greenthumb Posted January 9, 2019 Report Share Posted January 9, 2019 I replied to an ad here on Ratsun. This guy wanted to clear out a bunch of parts, and we came to a package deal for all he had. Pretty happy to find the fuzzies in the box of goodies 1 Quote Link to comment
Crashtd420 Posted January 9, 2019 Author Report Share Posted January 9, 2019 I got the transmission ready for installation.... I was happy the reverse switch worked, and all the gears work..... What didn't work was the speedo pinion.... This one was in the transmission before, and never worked.... I always thought it was the cable... oddly it fit my 63 series 4 spd and worked.... what I found was for the 71b I had to rotate it 180 and now it works perfectly... But to keep it in place I had to cut the notch on the opposite side..... 2 Quote Link to comment
DanielC Posted January 9, 2019 Report Share Posted January 9, 2019 The flange where the transmission bolts to the engine is thicker. Get longer bolts, M10-1.5, I do not know the length. The lower bolt on the left side of the engine has a locating ring, that bolt need to be longer than the other three engine to transmission bolts. The started bolts on a stock four speed are through bolts, with nuts. The five speed transmission the starter bolts thread into the transmission bell housing. My 1980 720 five speed transmission has four switches. Which one is the reverse light switch on your transmission? 2 Quote Link to comment
Crashtd420 Posted January 9, 2019 Author Report Share Posted January 9, 2019 I have extra bolts and stuff , so I should be ok.... I remember the starter because when I went to bolt it up to the 4spd there were no threads.... As far as the reverse mine was the forward most switch..... 1 Quote Link to comment
mainer311 Posted January 9, 2019 Report Share Posted January 9, 2019 The sheep sticker on the 2x4 made me laugh. 3 1 Quote Link to comment
Crashtd420 Posted January 9, 2019 Author Report Share Posted January 9, 2019 That's funny.... I have no idea where that came from.... I didnt even see it till you said it.... 1 Quote Link to comment
datzenmike Posted January 10, 2019 Report Share Posted January 10, 2019 Done the same thing to my '79zx 5 speed when I put the '85 diesel tail on it. 2 Quote Link to comment
Crashtd420 Posted January 12, 2019 Author Report Share Posted January 12, 2019 Not much to update got the 4 spd pulled out today and the 5 spd in place.... Removal was much easier than the installation, the hole in my floor was a bit to small, and covered by my sound proofing and carpet... I was able to use a tin snips to cut and bend a piece of the tunnel down and out of the way ... luckily this piece is separate from the cab so if I want to i can repair it... I didnt feel like pulling the seats and carpeting..... Either way doesnt matter how it got done, it's in there..... Just glad I didnt have the long tail transmission.... Next is to get the rear mount made and bolt the rest back together..... 1 Quote Link to comment
datzenmike Posted January 12, 2019 Report Share Posted January 12, 2019 You used the 4 speed clutch arm and release collar? 1 Quote Link to comment
Crashtd420 Posted January 12, 2019 Author Report Share Posted January 12, 2019 32 minutes ago, datzenmike said: You used the 4 speed clutch arm and release collar? Yup.... that was correct to do right.... ? 1 Quote Link to comment
Stoffregen Motorsports Posted January 14, 2019 Report Share Posted January 14, 2019 As long as the collar matches the clutch cover and slave cylinder matches the release arm. 1 1 Quote Link to comment
Crashtd420 Posted January 14, 2019 Author Report Share Posted January 14, 2019 5 hours ago, Stoffregen Motorsports said: As long as the collar matches the clutch cover and slave cylinder matches the release arm. I'm good then.... 2 Quote Link to comment
Crashtd420 Posted January 19, 2019 Author Report Share Posted January 19, 2019 (edited) Well I probably should have done like Daniel did his bracket..... Mine came out ok...... Luckily the black hides alot..... structurally its beyond solid but it's a bit ugly underneath.... Edited January 19, 2019 by Crashtd420 1 Quote Link to comment
Crashtd420 Posted January 20, 2019 Author Report Share Posted January 20, 2019 Got the bracket bolted in..... I had some extra time so I was able to get some more stuff done too.. Installed the small boot on the transmission, the shifter with new bushings and a new knob.... I also got the shifter boot and floor cover bolted back down.... Then I was able to get the driveshaft back in and regreased the u joints and slip shaft.... Then bolted up the clutch slave cylinder and the starter..... I think all I have left is connect the back up light wires and fill it with oil.... Then test drive.... unfortunately we stand to get 1 to 2 feet of snow.... so that will have to wait..... 1 Quote Link to comment
Crashtd420 Posted January 23, 2019 Author Report Share Posted January 23, 2019 Had a moment yesterday and was able to get the reverse lights hooked up and working.... Then I filled the transmission and topped off the rear differential while I was under there.... Did a small test up on the jack stands... little sketchy but not bad.... Just wanted to see if things worked.... All gears worked and reverse with no wierd sounds so I'm very happy with that.... completely forgot to see if the speedometer was working, oh well it should be ok, I verified it on the bench... At least now its driveable again... cant wait to get it on the highway now.... 2 Quote Link to comment
datzenmike Posted January 23, 2019 Report Share Posted January 23, 2019 I sure don't miss the cold and snow of southern Ontario. I survived 8? winters with a daily 521. Not because of the heater but in spite of it. 2 Quote Link to comment
Crashtd420 Posted January 23, 2019 Author Report Share Posted January 23, 2019 1 hour ago, datzenmike said: I sure don't miss the cold and snow of southern Ontario. I survived 8? winters with a daily 521. Not because of the heater but in spite of it. Ya it's been 0 with -30 wind chill.... not a fan.... Datsun doesn't like the cold either, battery was a little low but it started yesterday.... I think it wants to go back to SoCal where I found it... 1 Quote Link to comment
mainer311 Posted January 24, 2019 Report Share Posted January 24, 2019 And now it's 50 and raining. Welcome to New England. 2 Quote Link to comment
Crashtd420 Posted January 24, 2019 Author Report Share Posted January 24, 2019 2 minutes ago, mainer311 said: And now it's 50 and raining. Welcome to New England. I was thinking the same thing this morning.... 1 Quote Link to comment
datzenmike Posted January 24, 2019 Report Share Posted January 24, 2019 I don't think I have ever seen below the low twenties F out here. - 4 or 5 C for a couple of days then back to rain. Spring can start as early as Feb 1 Quote Link to comment
Charlie69 Posted January 24, 2019 Report Share Posted January 24, 2019 On 1/23/2019 at 6:56 AM, datzenmike said: I sure don't miss the cold and snow of southern Ontario. I survived 8? winters with a daily 521. Not because of the heater but in spite of it. That is the reason I installed a 720 heater and AC in my 520. No more cold winter drives! 1 Quote Link to comment
mainer311 Posted January 24, 2019 Report Share Posted January 24, 2019 Once salt hits the roads, the Datsuns are parked until spring. 1 Quote Link to comment
mainer311 Posted January 30, 2019 Report Share Posted January 30, 2019 Neil, what RTV did you use on your oil pan? Right Stuff? 1 Quote Link to comment
Crashtd420 Posted January 30, 2019 Author Report Share Posted January 30, 2019 Yes...... This stuff..... Worked good..... I think I still have the tiniest leak though.. it doesn't hit the floor but I I can feel a little oil at the back corner of the pan.... I was trying not to over do it but I guess I should have put a little more in that corner..... still way better than before..... Maybe next oil change I'll try again.... 2 Quote Link to comment
mainer311 Posted January 30, 2019 Report Share Posted January 30, 2019 Thanks. I have a gasket coming in the mail, but it’s one of those damn cork ones. Trying to figure out the best approach. 1 Quote Link to comment
