for me to find relevant information when there is a thread on it so just doing my part for the greater good. 1 Quote Link to comment
d.p Posted September 5, 2017 Author Report Share Posted September 5, 2017 .............. 1 Quote Link to comment
d.p Posted October 27, 2017 Author Report Share Posted October 27, 2017 Anyone know the thread/pitch for the PVC bung on the intake manifold? I deleted all that crap and want to plug that hole with a bolt but I assume its NPT (say that because fastenal couldn't match it) but no idea what size. Quote Link to comment
Crashtd420 Posted October 27, 2017 Report Share Posted October 27, 2017 If no one answers I can figure it out when I get home.... I have a pvc valve on my shelf..... 1 Quote Link to comment
Crashtd420 Posted October 27, 2017 Report Share Posted October 27, 2017 And if it's like some of the other fittings it's probably a 1/4 bspp thread.... British standard pipe thread Editing this to "bspt" There is a difference.... Bspp is straight Bspt is tapered 1 Quote Link to comment
DanielC Posted October 27, 2017 Report Share Posted October 27, 2017 I believe it is a 1/4 BSP. British Standard Pipe. 1 Quote Link to comment
d.p Posted October 27, 2017 Author Report Share Posted October 27, 2017 Ahh ok, do they sell that shit in stores? 1 Quote Link to comment
Crashtd420 Posted October 27, 2017 Report Share Posted October 27, 2017 Anyone know the thread/pitch for the PVC bung on the intake manifold? I deleted all that crap and want to plug that hole with a bolt but I assume its NPT (say that because fastenal couldn't match it) but no idea what size. Wait are you removing the pcv? I would keep it.... hook the pcv directly to the crank case vent.... 1 Quote Link to comment
d.p Posted October 27, 2017 Author Report Share Posted October 27, 2017 Wait are you removing the pcv? I would keep it.... hook the pcv directly to the crank case vent.... Might have described it wrong. Looking for the thread size of the bung on the right side of these manifolds. TVV? Not sure what its called. 1 Quote Link to comment
Crashtd420 Posted October 27, 2017 Report Share Posted October 27, 2017 The one on top? That's 1/8 And again probably bspt.... 1 Quote Link to comment
d.p Posted October 27, 2017 Author Report Share Posted October 27, 2017 The one on top? That's 1/8 And again probably bspp.... Yeah the one with the long tube sticking out on the right. I would take a picture of mine but too lazy. 1 Quote Link to comment
Crashtd420 Posted October 27, 2017 Report Share Posted October 27, 2017 Actually I just zoomed in and it might be 1/4.... I had 1/8 in my head because I was just looking at the same thing last night on my side draft intake.... 1 Quote Link to comment
Crashtd420 Posted October 27, 2017 Report Share Posted October 27, 2017 Probably cheapest and easiest to order online.... You could re tap with a 1/4 npt ... And get an npt plug... now your talking more money.. and you would want to take the intake of to do it... so no metal chips get inside.... 1 Quote Link to comment
wayno Posted October 27, 2017 Report Share Posted October 27, 2017 I use that one for power brakes, just put caps on the ends. 1 Quote Link to comment
d.p Posted October 27, 2017 Author Report Share Posted October 27, 2017 So a 1/4" one of these should work? https://www.discounthydraulichose.com/9030_BSPP_Hex_Head_Plug_p/9030.htm 1 Quote Link to comment
racerx Posted October 27, 2017 Report Share Posted October 27, 2017 You can't plug it with vacuum plugs? Those are available at auto parts store. 1 Quote Link to comment
d.p Posted October 27, 2017 Author Report Share Posted October 27, 2017 I can and did but I am OCD (not really) and don't like that look. Quote Link to comment
racerx Posted October 27, 2017 Report Share Posted October 27, 2017 Here you..it looks neater with a brass plug. 1 Quote Link to comment
Crashtd420 Posted October 27, 2017 Report Share Posted October 27, 2017 I think i said use bspp I believe I ment bspt.... Bspp is straight Bspt is tapered 1 Quote Link to comment
d.p Posted October 30, 2017 Author Report Share Posted October 30, 2017 Ordered 1/4” BPST... hopefully it will work. Anyone switched from spiral choke to a single wire one? Or just replaced OEM one? Mine has been acting up and every time I try and fix it it frays and I have to fight it to get it back on my Weber. Now it’s tight to pull and clicks when I push it in. Wondering what my options are? 1 Quote Link to comment
d.p Posted November 5, 2017 Author Report Share Posted November 5, 2017 Well 1/4” BPST fit the bill to plug that hole on the intake manifold. 1 Quote Link to comment
Crashtd420 Posted November 5, 2017 Report Share Posted November 5, 2017 Well after the whole bspp vs bspt I was hoping we got it right.... 1 Quote Link to comment
d.p Posted November 9, 2017 Author Report Share Posted November 9, 2017 Another day another problem to fix....intake manifold vacuum leak. For fucks sake its never ending with this thing. Click the link or the picture to see the video. https://flic.kr/p/Gp3G2a 1 Quote Link to comment
wayno Posted November 9, 2017 Report Share Posted November 9, 2017 Maybe I don't hear so good but my RPMs jump around that much just idling. When spraying flammable materials around looking for vacuum leaks the engine should noticeably jump up in RPM without a tach to look at, I really didn't hear a noticeable jump in RPMs, are you having a noticeable issue with the engine? 1 Quote Link to comment
