Stoffregen Motorsports Posted January 2, 2020 Report Share Posted January 2, 2020 The thickness is what concerns me. Too much squish might make it easy to crack the ears off the manifold. Let us know your impressions when you get it done. 1 Quote Link to comment
d.p Posted January 2, 2020 Report Share Posted January 2, 2020 What is the benefit of a gasket that much thinker than a run of the mill fel pro? 1 Quote Link to comment
mainer311 Posted January 2, 2020 Report Share Posted January 2, 2020 1 hour ago, d.p said: What is the benefit of a gasket that much thinker than a run of the mill fel pro? That particular material is made to crush up to 50% (from 1/8" down to 1/16") allowing for the sealing of imperfect surfaces and irregularities. From what I can tell, it looks like a bunch of loosely laminated graphite sheets. They're $37 on Amazon. I might give one a whirl when I put my Offy manifold on. 1 Quote Link to comment
Crashtd420 Posted January 2, 2020 Author Report Share Posted January 2, 2020 1 hour ago, d.p said: What is the benefit of a gasket that much thinker than a run of the mill fel pro? Not really sure.... The reason I bought it was the supposed claim that the intake gaskets without the gasket material between 2 and 3 exhaust are not good for headers.... if this is true or not I couldnt tell you... I'll see what my current gasket tells me when i remove it... This is the manufacturer's claim about the gasket I bought.... 1 Quote Link to comment
d.p Posted January 2, 2020 Report Share Posted January 2, 2020 Did your current intake gasket fail? Like I said I used fel pro for all mine and they have been rock solid. 1 Quote Link to comment
Crashtd420 Posted January 2, 2020 Author Report Share Posted January 2, 2020 No but I'm removing the intake to modify it for a pcv valve so I wanted a new gasket..... 1 Quote Link to comment
Crashtd420 Posted January 2, 2020 Author Report Share Posted January 2, 2020 2 minutes ago, d.p said: Did your current intake gasket fail? Like I said I used fel pro for all mine and they have been rock solid. I cant remember what brand I'm actually using.... I do remember I had to retorque the nuts once... 1 Quote Link to comment
mainer311 Posted January 2, 2020 Report Share Posted January 2, 2020 (edited) 8 minutes ago, Crashtd420 said: I cant remember what brand I'm actually using.... I do remember I had to retorque the nuts once... Same here. My intake manifold coolant passages keep weeping. Any idea what size the studs are? I'd like to change to studs all along the exhaust flange and just keep the 4 bolts at the top of the intake. Edited January 2, 2020 by mainer311 1 Quote Link to comment
d.p Posted January 2, 2020 Report Share Posted January 2, 2020 29 minutes ago, mainer311 said: Same here. My intake manifold coolant passages keep weeping. Any idea what size the studs are? I'd like to change to studs all along the exhaust flange and just keep the 4 bolts at the top of the intake. Not for nothing and no idea if this is true but california datsuns lists OEM studs as stainless. https://www.californiadatsun.com/exhaust-system/datsun-intake-exhaust-manifold-studs-l16-l18-l20b.html And per DanielC in another thread M8-1.25 but no mention of length. Although I could measure the ones sitting right next to me but I am lazy. 1 Quote Link to comment
mainer311 Posted January 2, 2020 Report Share Posted January 2, 2020 I don’t trust anything from California, including Ray. 1 Quote Link to comment
BrothersGarage Posted January 3, 2020 Report Share Posted January 3, 2020 59 minutes ago, mainer311 said: I don’t trust anything from California, including Ray. 😄 1 Quote Link to comment
banzai510(hainz) Posted January 3, 2020 Report Share Posted January 3, 2020 I believe zcardepot.com has studs and flange bolts ect…… I went with studs on the exhaust part of the head also I believe they are M8x1.25 but zcardepot list the thread pitch 2 Quote Link to comment
mainer311 Posted January 3, 2020 Report Share Posted January 3, 2020 33 minutes ago, banzai510(hainz) said: I believe zcardepot.com has studs and flange bolts ect…… I went with studs on the exhaust part of the head also I believe they are M8x1.25 but zcardepot list the thread pitch I looked, they're stainless with regular washers and flange nuts. Instead, I bought a 10-pack of Dorman 03411, and will reuse my thick washers. 1 Quote Link to comment
banzai510(hainz) Posted January 3, 2020 Report Share Posted January 3, 2020 I thought there was the stock nyclad versions also but I could be mistaken. there was varios version I thought. I seen the flange nuts.. I tried to fine stud nuts for exhaust and could not. But then I was looking at my exhaust manifold the the one stock stud that was on there I swear it was a M8x1.00 fine thread. I said fuck it and put M81.25 (both ends) on 2 of the studs the other stud was redone years ago by someone else and its a 5/16x24 which is the 521 SAE commonly used size) which is almost the same as a M8x1.00 which was confusing me. but what the guy replaced the studs in another exhaust manifold I had done (yesterday) Im sure its M8x1.25 but what came from the factory on the Y pipe side of the stud could have been M8x1.00 as I have the stock exhaust manifold Nut which is long and brass I believe and really think its fine thread as vibration but work it loose. But I cant check as the bolt broke insdie the nut while removing Really never had the Ypipe gasket go bad until this year with 30yrs of owning Datsun. So Im am new on this I just used a nut and washer and yes Im worried it will work loose 1 Quote Link to comment
mainer311 Posted January 3, 2020 Report Share Posted January 3, 2020 I believe the exhaust flange nuts are brass and crimped so they lock on, at least that's what I used. Dorman makes exhaust flange studs, and they come with those nuts. 1 Quote Link to comment
banzai510(hainz) Posted January 3, 2020 Report Share Posted January 3, 2020 (edited) Im going to make a purchase from these guys soon ,as I want to ck out their L series head gasket Mainer which is the best exhaust flange nut you think is best? https://zcardepot.com/collections/240z/products/copper-exhaust-manifold-flange-nut-240z-260z-280z# https://zcardepot.com/products/copper-exhaust-manifold-nut-set-240z-260z-280z?variant=19277176668273# Edited January 3, 2020 by banzai510(hainz) 1 Quote Link to comment
DanielC Posted January 3, 2020 Report Share Posted January 3, 2020 (edited) Here are some parts you will need to get from your local Nissan dealer. The gasket is obvious. The nuts are a type of stainless steel that does not seize to the manifold studs easily. I used these nuts on Ratsun, when I put the engine in it, in 2011. I cannot remember when the last time I removed the exhaust system from Dragon, and these nuts came off without breaking, or damaging the threads on the exhaust studs. I have also used these nuts on the exhaust studs on a VW powered dune buggy, with air cooled engine. No problems there either. Long story short, no broken exhaust manifold studs. Edited January 3, 2020 by DanielC 1 Quote Link to comment
banzai510(hainz) Posted January 3, 2020 Report Share Posted January 3, 2020 crap cant open photo 1 Quote Link to comment
d.p Posted January 3, 2020 Report Share Posted January 3, 2020 20602-S0600 Nuts 20691-A0880 GASKET EXHAUST 1 Quote Link to comment
mainer311 Posted January 3, 2020 Report Share Posted January 3, 2020 (edited) Hainz, I prefer the non-flanged nuts, and then just put a stainless washer under them. I also just purchased the Sanwa head gasket from them. It has seals around all of the passages. Edited January 3, 2020 by mainer311 1 Quote Link to comment
banzai510(hainz) Posted January 3, 2020 Report Share Posted January 3, 2020 OK thanks just to make clear I was going to order these as spares and use them on the lower Y pipe section of the manifold if needed (the 3 studs there)and put on my spare manifold if that's ever needed https://zcardepot.com/products/exhaust-intake-manifold-stud-oem-240z-260z-280z?variant=19276399083633# 1 Quote Link to comment
Stoffregen Motorsports Posted January 3, 2020 Report Share Posted January 3, 2020 (edited) Why pay retail when you can get studs from the source (or at least closer to the source)? I buy my hardware from various suppliers, but metric studs can be purchased from https://www.mcmaster.com/double-end-threaded-studs or https://www.belmetric.com/metric-studs-c-9.html Good, high quality JIS metric hardware can be found here - https://www.overlandmetric.com/collections/bulk-nuts-bolts-screws/M8 Though these guys make their hardware specifically for Toyota restorations, and it looks a bit different than the stuff Nissan used, it is very nice and doesn't have that hardware store look. Edited January 3, 2020 by Stoffregen Motorsports 1 Quote Link to comment
mainer311 Posted January 3, 2020 Report Share Posted January 3, 2020 I never understood why the factory bolts had cutout heads. It just ends up weakening the hex. 1 Quote Link to comment
banzai510(hainz) Posted January 4, 2020 Report Share Posted January 4, 2020 (edited) Daniel THANKS for the part numbers. Wish I would have got these in the first place that gasket looks better than the standard Felpro/ or other gasket set type. Yes those are the 3 long nuts needed Might get a set as spares but highly dought if I ever need this in the future. as once this trick wears out im dumping it and keep the 510 I never drive Edited January 4, 2020 by banzai510(hainz) 1 Quote Link to comment
bilzbobaggins Posted January 4, 2020 Report Share Posted January 4, 2020 I have tried to order two of those style gaskets for the Y pipe. Both times, nissan handed me a felpro looking one in a bag. No returns on them at my dealer either. Havent bought anything else from them in 8 years. 1 Quote Link to comment
