Crashtd420 Posted October 5, 2019 Author Report Share Posted October 5, 2019 2 hours ago, d.p said: Ouch! Are you referring to the 67 #? That's the mile per hour I was at in 3rd at peak power not the hp..... 1 Quote Link to comment
Crashtd420 Posted October 5, 2019 Author Report Share Posted October 5, 2019 Any how I went to pull the truck out to clean it up a little for tomorrow's show.... And I had a coolant puddle waiting for me ... luckily it was just the o ring on the drain had split... 1 Quote Link to comment
datzenmike Posted October 5, 2019 Report Share Posted October 5, 2019 14 hours ago, Crashtd420 said: I think 3rd.... Dyno sheet shows the peak hp at 67 mph ... I thought all HP are calculated by the increase in RPMs over time.... maybe not saying this right, but third will give a higher reading than 4th because it's a lower gear and why pulls are done in 4th. Differential gearing is also factored in. 1 Quote Link to comment
Stoffregen Motorsports Posted October 5, 2019 Report Share Posted October 5, 2019 That sound brings back memories. When I worked for Rebello, I lived only about a mile away from the shop at their old location. Dave would do dyno work on Saturdays and I could hear the dyno from my house. I would sometimes wake up to the distant sound of L motors. Sounds like a good little L motor. 1 Quote Link to comment
Crashtd420 Posted October 5, 2019 Author Report Share Posted October 5, 2019 21 minutes ago, datzenmike said: I thought all HP are calculated by the increase in RPMs over time.... That's a possibility .... the shop has a great reputation, mostly high horsepower efi stuff.... so I hope he knows what's right.... I emailed just to see.... even if I am making less hp I'm still happy with how it went and how it performed... plus I didnt destroy the motor so that's good..... 1 Quote Link to comment
datzenmike Posted October 5, 2019 Report Share Posted October 5, 2019 Ask the guy. Usually 4th or straight through to eliminate the transmission. Just spent a hour trying to find out if there is a difference in 3rd or 4th gear dyno pulls. One idiot said dynos measure HP..... and torque is calculated from this... what a tool. To properly adjust the HP reading in 3rd I think the operator would need the 3rd gear ratio so using 4th or 1:1 keeps all pulls on the same page for comparison. The operator would also need the differential ratio. and RPMs of the engine. I read once that an unscrupulous operator will make a base run in 4th make adjustments or add parts then make a run in third which would inflate the numbers to make it look good. I wish I knew more about this. 2 Quote Link to comment
datzenmike Posted October 5, 2019 Report Share Posted October 5, 2019 95 is as good a a good L20B. 1 Quote Link to comment
banzai510(hainz) Posted October 5, 2019 Report Share Posted October 5, 2019 Icehouse SR20 turbo would do 185 to 205 depending on minor adjustments. So when I see L 16 s claiming near that with dual carbs I call bullshit L18 insnt that much bigger 1 Quote Link to comment
datzenmike Posted October 5, 2019 Report Share Posted October 5, 2019 95 NOT 195. 1 Quote Link to comment
Crashtd420 Posted October 5, 2019 Author Report Share Posted October 5, 2019 Well I'm honestly doubting the numbers so I crunched some simple numbers.... If a stock L16 make 67 hp to the wheels + 10% 74 hp + 20% 80 hp + 30% 87 hp + 40% 95 hp.... I'm starting to doubt I've increased the hp by 40%..... The dyno guy knows the dyno I broke my motor in on.... he says that one is over by 10% so that means my original hp number of 86 is more like 77.... To increase 18 hp from just tuning ????? I think realistically if I'm putting down 80-84 hp thats 20-25% over stock that's pretty good..... If I'm actually putting down 95 then sweet if not so be it, motor still sounded sweet... 1 Quote Link to comment
thisismatt Posted October 5, 2019 Report Share Posted October 5, 2019 I've always heard Mustang dynos are rather generous... 1 Quote Link to comment
Crashtd420 Posted October 5, 2019 Author Report Share Posted October 5, 2019 Just now, thisismatt said: I've always heard Mustang dynos are rather generous... What's funny Is he says it not generous at all.... I don't know..... 1 Quote Link to comment
datzenmike Posted October 5, 2019 Report Share Posted October 5, 2019 Doesn't matter what it reads unless you compare to another engine. It's a great tool for fine tuning small amounts of hp you can't feel driving. It points out what's working and what isn't under real load conditions. I don't suppose you made a base line pull before 'improvements" were made? 1 Quote Link to comment
Crashtd420 Posted October 5, 2019 Author Report Share Posted October 5, 2019 Yes the baseline pull was actually almost the best combo .... Changes in between showed me what not to do.... luckily I paid attention because I didn't take notes.... Final pull was 1st combo with 1 step richer air corrector and to a higher rpm.... 1 Quote Link to comment
datzenmike Posted October 6, 2019 Report Share Posted October 6, 2019 I guess I meant L16 2bbl base line. I would expect high 60s. 1 Quote Link to comment
Crashtd420 Posted October 6, 2019 Author Report Share Posted October 6, 2019 Oh..... I know the number 67 hp has been said about a stock L16 ... I think hainz said a l16 sss setup would net 77 hp..... that's why I'm conceding to the fact that both dynos are over projecting my hp number..... 1 Quote Link to comment
banzai510(hainz) Posted October 6, 2019 Report Share Posted October 6, 2019 There was a dyno run of L18 SSS duel SUs that had that claim of 77. Stock L16 was like 65-67 or so.So having a sss cam ,200cc more 1.5 in ports duel carb only added 10hp over stock. Having 85-110 of of a L motor is really doing pretty good . 75 hp or more with a Weber DGV I would say is great also with a basic out out the stash distributor. If I could do it again I would have started out with L20s. This is just my opinion here .Im not a true expert on this but to get more hp out of a L motor is a work of art and a skill that most Ratsun people or not going to pay for when there or more torque motors like a KA or SRs out there cheap 1 Quote Link to comment
wayno Posted October 6, 2019 Report Share Posted October 6, 2019 Has everyone forgot what this engine is, it has pop-up/domed pistons, it is a high compression engine, and it also has a side draft Weber I think, this is not a stock engine and stock numbers do not apply here. 2 Quote Link to comment
Stoffregen Motorsports Posted October 6, 2019 Report Share Posted October 6, 2019 20 hours ago, Crashtd420 said: Well I'm honestly doubting the numbers so I crunched some simple numbers.... If a stock L16 make 67 hp to the wheels + 10% 74 hp + 20% 80 hp + 30% 87 hp + 40% 95 hp.... I'm starting to doubt I've increased the hp by 40%..... The dyno guy knows the dyno I broke my motor in on.... he says that one is over by 10% so that means my original hp number of 86 is more like 77.... To increase 18 hp from just tuning ????? I think realistically if I'm putting down 80-84 hp thats 20-25% over stock that's pretty good..... If I'm actually putting down 95 then sweet if not so be it, motor still sounded sweet... For sake of argument, when I was racing SCCA ITC in a 510, our engines were putting out 120-125hp on the engine dyno. A stock L16, according to common lore, made 96 hp. That's 30% right there. Our ITC L16s were blueprinted stock engines with the 210 TK cylinder head, a U20 cam, recurved distributor, Weber DGV and Comp header with 2.5" exhaust. You've got high compression, a big cam and a good intake. I think 40% gain with your setup is not implausible. 1 Quote Link to comment
datzenmike Posted October 6, 2019 Report Share Posted October 6, 2019 Engine dyno (or basically gross HP) is different from RWHP (or basically net HP). My engine tag says 110 HP for an L20B yet other later tags say low 90s for exact same engine. 1 Quote Link to comment
Charlie69 Posted October 6, 2019 Report Share Posted October 6, 2019 Mike would that be Canadian horse power as apposed to US horse power? LOL 1 Quote Link to comment
datzenmike Posted October 6, 2019 Report Share Posted October 6, 2019 Moose power. 1 1 Quote Link to comment
Stoffregen Motorsports Posted October 7, 2019 Report Share Posted October 7, 2019 19 hours ago, datzenmike said: Engine dyno (or basically gross HP) is different from RWHP (or basically net HP). My engine tag says 110 HP for an L20B yet other later tags say low 90s for exact same engine. I did say engine dyno. The numbers I gave were to illustrate the percent gained. 1 Quote Link to comment
Crashtd420 Posted October 8, 2019 Author Report Share Posted October 8, 2019 Well stroffgren I hope your right... I like the idea that I actually achieved 95hp..... This is the response from the dyno shop... "Yes, the rule of thumb is you would ideally like to use the 1:1 gear. However, we also don’t want to see the pull take more than 2 seconds per 1000 RPM of wide open throttle. I tried a short 4th gear pull and with the level of HP you are at, the 4th gear pull is way to slow and puts too much stress on the motor. Generally, this also generates a ton of heat and the engine loses power over the 3rd gear pull anyway. So I think what you have is the most accurate results we can get." And I'll leave that whole dyno conversation at that..... 2 Quote Link to comment
datzenmike Posted October 8, 2019 Report Share Posted October 8, 2019 I say bullshit to them. Who the hell hasn't held the throttle full open for more than 12 seconds. It's NEVER going to stress the engine. If you are merely looking to measure peak HP start the pull at 4K then. Now I suspect that they are inflating the output by using 3rd gear. 1 Quote Link to comment
